Showroom IL2 Sim on 2 Dof
Discussion in 'DIY Motion Simulator Projects' started by xmcnodx, Nov 30, 2021.
  1. xmcnodx
    xmcnodx IL2 Sim with 2Dof
    Schmelzer
    Zirndorf Deutschland
    94Coins
  2. Skuldi
    Skuldi Member Gold Contributor
    Germany NRW
    265Coins
    I really wonder how good your motors support each other with that position.
    I also thing that your levers are to long for that motors. I have two holes in my lever. one at 4cm away from the shaft (for racing) and one at 6 cm (for flying). I use two 370w motors.
    151,467Coins
    +11,041 / 56 / -2
    The placement of the roll motor means it has very little inherent design leverage and far less than the pitch axis, wiper motors are not very powerful so you need as much inherent design leverage as possible within space constraints. In other words the further the motors are from the pivot the better, which is why shoulder mount design is popular for wiper motors, as it gives the maximum inherent design leverage.
    The lever CTC length is likely too big, as per previous advice. At a guess try 40mm.
    151,467Coins
    +11,041 / 56 / -2
    CTC = Center To Center, the distance measured from the motor shaft center to the center of the hole drilled for the connecting rod on the lever.
  5. xmcnodx
    Schmelzer
    94Coins
    Sorry it took longer would have to wait for material
    as a bracket here in Germany was not to buy I was forced to build it myself of course with high priced tools LOL
  6. xmcnodx
    Schmelzer
    94Coins
    This is the original part I rebuilt
  7. xmcnodx
    Schmelzer
    94Coins
    Help
    I have the problem that the motors turn without me wanting it is not in the game or in SMC3 test
  8. xmcnodx
    Schmelzer
    94Coins
    an engine does everything it is supposed to do in the game
    the other turns completely in one direction and goes into emergency shutdown, but i pull it then
    151,467Coins
    +11,041 / 56 / -2
  10. Skuldi
    Germany NRW
    265Coins
    swap + and - on that motor
  11. xmcnodx
    Schmelzer
    94Coins
    these are the settings what i have
  12. xmcnodx
    Schmelzer
    94Coins
    @Skuldi
    changing + and - also helped
  13. noorbeast
    151,467Coins
    +11,041 / 56 / -2
    Leave the intensity level at 100%.
    Does everything work as expected in Output Testing?
    What are your Tuning Center settings?
  14. xmcnodx
    Schmelzer
    94Coins
    Since I swapped + and - the sim has been working and could test a round LFS
  15. xmcnodx
    Schmelzer
    94Coins
    finally i can report a success my first test after rebuild has been successful the wiper motors are strong enough to move me and thanks to @noorbeast with his advice to set the intensity to 100 and to @Skuldi to change the polarity i can finally move on
    THANK YOU THANK YOU is all I can say
  16. xmcnodx
    Schmelzer
    94Coins
    help how can i
    download the puling package I bought the licence
    151,467Coins
    +11,041 / 56 / -2
    Use 250 of your forum activity coins here, which will give you a week access to download as many plugins as you want, and those will continue to work as long as game updates do not break them: https://www.xsimulator.net/community/shop/
  18. xmcnodx
    Schmelzer
    94Coins
    thanks it worked, pictures will be coming soon and I'll try to add a video.
  19. xmcnodx
    Schmelzer
    94Coins
    Help Sim does not work[​IMG]
    151,467Coins
    +11,041 / 56 / -2
    What are your Axis Assignments and did it patch successfully?
