Showroom 6 dof - Odrive - BLDC - New design
Discussion in 'DIY Motion Simulator Projects' started by Will974, Apr 19, 2020.
  1. Will974
    Will974 Active Member
    Industrial Ingeenering Teacher
    Reunion Island
    953Coins
    An example of 3D print and CNC version ;)
  2. Will974
    Reunion Island
    953Coins
    Just a photo of my finished actuator ;)
    Fit and strong ! :) IMG_20210311_193938.jpg
    • Winner Winner x 3
  3. Will974
    Reunion Island
    953Coins
    The different arms are ready :) !!! It looks so pretty ! P10517-194213.jpg
  4. Will974
    Reunion Island
    953Coins
    The six actuators are also ready ! (The missing one is on my bench test) P10524-221915.jpg
    • Winner Winner x 3
  5. Will974
    Reunion Island
    953Coins
    The upper platform is ready !
  6. Will974
    Reunion Island
    953Coins
    Hi everyone,
    Just a short video to show the rig in action. All plastic parts seems to be good ! My 3D printed linear actuator concept is OK !!!! I tested the rig with 90 Kg user and there was no problem. Demonstration of plastic parts is OK ! Now, it's time to switch to aluminium parts :) !!!! Actuators will be more professionnal and strong ;-) See you next update !
    • Like Like x 5
  7. Joey
    Joey Member
    Technician
    Nijmegen
    436Coins
    Motion platform, 6DOF
    How did you interface the odrives? via uart?
  8. Will974
    Reunion Island
    953Coins
    The odrives is interfaced via their usb port.
  9. Arta Yasa
    Arta Yasa Member
    824Coins
    Hi sir, what type of bldc motor do u used??
    It is a sama with ac servo 100-400wat?
  10. Will974
    Reunion Island
    953Coins
    hi,
    I'm using Brushless DC motor. It's the same motor that you can see on my bench test page 1. Power is about 2450 Watt....
  11. Arta Yasa
    Arta Yasa Member
    824Coins
    It like a motor rc boat sir?? Because i have see rc boat bldc with 3000watt
    151,461Coins
    +11,038 / 56 / -2
    Can you please start your own build thread and raise all questions relating to it there, rather than across multiple other member threads, which you can link to if relevant.
  13. Arta Yasa
    Arta Yasa Member
    824Coins
    Alright sir, and sorry for that, thank you for th recomend sir
  14. Joey
    Joey Member
    Technician
    Nijmegen
    436Coins
    What firmware do you use? The odrivefinal.hex from silent chill?
  15. Will974
    Reunion Island
    953Coins
    Certainly....
  16. Will974
    Reunion Island
    953Coins
    Most of odrive users use the silent chill firmware....
  17. Will974
    Reunion Island
    953Coins
    Hi, just a short update,
    I work on my electrical box..... It's pretty finished ... It misses the cover grid... Electrical box.jpg
  18. ryanosman
    ryanosman New Member
    Commercial Recreational Sim Owner/Operator
    Western Canada
    272Coins
    3DOF, DC motor, AC motor, Arduino, Motion platform, 6DOF
    Any new developments here :) ?
  19. Will974
    Reunion Island
    953Coins
    Hi, sorry for late,
    The rig is still in development.... I have stopped the rig to update actuators by switching plastic parts with aluminum parts... I must also replace the encoder cable with a high quality shielded cable.... and many things... It takes many times but at the end, the rig and actuators will be stronger !!!! Photos will come soon ;-)
  20. PeterW
    PeterW alias Wickie
    Dipl. Ing. Mb (FH)
    1,755Coins
    Hi Will!
    Why do you want to make your actuators stronger? What are the weak parts or areas? I think this is quite interesting for all guys who want to use 3D-printed parts in an actuators
