How to choose potentiometer
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by DonCorleonez, Mar 15, 2016.
  1. Arihant
    Arihant New Member
    Electronic Enginner
    Mexico
    96Coins
    2DOF, 3DOF, DC motor, AC motor, Arduino, Motion platform, 4DOF, 6DOF
    thanks but actually there is a problem because i want to limit the movement in +/-45 deg and the smcutility has a min clip value of 255 so with this value and the specs of my 360 hall sensor, if i set the center reference value to 2.5V or 512(adc value) the movement will reach an undesire +/-90 deg. and the solution to avoid this without use gears is changing the limits of the clip value to 512 for example , so im figuring out how to change it in the ino file.
  2. Arihant
    Arihant New Member
    Electronic Enginner
    Mexico
    96Coins
    i think a found a solution, in order to represent the movement of one sensor to other, for example a hall sensor 360CW can be represented as a 180cw mapping its input values to the desires output values, in a +/- 90 deg movement centered in 2,5V [512 ADC] the 360cw sensor goes from [255] to [766] and the 180cw sensor from [0] to [1023] , so we just have to map these values in the Feedback variable , im going to try it and check how smooth it goes
  3. ChargedBoost
    ChargedBoost New Member
    Electrical Designer
    New Hampshire, USA
    136Coins
    3DOF, Arduino
    These pots are listed at 1000megOhms minimum, I keep reading 10k ohm min/max. Looks like neither of you had issues... but..?
    Also, is there any advantage to going with the 180* vs the 360* for the same price? If the resolution is the same (12bit), then the 360 should give you a little more leeway in mounting errors, yea?
    180*: 6127V1A180L.5FS TT Electronics/BI | Sensors, Transducers | DigiKey
    360*: 6127V1A360L.5FS TT Electronics/BI | Sensors, Transducers | DigiKey
    Spending more on 3 pots than I did on all my motor controllers is giving me anxiety. Thanks!
    152,045Coins
    +11,062 / 56 / -2
    You could technically get away with 90*, if you don't use more that 40 degrees up and down, which would be the ideal, but personally I use 180 for an extra bit of headroom, see here: https://www.xsimulator.net/community/threads/hall-effect-potentiometer.4948/#post-48019
    With high accuracy, long life and unable to be damaged by over rotation, Hall sensors may have a higher upfront cost, but are good value over time.
  5. ChargedBoost
    Electrical Designer
    New Hampshire, USA
    136Coins
    3DOF, Arduino
    Good point on the higher cost vs probably not having to replace them every few weeks (or so it seems from some of these posts!).
    I've checked out that thread and re-read that post several times this morning... from what it seems, no matter if you get a 90*, 180*, 360*, every degree is still worth "12 bits", right? So, if you use 90* of a 90* sensor, you're still only using the same 1080 bits of data that you'd be using if you used 90* of a 360* sensor... I think?
    Meaning, a 90* sensor seems like it would be more accurate, but in reality, it's exactly the same. But I assume this can't be the case, because why would they even sell smaller than 360.
    I design construction power systems, this small electronic stuff is strangely foreign to me and it's uncomfortable to admit that, haha!
  6. ChargedBoost
    Electrical Designer
    New Hampshire, USA
    136Coins
    3DOF, Arduino
    I went ahead and ordered the 180* versions. If I go beyond 90* in any direction I'm in trouble anyway. Thanks noorbeast!
  7. Snapdi
    Snapdi New Member
    Canada
    - 201Coins
    Thank you so much for this recommendation. I was having a terrible time 3d printing gears and designing a system with a hall effect sensors. they were not cheap in Canada (28$CAD) each, but well worth it.
  8. Matthew Bangerter
    Matthew Bangerter Member Gold Contributor
    Mechanical Engineer
    Mesa, AZ
    72Coins
    6127V1A180L.5FS potentiometers seem to be out of stock everywhere, has anyone found a suitable replacement hall effect potentiometer?
