Showroom FlyPT - 6DOF Brushless DIY Actuators
Discussion in 'DIY Motion Simulator Projects' started by pmvcda, Aug 29, 2017.
  1. katy77
    katy77 New Member
    73Coins
    AC motor, SimAxe, Arduino, Motion platform
    @pmvcda I use Schneider plc (Modicon 262)
    The issue is sending commands from flypt mover to plc, I am thinking of using UDP, I don’t know if you have any more ideas!
  2. pmvcda
    15,448Coins
    Let me check
  3. pmvcda
    15,448Coins
    @katy77 this?
    This one is motion control 8 axes
  4. katy77
    katy77 New Member
    73Coins
    yes exactly
  5. katy77
    katy77 New Member
    73Coins
    Do you have any idea How I can communicate it with flyptmover?
  6. AndreFilipe
    AndreFilipe Andrefly
    businessperson
    Brasil
    - 55Coins
    3DOF, DC motor, SCN6, SimAxe, Arduino, SimforceGT, Motion platform, 6DOF
    Hello, what software do you have to simulate these movements? thanks!
  7. pmvcda
    15,448Coins
    My own software: Flypt Mover
  8. zhai1987
    zhai1987 Member
    320Coins
    2DOF, 3DOF, AC motor
    Brother, thank you. We have placed an order for production!
  9. John Snell
    John Snell Member
    191Coins
    Hi @pmvcda.
    Did you get the cheap BLDC motor driver working that you got from China and mentioned in this post?:
    https://www.xsimulator.net/communit...shless-diy-actuators.10799/page-5#post-160376
    I have some similar ones, and I have been unsuccessfully trying to get them to work using SMC3Util. The result is a very jerky movement as they very closely following the sinewave (or other) signal from SMC3Util. There is a video here:
    https://www.xsimulator.net/communit...-using-brushless-dc-motors.16544/#post-221353
    Do you think that switching to BLDC-8015A motor drivers will solve this? or have I done simply something wrong in my setup to get this result? I'm hesitating making a purchase of new drivers in case it's not the problem
    (I have ordered ESP32s to be able to use the motor hall sensors)
    Love your work! Thanks!
    John
  10. pmvcda
    15,448Coins
    I never tried it... But should be just a replacement from 8015A to those cheap ones.
    I think currents/voltage are the same, just swap the BLDC8015A with those ones.
    One of the main differences is the adjustment you have inside the 8015A that allows you to make speeds match between different controllers and motors.
    It's cheap material, don't expect acurancy.
  11. xeg1101
    xeg1101 New Member
    Texas, USA
    93Coins
    Hello. I'm very impressed how detailed you are with your build process. I am looking to build a new simulator, but I am new to motion sims. One question though, from what I've seen of stewart platform 6dof sims online, was there a particular reason you went with this particular design where the seat cradle is "suspended" in the middle of the joints, vs. something like where the cradle is riding on top of the linkages. (see image). This latter type seems to be more space efficient, but do you know which type has better range of motion? or would that be more dependent on actuator length than platform position.
  12. pmvcda
    15,448Coins
    The center of rotation that allows you more range is in the midlle of the top platform.
    So if you seat sunken inside, you are going to have that COR higher.
    But the software can compensate it, but loosing range around that cor.
    The main reason is stability and use the structure to support wheels and other controllers (between the front actuators).
    Also, it's easier to go in and out. Not to high.
    You can make it really compact with high precision actuators, and get lot's of movement for a small displacement (angles), but to have them small, you need gearboxes, and then you loose in linear speed for example in heave.
    Don't know if I explained it well...
  13. xeg1101
    xeg1101 New Member
    Texas, USA
    93Coins
    Explained very well, thank you. While I was browsing through the thread here, I noticed you talking about batteries in the power circuit. Are you still using these? Was it a successful buffer for when motors were at peak current draw?
    I am also trying to wrap my head around the issue of power delivery overall for this system. I see the power supply you chose and it's input requirements. I am in the U.S., and our regular outlets in the home are ~120VAC, with the exception of the clothes dryer outlets which do 240VAC @ 30A.
