AMC-AASD15A servo controller
Discussion in 'SimTools compatible interfaces' started by Thanos, Nov 6, 2019.
  1. VTD
    VTD New Member
    49Coins
    HI Thanos,
    Is it possible to power multiple Servo drivers from one power socket? For example bridging two drivers?
    Or is one powersocket + EMI filter required for each of the servo drivers?
    Greetings
  2. cfischer
    Colorado
    2,789Coins
    One plug and filter for all drivers is the way to go.
  3. Dirty
    All the way up front.
    7,964Coins
    In my case (6x1000W) it was theoretically possible for the six motors together to trip the 3800W breaker, but since they will normally never draw the max current all at the same time in reality it was OK to supply them all from a single line (240V, 16A).
    There is however a reason to at least allow for them to be switched individually: When I switched all six controllers simultaneously over a single switch, there was a short initial draw of current that tripped the breaker every time. Switching them on one-by-one, even within just 2 seconds worked fine.
    So, in my experience I'd say you can supply all six from a single line, but you should still be able to switch them individually.
    Cheers,... :)
  4. cfischer
    Colorado
    2,789Coins
    This is an interesting observation. In my experience I have 14 servos on one 10a breaker and it only occasionally trips the breaker when I switch them all on at once (via a contactor) and never in use. Most of the drives are AASD15A but 4 of them are AASD20A. I wonder what the big difference is between our setups.
  5. VTD
    VTD New Member
    49Coins
    So if i would wire the power like this it would be fine? Obviously this is w/o the line filter and actuators connected.
  6. Dirty
    7,964Coins
    I assume there are capacitors that are being charged when you switch on the drives. I am using 6 AASD20A. Maybe these have different capacitors...
  7. cfischer
    Colorado
    2,789Coins
    If you look in the manual and the general consensus it would be wise to put a breaker in between the drives and the plug. But yes what you drew will work.
    If you're worried about what size breaker just put a 10a on there. I had a 15a on mine and was curious if I put a ten on instead, if it would trip. As a mentioned above, it only trips when first turned on, and only sometimes.
  8. Tancop24
    Tancop24 New Member
    - 17Coins
    Hi, I just finished my first actuator and had issue in Output Testing in SimTools. Actuator is not responding when I moved the slider. Here's some pictures attached and sorry I'm new to this and just building my actuators.
    Anyone can help me much appreciated. Thanks
  9. Thanos
    Electronics Engineer
    2,871Coins
    Hi, did you see the instructions in the manual? It could be the language system locale issue. Or missing FTDI drivers..
    https://github.com/tronicgr/AMC-AAS...5A_4DOF+TL+Surge-SRS-Simtools_manual_v2_6.pdf
  10. Tancop24
    Tancop24 New Member
    - 17Coins
    Hi thanks for your reply, I found out that my servo motor still in jog mode, after changing this every things works fine.
  11. VTD
    VTD New Member
    49Coins
    Sorry for the late reply.
    But a breaker like this will be fine? https://elektronica-online.nl/product/automatische-zekering-10a-15604
    It breaks at 10 amps
    Max voltage AC 240V
    Max voltage DC 48V
    Or do i need a breaker more like this one?
    https://www.elektramat.nl/emat-inst...MIopyIlem_9AIViP93Ch1_tAQsEAQYASABEgLg0vD_BwE
    Or is a 15 amps breaker more recommended?
  12. Thanos
    2,871Coins
    The second link with the 16A breaker is fine, no need to find exactly 15A, the fuses standards change from country to country.
    Thanos
  13. Petertje
    Petertje “Engineering changes the world.” —Isaac Asimov
    Mechanical engineer / battery specialist
    The Netherlands
    447Coins
    I used a 20ohm 10A thermistor in line with the 230VAC as surge protector. Never a tripped fuse again.
  14. Thanos
    2,871Coins
    Hey guys! The new Thanos4U servo controller is here:
  15. Thanos
    2,871Coins
  16. cfischer
    Colorado
    2,789Coins
    Wow simracingstudio must be really taking off then huh?
  17. Thanos
    2,871Coins
    I wouldn't put it in the category that is the best, just each software has its advantages.
    Simracingstudio just tends to be more plug and play with minimal tuning, and automated tasks. But you have less access to fiddle around. Much of it is blackboxed and is trying to give easy access to the gamer that jumped to PC from consoles. Just power on and play. Also less headaches for the user and for us too as less troubleshooting is needed.
    See this video where the difference between software is explained a bit from the user perspective (around minute 28:08):
    Also a later video of his where he shows the tuning steps with simracingstudio:
  18. VTD
    VTD New Member
    49Coins
    I just installed the servo drives on my motion rig and it only displays '0'. I tested the servo's with the actuators before installing a few weeks ago and it just worked fine. Is anyone known with this issue?
  19. Thanos
    2,871Coins
    The screen does not display the "X" or "!" or "C" symbols for each servo, something is not right, you should be able to hot plug and detect each actuator and see the state of that actuator on the LCD:
    I'd suggest do a factory restore of the parameters on the AMC controller using EXIT + RESET procedure. See the manual how: https://github.com/tronicgr/AMC-AAS...5A_4DOF+TL+Surge-SRS-Simtools_manual_v2_6.pdf
    Then leave it set to 6 actuators, and just set correct leadscrew and stroke for the actuators...
    Make sure you also have the latest firmware, if not, a update it according to the instructions here:
    https://github.com/tronicgr/AMC-AASD15A-Firmware/tree/master/Latest_firmware
    Thanos
  20. Mat_Menzies
    Mat_Menzies New Member
    92Coins
    Hi cfischer, Dirty, the difference may to be in the type of cct breaker used. There is a range of breaker styles, often referred to as "curves" available that are intended to cater for this kind of scenario, here is a wikipedia explanation:
    https://en.wikipedia.org/wiki/Circuit_breaker#Standard_current_ratings
    From my readings, C curve breakers are readily available from local electrical outlets and should be quite suitable for our type of application.