    152,045Coins
    +11,062 / 56 / -2
    Any Hall sensor with these specs should do the trick: Hall Effect Sensor, Position, 180°, Flatted 4.5 V to 5.5 V, Pin, Cylinder Rotatable, 200 mV
    Technically you could get away with a 90 degree hall sensor (45 degrees up and down), but personally I think a bit of headroom is worth the compromise in resolution.
  10. Matthew Bangerter
    Mechanical Engineer
    Mesa, AZ
    72Coins
    Thanks @noorbeast i spent a couple hours poking around and I found 90s and 360s in the above potentiometer but as you say 180 is really the ideal for my sim. Trouble is I haven’t been able to find many other manufacturers who make a 180 hall pot. Most are 360s and the only others I have found in 180 are one by CALT that is $42 and one by P3 that is $67 which is really more than most would be willing to pay for a POT. Mouser claims to be getting more in stock in a month or so, so I may just place an order with them and wait it out unless I can find something comparable. This one seems to be a bit of a unicorn!
    152,045Coins
    +11,062 / 56 / -2
    Tech related shortages are a pain and global phenomenon at the moment, it looks as though in Australia the likes of Element14 anticipate stock later this month and as they are a global distributor that likely applies elsewhere: https://au.element14.com/bi-technol...fs/sensor-hall-0-2v-20v-to-10v-pin/dp/2319662
  12. Matthew Bangerter
    Mechanical Engineer
    Mesa, AZ
    72Coins
    Amen to that! I found this interesting site that shows stock across all vendors. looks like some company(s) that use(s) these made some massive bulk buys in september and december. Good to know other vendors are expecting them next month as well
  13. Zed
    USA
    5,844Coins
    Hey Boost, they actually are different but in practice it’s not a huge deal. It’s the same kind of thing with “filling” an ADC. You get the best resolution if you use all the bits but that may or may not matter.
    First off, 12 bits is 4096 steps and 10 bits is 1024 steps. With a 10 bit resolution over 180 degrees, that makes each step equal to 0.17 degrees. 10 bits over 90 degrees is 0.088 degrees per step - twice as fine of step size. If the actual range of motion matches the sensor, you can “see”/resolve smaller motions. But use too big of a range sensor (e.g. using a 180 degree sensor for 45 degrees of motion) and the smallest motion you can resolve is 4 times as the size as if they match properly.
    For example and just using whole (unrealistic) numbers so it’s easier to think about, if you have 45 degrees of travel and your ADC can resolve 1 step per degree, you could detect a 1 degree movement with 45 total steps. But use a 180 degree sensor and you wouldn’t see a change in output until you move 4 degrees since 45 steps over 180 degrees is 4 degrees per step.
    So which range of sensor you use matters but in practice, with enough bits of resolution, it may not be a big deal. There’s other considerations but that’s the jist of it.
    The bigger problem comes in going the other way - you simply can’t use a 45 degree sensor in a 180 degree application. In a feedback loop you really don’t want your sensors to run out of range or things can break.
    (edited for clarity)
  14. ilciumbia
    ilciumbia Member
    Engineer
    181Coins
    Hi all,
    I keep reading that with Arduino 10k is basically mandatory, but I do not understand why. I mean: the way potentiometers are connected, they form a voltage divider between the +5v supply and the tap on the rotary contact. This way, every linear pot will provide a voltage on the center tap proportional to the rotation angle - be the potentiometer 100k, 22k, 10k, 1k and even 1M and 100 ohm (though the latter two would be inadvisable due to respectively noise and power consumption). Can someone e please explain why 10k value keeps recurring in posts?
  15. Danny Miller
    Danny Miller New Member
    42Coins
    The common, popular options right now for magnetic encoders, usually sold on mountable breakout boards:
    AS5600 : 12bit
    AS5048: 14 bit
    MT6701: 14 bit
    TL5012: 15 bit
    Same ones used for encoding on FOC to turn BLDCs into servos
