Icy7CE
  1. hexpod
    hexpod http://heXpod.xyz
    berlin
    7,838Coins
    DC motor, 6DOF
    Yep, the longitudinal bug specific to fs2020 seems to be gone but like I thought I think we have an issue on lateral accel where we might have to subtract the wind and build a Profile similar to P3d.
    let‘s dig into it...
  2. hexpod
    berlin
    7,838Coins
    DC motor, 6DOF
    Funny even when the game is paused we have weather coming in or something :))
  3. hexpod
    berlin
    7,838Coins
    DC motor, 6DOF
  4. hideki
    hideki Active Member
    Spain
    - 208Coins
    2DOF, SCN5
    Hello guys. Any of you tried Flight Simulator with just the Joystick Plugin? Or this one is so much better as it is, that it's not even worth it trying it. I dont have the game yet but I am planning to by it. Just curious. Thanks
    153,818Coins
    +11,150 / 57 / -2
    When a plugin is available for a game use that, the Joystick plugin is for non-supported games.
  6. hideki
    Spain
    - 208Coins
    2DOF, SCN5
    OK. thanks Noorbeast I thought some people were struggeling with this game
  7. frsim09
    frsim09 Member
    Ariège, France
    604Coins
    Hi @DZSchneider, i have the same problem with the H135 and the Bell 47 G2 Helicopters, the values on the Heave axis do not move during the flight, the only time there are values that move are when the skids leave the ground or on landing, when they touch the ground. Do other users have the same problem on this axis ?. However this axis works perfectly with all the planes
  8. ALXXX
    ALXXX 2Dof Motion in progress Gold Contributor
    Stuttgart
    7Coins
    Anyone knows if it is possible to play flight simulator on the xbox series x in combination with motion seat and the joystick plug in ?
    This would be great
  9. hexpod
    berlin
    7,838Coins
    DC motor, 6DOF
    Seems to be another asobo bug. standard accelerations are unusable in helicopters. Another telemetry (body velocity) has to be used
  10. tadeusz
    tadeusz New Member
    34Coins
    Hi
    I am new
    what should I do to be able to download the FS2020 plugin?
    regards
    Tadek
    153,818Coins
    +11,150 / 57 / -2
    You can use 250 of your Forum Activity Coins here: https://www.xsimulator.net/community/shop/
    That will allow you to have a weeks access to download as many plugins as you like, including MSFS2020.
    Those plugins will remain functional as long as there are no game changes/updates that may break some plugins.
    See the FAQs for further details: https://www.xsimulator.net/community/faq/coins-and-how-to-download-plugins.2/
  12. Zed
    USA
    5,845Coins
  13. jeanmehdi
    jeanmehdi New Member
    LONDON
    - 201Coins
    hi, do you mind me asking what version you are using and where i can get it please ?
    thanks
  14. tadeusz
    tadeusz New Member
    34Coins
    hi
    Is there any instruction on how to use this plagin
    direct to FlyPt?
    Best regards
  15. Magnum95
    Magnum95 New Member
    23Coins
    3DOF, SCN6
    Having a Prosimu T1000 3Motion, when launching Game Manager, I don't see Extra 1/2/3 ticked in red which result in non working yaw when I use my rudder.
    Only the front actuators work (fine).
    Any idea ?
    Cheers from Paris.
  16. Unbreakable_Xman
    Unbreakable_Xman New Member
    6Coins
    153,818Coins
    +11,150 / 57 / -2
  18. DJJohnson
    DJJohnson New Member
    Gladstone, Michigan
    - 59Coins
    3DOF, Arduino
    Wow! Great plugin. Worked great. Now I'd love to get a plugin for Planet Coaster.
  19. Michail
    748Coins
    why no motion? game patched, when i start the game the rig switch to neutral position, but no motion. tuning center capturing all zero values in green fields.
    when started fowing ecpotion will occur:
  20. VFX Pro
    VFX Pro Member
    Los Angeles
    431Coins
    Motion platform, 6DOF
    I have a prosimu p7mp and I have problem with jerky, steppy, stuttery movement with this plugin. No issues in racing games. I cannot tell if it's from the game or the plugin. I'm cranking the smoothness in the axis assigments, but not luck. Help?
