$450 Mige Direct Drive Wheel using MMOS and AASD
Discussion in 'DIY peripherals' started by Peacemaker105, May 6, 2020.
  1. JonBakhol
    JonBakhol Active Member
    Netherlands harderwijk
    443Coins
    @Da3vr,
    Thanks I'll have a go at it tonight. Hope that the legacy wheel instead of custom does the trick.
    I'll let you know.
    Ride on
    Bakhol
  2. JonBakhol
    443Coins
    @Da3vr.
    Legacy did the trick. Now the settings :)
  3. phongshader
    phongshader New Member
    39Coins
    is there an stl file for the cirtuit board/plugs box available?
  4. llluis
    Quebec
    1,632Coins
  5. phongshader
    39Coins
    Thank you, is there an stl file for the enclosure that does not use TDD board as in the 1st post in this thread?
  6. llluis
    Quebec
    1,632Coins
    Probably not... Unless you search in thingiverse for an standard STM32F04 enclosure.
  7. JonBakhol
    443Coins
    He guys
    I got the Thanos TDD V1.1 PCB and ordered the DAC and LED'S.
    Can't figure out which resistors/capacitor are used for the LED'S and around the DAC.
    Anyone a suggestion?
    Edit ( 2,2 K for the LED's, 0,1 µF for the DAC)
    Ride on
    Bakhol
  8. phongshader
    39Coins
    It should be jumped like this?
    I'm not using the thanos board, wiring directly to the core407v board
  9. JonBakhol
    443Coins
    Did the jump like that worked? I do have a TDD board which I gave to a friend, but it isn't running yet.
    please let me know.
    Ride on
    Bakhol
  10. phongshader
    39Coins
    NO! it did not, I was very wrong, fortunately I didn't fry anything. There are 3 pads, the board comes with the 5vin and center pad jumped, what you want to do is remove the solder that jumps those pads and add a solder jump between the center pad and usb5vout pad
  11. votrungchi
    votrungchi New Member
    61Coins
    Hello @Peacemaker105, I found your work very interesting and I want to make mine one.
    I have a question, could I use other brands AC Servo motor like below? (Times Brilliant).
    The reason is I can not find MIGE motor at my local store. Thank you so much in advance.
    H11003d2eb559413f955d434eea01404fn.jpg Had7e8180d0804f09bda1fb2b5ea6a471z.jpg
  12. JonBakhol
    443Coins
    The Nm of these 2 servo's are very low.
    The most of us just ordered the servo online at Aliexpress.
    https://nl.aliexpress.com/item/3286...=glo2nld&spm=a2g0s.9042311.0.0.67274c4d5qpWWV
    Have a good search.
  13. votrungchi
    61Coins
    Thank you for your reply. I know I will select a bigger servo. The main point I want to ask is could I use another brand servo that looks similar for this DIY, are there servo from China compatible?
  14. JonBakhol
    443Coins
    Most likely you can use different servo's and controllers. The main question is that you need to put the same parameters in the controller as the controller used by Peacemaker. If this is the case, I don't see any problems.
    But maybe you have to wait for some others who used different controllers, for their experience.
    Have a good day
  15. votrungchi
    61Coins
    Yes, I think I could use these servos as well. But since I have no experience with AC Servo that is why I want to confirm. Let's wait for someone with their experience.
    Have a great day!
  16. sedesa tatasa
    sedesa tatasa Member
    509Coins
    Other servo drivers may not be able to control the direction with dir-pe11.
    In that case, +-analog signal is required.
  17. Ak Yarla
    Ak Yarla New Member
    16Coins
    DC motor
  18. Richh999
    Richh999 New Member
    Engineer
    Uk
    150Coins
    So I made one of these a while ago, didn't really used it due to RL and just making some loadcell pedals for myself now. Has anyone been able to solve the 10khz whine from the AASD yet or is it that you have to use a different driver?
  19. Gadget999
    12,132Coins
    what is RL ?
    you can not get rid of the 10khz squeal - unless you use a different driver
