Dirt Rally 2 Plugin v2.3
SimTools plugin for Codemasters Dirt Rally2
  1. Manes
    Manes Member
    179Coins
    i try to put this lines but don´t save the configuration. I try whit wordpad and block note. I need some app to change that?
    153,691Coins
    Go to Documents\My Games\DiRT Rally 2.0\hardwaresettingsv
    Find the file hardware_settings_config_vr, right click on it and choose to open it with Notepad, you can then follow @Daguru's suggestion and copy and past the suggested section into the hardware_settings_config_vr, then save the hardware_settings_config_vr file in Notepad.
  3. Manes
    Manes Member
    179Coins
    I am doing that but when I save the configuration, I enter in the game, start to drive, I don´t have motion, and when I go again to the archive hardwaresettingsv, i don´t have the configuration saved.... Have you got any idea?
  4. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    @Manes this is mine you might have to change settings with in the game to suite you etc but backup your file and try this
  5. Manes
    Manes Member
    179Coins
    Yeah man!! It's working now!! It change graffics and some things but i only need reconfigurate. Many thanks bro.
  6. ROBERTO PAGLIA
    ROBERTO PAGLIA New Member
    8Coins
    Good evenig sorry the Dirtrally 2.0 pluginno longer works what could it be thanks...I don't know if l wrote in theright section
  7. Manes
    Manes Member
    179Coins
    Yes it's working. I play today
  8. ROBERTO PAGLIA
    8Coins
    The game manager connected is blue but startimg the game does not makeany movement
  9. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    Got any pictures of your settings also was it working before and if yes what have you changed?
  10. ROBERTO PAGLIA
    8Coins
    now it works thank you very much
  11. ROBERTO PAGLIA
    8Coins
    i reinstalled the pluging
  12. Anthony atallah
    Anthony atallah Member
    Mechanical Engineer
    Lebanon
    107Coins
    Hello
    I did read most of this thread and tried some solutions without success.
    Does anybody know what's the the latest fix?
    Can't get data in game tuning.
  13. Anthony atallah
    Mechanical Engineer
    Lebanon
    107Coins
    Also when the game starts I hear the same beep like when we can't turn on the motor in the game manager to test the output.
  14. yobuddy
    51,518Coins
    That sounds like your interface crashing.
    I would check for loose connections and maybe try a different usb cable.
    Take care,
  15. Anthony atallah
    Mechanical Engineer
    Lebanon
    107Coins
    Output testing and LFS works
  16. Emanuele Apollo
    Emanuele Apollo New Member
    - 63Coins
    hello guys,
    I'm new with simtools but i think i understand that pitch,roll and heave are for the road and yaw, sway and surge are for the car...i have prosimu t1000 3dof with prs200, do you have any suggestion for pitch,roll and heave?
    153,691Coins
    Grab a copy of the SimTools manual and keep it handy for reference: https://www.xsimulator.net/community/faq/rtfm-start-with-the-official-simtools-documentation.117/
    Then see the FAQ motion profile tuning tips: https://www.xsimulator.net/community/faq/tuning-centre-and-axis-settings.240/
  18. SteULM
    SteULM Active Member
    601Coins
    Hello everyone, yesterday I installed DirtRally2.0 and from that moment my problems started ..... I read all the pages of this thread and tried everything, I got to the point that the telemetry data on the tuning center there are but the rig does not move. I finished a race, I quit the game, I patched and nothing moved and there was no telemetry data either, so following the various posts I changed the lines of the hardware_settings_config.xml file and the data arrived but no movement. Can I check anything else ??
    These are the lines of the modified xml file:
    <motion_platform>
    <dbox enabled="true" />
    <udp enabled="true" extradata="3" ip="127.0.0.1" port="4123" delay="1" />
    <custom_udp enabled="true" filename="SimToolsCustomUDP.xml" ip="127.0.0.1" port="4123" delay="1" />
    <fanatec enabled="false" pedalVibrationScale="1.0" wheelVibrationScale="1.0" ledTrueForGearsFalseForSpeed="true" />
    </motion_platform>
    153,691Coins
    The game data is there in the Tuning Center, so this is likely a settings issue.
    It would be helpful to include a picture of your Axis Assignments.
    See the tips in the FAQs about refining a motion profile, in particular take note of capturing the Max/Min values in the Tuning Center and then tweaking from there: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  20. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    My best guess is max and min numbers too high:thumbs
