new 2DoF SCN5 build
Discussion in 'DIY Motion Simulator Projects' started by dirigible, Oct 8, 2021.
  1. dirigible
    dirigible Member
    Ontario, Canada
    137Coins
    2DOF, SCN5
    Re: 3D printing an enclosure... unfortunately I don't have access to a 3D printer. I've been waffling on getting one for a long time, but honestly I don't need one often enough to justify it. That being said, I found an old, compact desktop PC in my garage that is just collecting dust. I think I'm going to gut it and use the case for my enclosure.
  2. hideki
    hideki Active Member
    Spain
    - 208Coins
    2DOF, SCN5
    Man, there must be many 3D printer services that might do that piece for you, but that case you found will work more than ok.
    At the end I didnt see those bumpers ;).
    Another thing. Be careful when you seat, do it gently and not in the border of the seat. Those SCN5 have a "pin" that connects the rod to the motor and it breaks easyly and its hard to repair (not imposible).
    keep posting fotos if you feel like
  3. dirigible
    dirigible Member
    Ontario, Canada
    137Coins
    2DOF, SCN5
    When I put leverage on the seat in one direction or another, it extends/retracts the corresponding SCN5 rods manually. Is this bad for the actuators? Will they calibrate automatically when power is applied?
  4. hideki
    Spain
    - 208Coins
    2DOF, SCN5
    When there is no power you can move them manually, no problem with that.
    Simtools will extend them to the maximum and minimum and then stop in the middle.
    Try no to seat when there is no power and be gentle when there is. If you seat fast those pins can break.
  5. dirigible
    dirigible Member
    Ontario, Canada
    137Coins
    2DOF, SCN5
    I'm pleased to announce that my sim is up and running in Live for Speed! I'm using the default profile for the actuators as shown in the SimTools manual (surge & sway @ 50%) and it seems very muddy. It's jerky motion, almost as though the actuators are working against eachother at times. I'm going to spend some time tweaking over the next few days and see what I can figure out on my own, but I suspect I'm going to need some assistance with this. There seem to be a variety of locations to configure motion profiles, and I'm not sure how they differ from one another.
    To clarify, this is a 2DoF simulator, so I can assign only 2 dimensions in the Axis Assignments? The software takes care of combining these forces to move the seat diagonally?
    152,541Coins
    +11,086 / 56 / -2
    The first thing to do is grab a copy of the SimTools manual and keep it handy for reference: https://www.xsimulator.net/community/faq/rtfm-start-with-the-official-simtools-documentation.117/
    Then check out the these motion profile tuning tips in the FAQs: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
    While you only have 2DOF you can simulate some extra axis, like heave and surge, which greatly enhances the experience. So you should use and configure sway, surge, roll, pitch and heave.
  7. dirigible
    dirigible Member
    Ontario, Canada
    137Coins
    2DOF, SCN5
    Thanks! Yes, I've been working with the manual, but it doesn't do a good job of explaining how the Axis Assignment functions work. I've been able to get a much smoother function using one of the presets as opposed to manually just setting Sway/Surge. It's a better starting point.
  8. dirigible
    dirigible Member
    Ontario, Canada
    137Coins
    2DOF, SCN5
    I'm jumping the gun a little here, but I'm already looking ahead to adding traction loss. How far in an arc does the seat have to travel for the driver to feel traction loss?
    152,541Coins
    +11,086 / 56 / -2
    See the FAQs here, average is somewhere in the range of 200-300mm total: https://www.xsimulator.net/community/faq/traction-loss.174/
  10. dirigible
    dirigible Member
    Ontario, Canada
    137Coins
    2DOF, SCN5
    I think my rig is complete, with the exception of some monitor placement tweaking, cable management and an H-pattern shifter that I just ordered (which will clamp to the rails on the base that support the steering frame). I covered the base with vinyl-backed utility carpet, and this makes it very comfortable and less DIY-feeling. I've got Live for Speed running well, and I'm just starting to set up Assetto Corsa. I'm also looking forward to trying No Limits 2 with my Oculus Quest 2.
  11. hideki
    Spain
    - 208Coins
    2DOF, SCN5
    nice but try to place the the motors in a diagonal just changing the rod ends connection: on top (seat structure) in the inside, on the botton (rig structure) in the outside. Yours motors are completelly parallel. Take a look at the simxperience rigs much wider at the botton that the rest o brands (Frex etc) Sorry my English is not good enough to explain that better...
  12. dirigible
    dirigible Member
    Ontario, Canada
    137Coins
    2DOF, SCN5
    It may be hard to see in the pbotos, but the SCN5s are at about a 10 degree angle outward from the seat to the base (the recommended range is 10-15 deg). Flipping the mount puts the angle just above 15 deg. I've tried it both ways, and you're right, the increased angle feels a little (but not much) better.
