2 DOF motion rig using 4 wiper motors & Arduino
Discussion in 'DIY Motion Simulator Projects' started by Captain Jack, Nov 20, 2021.
  1. Captain Jack
    Captain Jack Member
    - 26Coins
    Some of the parts were printed solid (100% infill) like the motor arms, but most parts are 50% infill. PLA strength is not an issue if the part design takes into account less strength between layers than in the other directions.
    I found PLA better than ABS actually - similar strength in practice as PLA doesn't develop cracks over time like ABS does.
    The only thing to be careful with is temperature. PLA gets soft above 50C
  2. Captain Jack
    Captain Jack Member
    - 26Coins
    It's finally finished! I've just done a couple laps on the Nurburgring :D
    Here's the solution for the belt tensioner:
    This system of pulleys doubles the motion of the belt - both the belt and the attachment point get pulled at the same time. They obviously move in the same direction so the pulleys at the bottom reverse the motion, resulting in 2x motion.
    The belt system went from "not worth the effort" to "quite good". I'd still like it to tighten more, but this probably the best you can get without an electric tensioner. I'm happy.
  3. itsumairu
    itsumairu Active Member
    Psychologist
    Indonesia
    440Coins
    a video would be nice. I'd like to see how it works.
  4. Keith
    Keith Active Member
    Electrician
    Canada, Saskatchewan
    154Coins
    Nice build and nice 3d prints! It's amazing what you can do with PLA, very underrated. I might have to try out your seat belt tensioner idea.
  5. Captain Jack
    Captain Jack Member
    - 26Coins
    Here's a video of the rig:
    153,764Coins
    +11,149 / 57 / -2
    Nice job :thumbs
    What fans and control board are you using for wind simulation? The folding mount is really neat.
  7. itsumairu
    Psychologist
    Indonesia
    440Coins
    the belt mechanism is really a great idea!
    can't wait to replicate what you did, when I have time.
  8. Captain Jack
    Captain Jack Member
    - 26Coins
    I'm using an Arduino board & SimHub. The fans are Delta FFB1212SH controlled with PWM through SimHub.
  9. Anthony atallah
    Anthony atallah Member
    Mechanical Engineer
    Lebanon
    107Coins
    Cool and clean setup!
    What kind of motor cooling you're using?
  10. Anthony atallah
    Mechanical Engineer
    Lebanon
    107Coins
    Got the answer on the first page hehe.
    May I suggest connecting the structure of each couple of motors to each other, it will eliminate a bit of vibrations and strengthen to motor holder.
  11. Captain Jack
    Captain Jack Member
    - 26Coins
    60mm PC cooling fans :p
    Thanks for the suggestion. I might add a brace at some point
  12. JacquesSakkie
    JacquesSakkie Passionate about life.
    Automation Engineer
    Netherlands
    71Coins
    Very nicely done. Never thought of doing hall senders. Will try that. Just a question, why 4 motors?
  13. JacquesSakkie
    Automation Engineer
    Netherlands
    71Coins
    This is a very nice build. Very tricky question. Will you be willing to share the design for the motor bracket? Best I have seen so far.
