  1. noorbeast
    153,824Coins
    +11,150 / 57 / -2
    The likes of SMC3 code allow control of the hardware, while SimTools and plugins get data from a game and allow motion profiles for specific games to be set up.
    Yes SMC3 code should be installed on the Arduino(s) and the configuration tool used to properly configure everything for the particular hardware you are using: http://www.xsimulator.net/community...3dof-motor-driver-and-windows-utilities.4957/
    You should then grab a copy of the SimTools manual and keep it handy for reference: https://www.xsimulator.net/community/faq/rtfm-start-with-the-official-simtools-documentation.117/
    SimTools can then be configured, see the tips here: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
    But before doing any of that you should ensure you have a sound design and hardware selected that is suitable for that design: https://www.xsimulator.net/community/faq/design-considerations-resources.24/category
  2. sci666
    1,210Coins
    great :) thanks ! sorry for these many questions but i just started ant its my learning phase :-D
  3. Manes
    Manes Member
    179Coins
    Hi to all!
    I finish my 2 dof some weeks ago. I am using SMC3 with Sabertooth 2x60 and I have problems. I go with the sim 5 laps without problem but sometimes the motors want to be crazy. They start to tremble or directly they off. I need restart SCM3 and I touch parameters but I don't To get A movement without problems. If I down parameters un tunning center, I dont have the problem, but I dont have movemets. I need help. I dont understound why is the problem. I would like have help of the profesionals of here :D
  4. Gadget999
    12,132Coins
    are you getting interference on the signal / pot line ?
    Is the wire shielded and grounded ?
  5. XaviAlonso
    XaviAlonso Member
    España
    103Coins
    Maybe it is not the solution but when you finish to config the smc3 you need to close the software, and not still running when you have the sim and the software of simtools
    in my case i can not running the smc3 and the sim at the same time.
    good work btw.
  6. moaale
    moaale IAN MRTIN
    NN
    ARGENTINA
    96Coins
    2DOF, DC motor, SimforceGT
    Hello friend, I am speaking to you from Argentina .... note that surely you must have problems with the potentiometers you have to check if the potentiometers are well coupled with the layered motors that are knitted ... note that in the SMC3 they ballan the most together possible the green and blue lines of each potentiometer.
  7. Manes
    Manes Member
    179Coins
    no have ground cable. is a sensor hall. Interferences?? mmm yes.... sometimes when the motors are stopped i fell a little movement. The sensor hall is conected with utp cable with rj45. Is posible it was the problem??
  8. Manes
    Manes Member
    179Coins
    [QUOTE = "moaale, post: 220472, miembro: 5397"] Hola amigo, te hablo desde Argentina .... nota que seguramente tienes problemas con los potenciómetros tienes que comprobar si los potenciómetros están bien acoplados los motores estratificados que se tejen ... nótese que en el SMC3 se equilibran lo más posible las líneas verde y azul de cada potenciómetro. [/ QUOTE]
    ok i go to see that. I think the smc3 have a good movement with the lines
  9. Manes
    Manes Member
    179Coins
    Esta es la sala de sensores con cable utp y rj45
  10. Trigen
    Trigen Active Member
    2,891Coins
    I have sabertooth 2x32
    You have to ground port 8 on the ardunio to get them into 115 000 baud rate or they will go crazy on you. It happens on a rare occasion in 115 to. The cannot handle any more.
    Smc tool does not work in 115 so I have added a switch on mine
    Might need to set the calculation rate fsid something to 3 too
  11. Manes
    Manes Member
    179Coins
    I read the manual and I Saw that but I didnt take It into consideration because i have 2x60, no 2x32. Go to check. Thanks man
  12. Bastiuscha
    Bastiuscha Active Member
    750Coins
    @Manes
    I would recomend a calculation rate of 3 too.
    Your KP Value is really big to. Do your geaboxes have 60:1 ?
    Did you try to set PWNmin a little lower? 15 ?
  13. Manes
    Manes Member
    179Coins
    I dont know the ratio of gearbox but I know the motor have 60 Nm at 42 rpm
  14. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,037Coins
    3DOF, DC motor, Arduino, 6DOF
    Your SMC3 value seems off. This is what SilentShill gave me a long time ago:
    This is the last time I checked mine.
    Don't be afraid to put your Fpid higher. Also, put the Max Limit and the Clip Input just before the maximum position where the motor will go wrong. One tries to reverse the motor before it`s too late, and the other stop it.
    I hope this helps.
  15. MarcoMade
    MarcoMade Active Member
    italy
    157Coins
    Hello. I'm afraid you should use a stereo shielded cable such as a microphone or stereo headphone. and connect the braid to the negative.
    the cable you use is probably not suitable or not able to shield the RF emitted by the motors.
    that constant reversals emit a lot of dirt. let me know hello Marco
  16. Manes
    Manes Member
    179Coins
    Thanks for the support guys. This afternoon I Will check this solutions. We keep on touch. Thanks thanks
  17. hannibal
    hannibal Active Member
    4,492Coins
    i also had to do the same with grounding pin 8 due to the erratic shaking. and i also added a switch so i can get into the SMC3 utility
  18. Manes
    Manes Member
    179Coins
    Where I need puta the switch?? I dont understand , sorry
  19. Manes
    Manes Member
    179Coins
    After to do all yours ideas and configurations, I have the same problem.
    Change cables whith gnd , adjust potenciometers, and put SMC3 whith the parameters same than Pierre and modding this parameters, and parameters of all tipes, and I have the same problem. When i put pin8 or 9 Whith gnd in Arduino, i can't start SMC3 ... It is imposible. .....
  20. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,037Coins
