Wagnard
Elite Dangerous Horizons/Odyssey Plugin (XML edition) 4.3.0.0 pointer update
  1. RENZOREY18
    RENZOREY18 Member
    46Coins
    2DOF, 3DOF, Arduino
    traducido con google
    hello genius
    the steps i did
    1 _install the plugin in (pluginupdater)
    2_patch the Elitedangerous 64 in (game manager)
    3_ (tuning center) these values roll = +1.5 / - 1.5
    step = +1.5 / - 1.5
    elevation = +1.5 / -1.5
    roll = +1.5 / -1.5
    increase = +1.5 / -1.5
    extra = 0
    extra2 = 0
    extra3 = 0
    I did this manually, is it done differently?
    I would also like to understand that it is XML, do you have to install it in a folder?
    as the game does not send telemetry signal I am using steam
    buy the game in instagame has something to do?
    153,041Coins
    +11,116 / 56 / -2
    Special instructions:
    -If you are updating from a previous working version of this plugin, there is no need to patch again, just use the SimTools plugin updater.
    -After patching, have a look at the XML to configure the forces to your desired values.
    -If GameManager crash on game launch, it probably mean you have an outdated wow64ext.dll (9kb) in the plugin directory.
    I advise you replace it with the one located on your simtools installation directory, it should be around 700kb in size.
  3. George Dobransky
    Hungary
    - 43Coins
    Wagnard,
    At first, thnx for the updated plugin, it works well. But after yesterday's windows update at me there is an issue with the plugin... When hyperspace jump after dropping out from Hyperspace there is a strange movement for a second, and at the station when released from the station also one second strange movement. At normal flying (not in supercruise when open system map after few seconds it rolls to one side, when back in the cabin it stays back..)
    Anybody experienced that issue?
    George
  4. Wagnard
    Wagnardsoft
    Canada, Quebec, Mirabel
    5,277Coins
    I will try to repro.
  5. kev b
    kev b Active Member
    Academic Lecturer - Electrical Engineering
    Swindon, UK
    929Coins
    3DOF, Arduino, Motion platform, 6DOF
    Hi fellas,
    Maybe some good news on the horizon.
    Just noticed this on the Elite Issue tracker from a couple of days ago regarding Telemetry for motion data from the game for our simulators.
    @Konstruukt - have you seen this? as you originally raised the ticket.
    If I'm reading it correctly they are now investigating it and have specified possible release in update 8
  6. Mechromancer
    434Coins
    OMG...the tease is excruciating! LOL
  7. George Dobransky
    Hungary
    - 43Coins
    Best news in ED history for us.....
  8. Wagnard
    Wagnardsoft
    5,277Coins
    Let's just hope they make it simple for us to make the plugin.
  9. George Dobransky
    Hungary
    - 43Coins
    NEW, UPDATE, we need new pointers????
  10. Wagnard
    Wagnardsoft
    5,277Coins
    EDH & EDO Update 8 pointers updates.
  11. George Dobransky
    Hungary
    - 43Coins
    Wagnard,
    Thanx a lot, buddy, beer has gone to you!
    Cheers
  12. Wagnard
    Wagnardsoft
    5,277Coins
    Thanks ! that beer was refreshing ! :D
  13. RENZOREY18
    RENZOREY18 Member
    46Coins
    2DOF, 3DOF, Arduino
    :traductor google
    hello mr wagnard,
    First of all, thanks for your work and time, now I am about to ask a question and excuse my ignorance, but I would like to know what this file (EliteDangerous64_Offsets.zip) is for, and where should I install it? ...
    I previously posted that the pluig didn't work for me and I see that wow64ext.dll is from 08/14/2018 so I'll update it to see if the pluig works for me
    thanks and regards !!
  14. RENZOREY18
    RENZOREY18 Member
    46Coins
    2DOF, 3DOF, Arduino
    hello @noorbeast,
    where do i find the plugin directory?
    to see if my wow64ext.dll file is out of date
  15. Wagnard
    Wagnardsoft
    5,277Coins
    Once you have the main plugin installed, you just drag and drop the EliteDangerous64_Offsets.zip (just like a plugin) in the "SimtoolS PluginUpdater", the file will go automatically at the good place.
    Also be sure you do NOT have the "wow64ext.dll" file inside your plugin folder : C:\Users\*youruser*\AppData\Local\SimTools\GamePlugins
    wow64ext.dll (+-769KB) should only be present in C:\Program Files (x86)\SimTools
  16. RENZOREY18
    RENZOREY18 Member
    46Coins
    2DOF, 3DOF, Arduino
    Here in this video you will see that the game communicates with the simtools but I am not getting telemetry since the tuning center does not capture the movement.
    Do I have to configure something in the game?
    or do I have it on Steam?
    Or what happened I skipped so that I have no movement?
    thanks again for your time greetings I hope to be able to give movement to this game
    153,041Coins
    +11,116 / 56 / -2
    For me the video is listed as Unavailable, perhaps the settings need to be changed to Public.
  18. RENZOREY18
    RENZOREY18 Member
    46Coins
    2DOF, 3DOF, Arduino
    I'm sorry, my mistake, I changed it, you can check if you can see it?
  19. Wagnard
    Wagnardsoft
    5,277Coins
    Post the content of "EliteDangerous64_Offsets.xml" from "C:\Users\*your current user*\AppData\Local\SimTools\GamePlugins"
  20. Wagnard
    Wagnardsoft
    5,277Coins
    Fixed pointers for YAW with Horizon. (8.01)
