F1 style 2 DOF | Mantis Simulators FS2
Discussion in 'Commercial Simulators and Peripherie' started by early_m, Apr 25, 2021.
  1. early_m
    early_m Active Member
    Chelmsford
    819Coins
    Updated the rig to an Ali frame - huge improvement in rigidity. Also repositioned the motors for more mechanical advantage and the overall movement is much improved. Also swapped out the ibt2's for a sabertooth 2x32.
  2. ets23
    ets23 New Member
    16Coins
    very nice project.. can I ask you where did you find the motors? I can't find them anywhere
  3. Kenshiro27
    Kenshiro27 Active Member
    70Coins
    Great job
    the sensations seem to be there
    • Optimistic Optimistic x 1
  4. early_m
    Chelmsford
    819Coins
    Slight design change with mods to wind sim due to DD upgrade (after running a G27 for about 6 years).
  5. itsumairu
    itsumairu Active Member
    Psychologist
    Indonesia
    440Coins
    your build is one of my inspiration.
    Can you kindly share the dimensions of your 2 dof sim? I really want to know.
    Thx in advance!
  6. Kenshiro27
    70Coins
    Very good choice
    I also have the same Fanatec set up
    If you can find a used V3 crankset you'll be on top
    Is your ventilation system really good? I hesitate to make one
  7. early_m
    Chelmsford
    819Coins
    Pedal upgrade is on the cards. I have the truebrake mod fitted to these G27 pedals which I really like, so in no hurry. Wind sim is hands down one of the best immersion boosters, especially in vr, and it's cheap to do, about £25
  8. Kenshiro27
    70Coins
    indeed not expensive. Do you have a link or you could give me or some explanations on your installation please. Your photo and your comment makes me want to try
  9. early_m
    Chelmsford
    819Coins
  10. Kenshiro27
    70Coins
    thank you early_m
  11. Michail
    Michail Member Gold Contributor
    717Coins
    Can you explain how you screw the ujoint with the base?
    I have issues, it loose and rotate the whole rig.
    Can you share please your simtools settings and for the plugin? THX
  12. early_m
    Chelmsford
    819Coins
    When it was a wooden rig I used long m10 coach screws, but I still had some play like you are showing
  13. Michail
    717Coins
    Thank you for your information. I consider to make the base in Aluminium or steal.
    May you can share screenshots of your axis settings in simtools? And which game you play in your video? F1 from codemasters or assetto Corsa with F1 hybrid mod? I Racing or something else? I really like the acceleration and break motions of your rig. And looking forward to achieve this motion to, so pleas share your settings. Thx
    • Old Old x 1
  14. Imran
    Imran New Member
    56Coins
    Can you please say all the components you did use. If not say which motor you used
  15. Imran
    Imran New Member
    56Coins
    What is the purpose of that small motor attached with the big gear motor?
    I find out such a motor in our region
  16. noorbeast
    151,991Coins
    +11,061 / 56 / -2
  17. Imran
    Imran New Member
    56Coins
  18. Imran
    Imran New Member
    56Coins
    151,991Coins
    +11,061 / 56 / -2
    Spend some time in the FAQs, it is a great place to find answers to common questions: https://www.xsimulator.net/community/faq/fundamentals-of-motion-control-electronics.23/category
    You can also find out more about motor driver options and differences, such as Sabetooth being capable of high voltage: https://www.xsimulator.net/community/faq/motor-drivers.11/category
  20. Imran
    Imran New Member
    56Coins
