Budget 2DOF
Discussion in 'DIY Motion Simulator Projects' started by Surferjo86, Jun 10, 2020.
  1. Surferjo86
    Surferjo86 New Member
    Sheffield
    43Coins
    2DOF, 3DOF, DC motor, Arduino, 4DOF, 6DOF
    So finally.. She moves!
    I've got a fair bit done with the cockpit and controls. Still loads of tidying up to do yet.
    But the new smaller motors are working great! Just need to figure out how to get her working in game now.
    Added some pictures, will try and get a video posted.
      258.7 KB
      314
      241.4 KB
      307
  2. Surferjo86
    Sheffield
    43Coins
    Back to the trouble.
    The rig is moving perfectly in SMC3
    But does not move on the sliders in the game engine.
    Any advice would be greatly appreciated.
    I thought today would be the day!
    I have the game patch loaded.
    pulling my hair out again
    153,818Coins
    +11,150 / 57 / -2
    If you are using SMC3 then your SimTools Interface Settings should be like this, as per the SMC3 guide:
    BitsPerSec - 500000
    Data Bits - 8
    Parity - None
    Stop Bit -1
    Output Bit Range - 10
    Output Type - Binary
    Interface Output - [A<Axis1a>][B<Axis2a>]
  4. Surferjo86
    Sheffield
    43Coins
    Thankyou so much for the quick reply! she moves!
    Time to fly now
  5. Surferjo86
    Sheffield
    43Coins
    Fine tuning now, having a ball playing war thunder!
    Could anyone explain why my rig isn't following the command line? upload_2021-7-3_16-45-1.png
    I'm going t o be adding yaw and a seatbelt for G forces shortly.
    Thankyou to everyone who helped me get this thing moving.
    Joe
  6. Surferjo86
    Sheffield
    43Coins
    Here’s a link to a video of the rig working. Will get a better clip at some point
  7. Surferjo86
    Sheffield
    43Coins
    So I'm building a new project. 6DOF, Having trouble with SMC3 for some reason the 10k pot is on all 3 motor channels. Not sure what's happening. I have re installed firmware, re wired. Checked to see if the pins are linked. I have also used 3 different uno's with the same result.
    Not sure where to go from here. Pictures to follow
    If anyone out there could shed any light on this issue that would be great.
    J
