Dimensions of a 2DOF motion platform for SimCalc
Discussion in 'DIY Motion Simulator Projects' started by imajavaid, Nov 16, 2021.
  1. imajavaid
    imajavaid Member
    169Coins
    Yes exactly that's happening. As the green line of the potentiometer intersects the blue line. The motor changes its direction. This means I'm going in the right direction?
  2. SteULM
    SteULM Active Member
    601Coins
    Yes, when you install the potentiometer that is moved by the motor in that case it would stop.
  3. Halloween2go
    Halloween2go Active Member Gold Contributor
    1,395Coins
    The power supply or battery should connect to the IBT2 +- on the green connector. The motor also connects to the MM on the green connector on the IBT-2. The IBT2 will control the motor. DMAX
  4. imajavaid
    imajavaid Member
    169Coins
    Is there any guide to understand the background working of smc3
    153,697Coins
  6. imajavaid
    imajavaid Member
    169Coins
    Sharing my progress from the last two weeks.
    Base mount and chair mount
    WhatsApp Image 2022-03-07 at 10.38.18 AM (1).jpeg WhatsApp Image 2022-03-07 at 10.38.18 AM (1).jpeg WhatsApp Image 2022-03-07 at 10.37.46 AM (1).jpeg WhatsApp Image 2022-03-07 at 10.37.46 AM (4).jpeg WhatsApp Image 2022-03-07 at 10.38.14 AM (3).jpeg WhatsApp Image 2022-03-07 at 10.38.18 AM (2).jpeg WhatsApp Image 2022-03-07 at 10.38.18 AM (1).jpeg WhatsApp Image 2022-03-07 at 10.37.46 AM (1).jpeg WhatsApp Image 2022-03-07 at 10.37.46 AM (4).jpeg WhatsApp Image 2022-03-07 at 10.38.14 AM (3).jpeg WhatsApp Image 2022-03-07 at 10.38.18 AM (2).jpeg
  7. imajavaid
    imajavaid Member
    169Coins
    CTC lever
  8. imajavaid
    imajavaid Member
    169Coins
    Motor shaft
  9. imajavaid
    imajavaid Member
    169Coins
    Integration of swivel joint, motor shaft, motor
    and Connecting upper frame to swivel joint
  10. imajavaid
    imajavaid Member
    169Coins
    Universal joint
  11. imajavaid
    imajavaid Member
    169Coins
    Integration of lower and upper frame
  12. imajavaid
    imajavaid Member
    169Coins
    Connecting hall sensor to shaft of the motor
  13. imajavaid
    imajavaid Member
    169Coins
    I have attached foot rest to the upper frame so that the user feet should not touch the ground.
    Hoping to get a more realistic experience
  14. imajavaid
    imajavaid Member
    169Coins
    A complete integrated motion platform
  15. imajavaid
    imajavaid Member
    169Coins
  16. imajavaid
    imajavaid Member
    169Coins
    Going to attach seat now
  17. imajavaid
    imajavaid Member
    169Coins
    Thanks to @noorbeast @Halloween2go @SteULM @jambone1963 @itsumairu for guiding me till this phase. Really appreciate your kind time. It could have not been possible without your kind assistance.hug::thumbs
    And I will keep disturbing you in the future. Please don't mind for that:D;):grin:sos
  18. noorbeast
    153,697Coins
    Nice work :thumbs
    Have you hooked up the electronics and tested it under load?
  19. imajavaid
    imajavaid Member
    169Coins
    Thanks. It's still in progress. I will try to complete it by thus weekend
  20. imajavaid
    imajavaid Member
    169Coins
    I have defined mode 2 in arduino and set com port to 4 as of arduino adn it is also showing in smc3. But why the motors are showing turn off status. I clicked on it but they are not turning on. I also have rechecked the circuit diagram
