Diablo2112's 4-axis SFX-100 build
Discussion in 'DIY Motion Simulator Projects' started by diablo2112, Jul 2, 2019.
  1. Extremier
    Extremier New Member
    245Coins
    Motion platform
    Congratulations !!! This is a fantastic Master Peace !!!
    Really got me ...I´m really consider myself a SFX 100 project.
  2. Evgeny Bukan
    Evgeny Bukan New Member
    103Coins
    can you share the stl files with the modification you did for cnc machine? thanks
  3. Luka Usenicnik
    Luka Usenicnik New Member
    Mechanical Engineer
    Slovenia
    131Coins
    Yes ofcourse
  4. Evgeny Bukan
    103Coins
    did you make any modifications to the shaft as well, considering the linear bearing is inside the bottom cover?
  5. Evgeny Bukan
    103Coins
    also can you share any price quotes for the cnc procedure?
  6. Luka Usenicnik
    Mechanical Engineer
    Slovenia
    131Coins
    Not the shaft but the slider
  7. Luka Usenicnik
    Mechanical Engineer
    Slovenia
    131Coins
    price for the CNC parts is 400€ :)
  8. Evgeny Bukan
    103Coins
    thanks for the info. very useful for making my decision. by the way, the actuator looks way cooler with the alu parts on it. nice work!
  9. Luka Usenicnik
    Mechanical Engineer
    Slovenia
    131Coins
    Thank you!
  10. diablo2112
    diablo2112 Member
    USA
    662Coins
    2DOF, Motion platform, 4DOF
    Edit: damn. Photobucket has changed owners. The "new and improved" photobucket is a $6/month rip off now. Sorry. I have to find another image hosting service.
  11. Sebj
    Sebj Active Member
    Canada
    492Coins
    Woops ^^^^^
  12. dennis johnson
    dennis johnson Member
    retired
    Ft Mill, SC 29707
    138Coins
    3DOF, AC motor
    Howdy,
    I am just getting started with my project. I have all the parts on order and am starting to learn my new Ender 3 printer. I think my extrusions are here in the USA. No word on the China parts yet. It may be awhile before any of that happens.
    My current rig is a GT1 EVO with a NLRV3. I did order the Thanos 6dof board. So I am interested in how its going with the two of them working together. With that being said, would you share your simtools and platform manager settings with me? And clue me in on any problems or software conflicts etc to watch out for?
    you are one of the main reasons that I jumped on the sfx bandwagon, although my timing might not have been the most appropriate....lol
    thanks for sharing your build..
  13. diablo2112
    diablo2112 Member
    USA
    662Coins
    Congrats! I find the v3 and 4-actuator setup works brillantly together. I posted Simtools settings earlier in this thread. I need to update those, as the new "spike" filter on the Thanos controller changes everything. In sum, raise the intensithy to 100 in Simtools (not 99 as I showed), put all forces at "0" in the game manager (up from a range of -30 to 0); and setup the spike filter at a level of 3000 on the controller, and the smoothing filter at either 1 or 0, to your taste. All other settings as I show earlier in this thread. I find this setting fantastic. Incredible detail, but doesn't go crazy on crashes/off track.
    As for v3 settings, I dial that back about 50% compared to what I previously used. I'll try to find detailed settings and post them up a bit later.
  14. Heist18
    Heist18 New Member
    163Coins
    3DOF, Arduino
    First of all, really loved the way you set up your rig... compact and looks great and rigid. Do you mind if I copy your dimensions? I too am building the SFX100 and planning to just strap it onto al profile rig ...
    Can share the length and breath of the 4080 profile you use as the base frame?
  15. Chipless
    Chipless Member
    152Coins
    Thank you for the great update and suggestions! Plan to use these with AMS2. Which smoothing filter do you prefer?
  16. tomkil192
    tomkil192 Member
    Uk. London
    - 25Coins
    Great project.
    I will create one time once i finish my 1st version :)
    Can you tell me what seat do you use? is it comfortable?
    I am quite tall and my sparco seat is not suitable for me 6'2''
  17. diablo2112
    diablo2112 Member
    USA
    662Coins
    I've gone back to triple screens. Here's a few pics and a short video.
    • Winner Winner x 3
  18. Sebj
    Sebj Active Member
    Canada
    492Coins
    Why did you go back? What VR headset did you run?
  19. jdmkun
    jdmkun New Member
    6Coins
    Motion platform, 6DOF
    Wow, you really raise the bar--impressive! Awesome job! Can you share the dimensions and also what hardware you used to connect the NextLevelRacing seat to the platform? I'm considering building a motion platform with both the SFX100 and the NLV V3, but for flight sim. Have you tried it out with any of the flight sims?
  20. Billel
    Billel Member
    195Coins
    Hello diablo,
    Are those stepper motors on the acuators ?
