F1 2021 2021-09-08
SimTools plugin for Codemasters F1 2021
  1. Rongchen
    Rongchen New Member
    67Coins
    I never play my team mode hence I have no idea if it works or not.
    I use this F1 2021 plugin. What I meant was I applied the same method as taught in the F1 2020 plugin discussion except for deleting the whole line in the SimHubWPF.exe file.
    cheers
  2. danone38
    danone38 New Member
    - 291Coins
    Hello
    It would be nice to give the exact user manual to have simhub and simtools together because I can't.
    I have tried all the possibilities.
    thank you
  3. ivan jack
    ivan jack Member
    412Coins
    The solution is in this Discussion at page 2 posted by Petemnz. Use F1 2018 from simhub for port forwarding. Both simhub and simtools will work.
  4. offman
    offman New Member
    10Coins
    Hello, Use F1 2018 in simhub ? I don't understand...For f1 2021 ??? Sorry for this question...
  5. ivan jack
    ivan jack Member
    412Coins
    Yes, because F1 2021 from simhub Doesn't have 2018 support telemetry. Simtools plugin works on 2018 telemetry so that's why you need to pair it with F1 2018 from sinhub.
  6. offman
    offman New Member
    10Coins
    thanks for the reply. However, sorry if i am a little silly ... i dont know exactly what that means i need to install f1 2018? I don't understand what to do in simhub How to play f1 2021 by configuring f1 2018 on simhub? sorry to bother you, but I dream of having the solution.Thank you for your patience
  7. VTD
    VTD New Member
    49Coins
    If you use UDP 2018 data in f1 2021, than use f1 2018 in simhub. The f1 2018 in simhub is using the 2018 udp data if i remember correctly
  8. offman
    offman New Member
    10Coins
    ok, but i don't understand how i can play f1 2021 if the game in simhub is f1 2018..really i don't understand ... if i put F1 2018 i will necessarily play f1 2018 ... when can i be in f1 2021?
  9. VTD
    VTD New Member
    49Coins
    Hi offman,
    Sorry for the late reply.
    I you want to use simhub and simtools togetter while playing f1 2021, you need to adjust the telemetry settings in f1 2021. Since the simtools f1 2021 plugin requirers 2018 UDP data you need to enable 2018 UDP telemetry data within the f1 2021 settings.
    Because you are sending 2018 udp data from the f1 2021 game, you only can use the f1 2018 settings in simhub.
    F1 2021 game UDP 2018 data --> Simhub f1 2018 plugin
    From the Simhub f1 2018 plugin you can forward the data to other diveces.
    I hope this helps
  10. William Walker
    William Walker New Member
    - 84Coins
    I have tried everything and mine still doesn’t work any ideas
    thanks
  11. hideki
    hideki Active Member
    Spain
    - 208Coins
    2DOF, SCN5
    It works as they say. Simhub 2018 and forward it. Also change it in F1 2021 Telemetry from 2021 to 2018
    Many thanks guys I like it a lot...
      18.3 KB
      359
  12. hideki
    Spain
    - 208Coins
    2DOF, SCN5
    IMPORTANT My Simhub detects that I am playing F1 2021 and connects to it in the midle of the game so I had to install an old Simhub version with no F1 2021 support to make it work with no problems, In the Games window of SimHub click once on F1 2018 it will turn blue and it wont move from there, New versions will go back to 2021 window so it stops "listening" the game. Maybe I am doing something wrong but this is ok to me and the plugin is really good for my liking
  13. offman
    offman New Member
    10Coins
    thank you very very very much !!!!!!!!!!!! it's work fine !!!!
  14. AlbertoMoralo15
    AlbertoMoralo15 New Member Gold Contributor
    - 21Coins
    Hello, any update on when are we going to have the F1 22 plugin?
    Thanks beforehand
    152,541Coins
    +11,085 / 56 / -2
  16. AlbertoMoralo15
    - 21Coins
  17. yobuddy
    51,186Coins
    If your sim works with v2, it will work in v3 for sure. :thumbs
    And the public beta for v3 is being worked on right now, and I even have a test f1 2002 plugin is a testers hands.
    Chat soon,
  18. offman
    offman New Member
    10Coins
    a test f1 2002 plugin ? It's a very old plugin model...;)
  19. yobuddy
    51,186Coins
    lol 2022 I mean...
  20. lupotto
    lupotto New Member
    - 120Coins
    Can i use the f1 2021 plugin for f1 22?
