Dirt Rally 2 Plugin v2.3
SimTools plugin for Codemasters Dirt Rally2
  1. SteULM
    SteULM Active Member
    600Coins
    I recorded the data with capture settings and this is the data it recorded me in the cfg file:
    <?xml version="1.0" encoding="utf-16"?>
    <GameMaxMin xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
    <_GameName>DirtRally2</_GameName>
    <_RollMax>10445.7507907062</_RollMax>
    <_RollMin>-10445.7507907062</_RollMin>
    <_PitchMax>8742.0310269309</_PitchMax>
    <_PitchMin>-8742.0310269309</_PitchMin>
    <_HeaveMax>3510.07470703125</_HeaveMax>
    <_HeaveMin>-3510.07470703125</_HeaveMin>
    <_YawMax>180</_YawMax>
    <_YawMin>-180</_YawMin>
    <_SwayMax>4509.34423828125</_SwayMax>
    <_SwayMin>-4509.34423828125</_SwayMin>
    <_SurgeMax>1643.21862792969</_SurgeMax>
    <_SurgeMin>-1643.21862792969</_SurgeMin>
    <_Extra1Max>5688.89306640625</_Extra1Max>
    <_Extra1Min>-5688.89306640625</_Extra1Min>
    <_Extra2Max>180</_Extra2Max>
    <_Extra2Min>-180</_Extra2Min>
    <_Extra3Max>0</_Extra3Max>
    <_Extra3Min>0</_Extra3Min>
    </GameMaxMin>
    I performed the same procedures I did with the other games but with this one I'm having a lot of difficulties, Game Engine often closes while I'm running ...
  2. SteULM
    600Coins
    This is the axis setup, I'm only using Sway, Surge and Heave
  3. SteULM
    600Coins
    I tried to see the information in virtual axis and there is something that does not convince me. The movements seem imperceptible. Now I make a video and show it to you.
  4. SteULM
    600Coins
    151,991Coins
    +11,061 / 56 / -2
    The Tuning Center values are way too big.
  6. SteULM
    600Coins
    They are the ones that Capture registered me
  7. SteULM
    600Coins
    I reinstalled the plugin but it still doesn't work
    151,991Coins
    +11,061 / 56 / -2
  9. SteULM
    600Coins
    I had tried but without results, now I have uninstalled everything and I'm starting again, first I set the Region to United States ...
  10. SteULM
    600Coins
    YES !!! hug:
    Now everything works, surely the capture values were high due to the wrong setting of the windows region. Thanks for everyone's continued help, what a spectacular forum !!!!!
    :cheers:thumbs
  11. Andreawrc83
    Andreawrc83 Andywrc Gold Contributor
    commerciante
    italia
    73Coins
    Good morning
    I've a problem with dirt rally 2 plugin.
    I post photo, but my motors go only in one direction, when i move manual the motors with the option in output simtool, roll move only on the left, on the right don't move the motor, pitch on the left move the left motor down and on the right move the right motor up. I've 2 dof simulator with the motor inverted.
    Thanks...
    I post the photo of my setting in smc3.
    With flypt go all...
  12. paulopsx2
    paulopsx2 Active Member
    brasil
    647Coins
    250 for a week plus 10 for plugin
  13. Jeroen Vrancken
    Jeroen Vrancken ProSIMU T3000 Gold Contributor
    CPA
    Netherlands
    - 55Coins
    3DOF, SCN6
    Hi the dirt plugin for dirt 1 works but i cant get dirt 2 to work:
    1) Version 2.51 of simtools / PRO SIMU setup
    2) PC is set to English Local:
    3) completed a race and patched the game:
    <motion_platform>
    <dbox enabled="true" />
    <udp enabled="true" extradata="3" ip="127.0.0.1" port="4123" delay="1" />
    <fanatec enabled="false" pedalVibrationScale="1.0" wheelVibrationScale="1.0" ledTrueForGearsFalseForSpeed="true" />
    </motion_platform>"
    4) game conneted (game manager selects Dirt 2 / game engine turns blue) but in tuning center to record the values the game slected is ACC.
    I would appreciate all the help that i can get to get things woking.
    151,991Coins
    +11,061 / 56 / -2
    In the TC the game selected is a drop down list, does Dirt 2 appear in that list?
  15. Jeroen Vrancken
    CPA
    Netherlands
    - 55Coins
    3DOF, SCN6
    In TC dirt available, once i start dirt it goes to ACC and the drop down is greyed out.
  16. noorbeast
    151,991Coins
    +11,061 / 56 / -2
    The TC has a drop down for installed games, does DR2 appear there and should be selectable, like this:
  17. Jeroen Vrancken
    CPA
    Netherlands
    - 55Coins
    3DOF, SCN6
    It is, but when i select dirt and start the game it automatically switches to ACC.
  18. noorbeast
    151,991Coins
    +11,061 / 56 / -2
    @yobuddy do you any ideas as to what is messed up here?
  19. yobuddy
    51,002Coins
    Try reinstalling the dirt2 plugin first, then if there is still the problem, I can help you reset the profiles for the game.
    I'll be around most of the day buddy!
    Chat soon!
  20. Jeroen Vrancken
    CPA
    Netherlands
    - 55Coins
    3DOF, SCN6
    trhat did not help unfortunately :(
    thaks for the swift esponces!