    Do you happen to have taken measurements of how much power the rig draws under operation?
    And hopefully anyone reading this who lives in the USA and has built something similar can provide some insight?
  14. John Snell
    John Snell Member
    191Coins
    Hi guys.
    I've been trying unsuccessfully to get a single BLDC motor with wormdrive working with the esp32 (this is a proof-of-concept before I start physical construction).
    The motor has a built-in Hall sensor (yay!), I have the same Wantai motor driver, PCBs from an earlier post in this thread, and I have uploaded the correct sketch from the fist page of this thread to the ESP32 using the Arduino IDE. I also wired and checked the limiter switches and resister as per the post on page 26.
    When I power it on the motor turns smoothly, the FR pin of the motor driver has +3 volts on it. If I press the minimum limiter switch then the motor stops (I can see in the code that it has been recognised), and at this point the FR pin on the motor driver has zero volts on it.
    Should the motor reverse at that point? I'm expecting it to and I can't figure out why it doesn't. Is it possible that I have my hall sensor wires and power wires in the wrong order on the motor driver? I did have this exact issue on a different motor driver I was trying, so would be surprised if I got it wrong on both of them.
    Any help on why my motor is not reversing at that point would be REALLY appreciated? Am I right that it should reverse?
    Thanks a lot
    John
  15. pmvcda
    15,448Coins
    Been some time I don't touch the code or the hardware.
    It works for me, so...
    But from what I remember, the code is made for 3 actuators, so it waits for the other 2 to acomplish the calibration.
    Take a look at the code, you can change the number of actuators to 1.
    Could be another problem.
  16. John Snell
    John Snell Member
    191Coins
    Hi @pmvcda. Thanks so much for taking the time to reply.
    EDIT: I have set the number of actuators to 1, this is important to get through the calibration loops.
    Then I realised that the motor was in fact reversing, as it should, upon reaching the Max limit, but immediately thought it has also found the Min limit and so stopped rotating... this pointed to something being wrong with the limit switch wiring. I did know that an update had been posted on page 26 by @Richh999, but I didn't realise (didn't notice) that it is still a little different to the diagram currently on page 1. Correct diagram is here:
    https://www.xsimulator.net/communit...hless-diy-actuators.10799/page-26#post-192260
    By changing the wiring to match the updated diagram I seem to have successful motor calibration now.
  17. Richh999
    Richh999 New Member
    Engineer
    Uk
    150Coins
    So it's been a while but I had pretty much finished the project about 18months ago but just had some tidying up and then get my head around the software side of things and filters but haven't touched it since. Had a few test runs and was all running great.
    I'm just getting it all setup again and was hoping that someone might be able to share their Mover config (filter setups) with me as a starting point as I never really got this side of it working. Last Mover version I used was 2.9.9 so just downloaded the latest version.
    My rig is pretty much the same dimensions as @pmvcda and uses the BLDC-8015A too if that helps.
    If I could get some Sources and Poses with filters to get started for the following to then tweak for my rig that would be very helpful. The top 3 are what I mainly use.
    X-Plane 11
    rFactor 2
    Dirt Rally 2
    FS2020
    Assetto Corsa
    Forza 4
    Much appreciated and TIA.
  18. Racerr87
    Racerr87 New Member
    6Coins
    Awesome thread for reading and massive respect for the DIY!
    I was wondering why did you choose an esp32 instead of arduino uno? Would it be possible to control more actuators with the esp?
    Thanks!
  19. C.Y
    C.Y New Member
    120Coins
    I was thinking the same but with a Thanos AMC AASD15A ?? I'm new and so confused ... my understanding is this product is the benchmark as it is basically plug and play. Is it a matter of these posts / builds / tutorials were made prior to the Thanos release thus ... if its still working for them then why change it ??
  20. pmvcda
    15,448Coins
    @C.Y and @Racerr87 , the ESP32 is way faster compared to the Arduino.
    Using the AASD15A is simpler and easier to build and with lot's of power.
