My finished 2DOF project (VideoTutorial)
Discussion in 'DIY Motion Simulator Projects' started by scruck, Jun 1, 2021.
  1. RGS-Furtwangen
    RGS-Furtwangen GWS-Lörrach
    School
    Lörrach
    194Coins
  2. Martin Dixon
    Martin Dixon Member
    Sgt HM FORCES
    Devizes, Wiltshire
    26Coins
  3. RGS-Furtwangen
    School
    Lörrach
    194Coins
    There is an amazon link too, but the link gets deleted once you post it on this forum.
    You can access the link under his YouTube video.
    Aliexpress is basically the same as eBay, it mostly depends on the seller.
  4. Anthony atallah
    Anthony atallah Member
    Mechanical Engineer
    Lebanon
    106Coins
    Hi
    I got all my electronics from aliexpress, but sometimes delivery is slow.
  5. Martin Dixon
    Martin Dixon Member
    Sgt HM FORCES
    Devizes, Wiltshire
    26Coins
  6. Martin Dixon
    Martin Dixon Member
    Sgt HM FORCES
    Devizes, Wiltshire
    26Coins
    Thank you will bare the delivery times in mind when ordering
  7. James Frame
    James Frame New Member
    70Coins
    this is such an elegant compact design! love the Arduino 3D printed bits too!
  8. Goreto
    Goreto New Member
    9Coins
    Hello, what a beautiful project! Congratulations, I m really interested about making my own 2 Dof based on your project but after seeing your video I still have some questions.
    When I see the video of 2 dof simukit project, it seems like everything moved with more degrees and more speed or power? Is it hardware limitation (motor?) or software setup?
    thank you
  9. tsamt
    tsamt New Member Gold Contributor
    - 102Coins
    This is an exciting article, learned a lot, I want to know what the circuit diagram looks like? Could you send a detailed wiring diagram?
    thank you
  10. SaintFrank
    SaintFrank Member
    Proces operator
    Nederland
    148Coins
  11. Goreto
    Goreto New Member
    9Coins
    Hello there, I just received my 2 Platos and the cross from Cardyfren but I can’t put all this part together, do I need an hydraulic press? Thank you
  12. Gustau
    Gustau New Member
    Barcelona
    213Coins
    Hi, if he don't answer, he has a Discord channel look for SCK Gaming or https://discord.gg/C8EQURtKb4
  13. acex
    acex New Member
    6Coins
    Thank you for sharing the project. Looking foward to use it as reference for my own project. Very helpful
  14. amilivian
    amilivian New Member
    INGENIERO EN TELECOMUNICACIONES
    CATAMARCA ARGENTINA
    114Coins
    2DOF, 3DOF, Arduino
    Hello, can you guide yourself to assemble the cardan crosshead manually without press, I leave you a link to youtube, greetings! I hope it works for you.
  15. Kevin123
    Kevin123 New Member Gold Contributor
    Computer Programmer
    Colorado
    58Coins
    This video was very helpful. I have the same u-joint and I was wondering how to best assemble it. It worked perfectly. Thank you!
  16. amilivian
    CATAMARCA ARGENTINA
    114Coins
    2DOF, 3DOF, Arduino
    that's great! I'm glad you found it useful
  17. MoreSine
    MoreSine Member
    Hesse, Germany
    157Coins
    Love this post, your video, your blog post and everything.
    I am creating my own rig based on your tutorial, started a new post for it:
    https://www.xsimulator.net/communit...c-rig-for-flight-sims-work-in-progress.17426/
    Since I didn't want to order pulley wheels from China and they were really expensive from amazon I went ahead and 3D printed them, so far it works like a charm, will see how good they cope on the finisshed rig...
  18. fabrizio1203
    fabrizio1203 Member
    - 7Coins
    This thread is a gold mine for me! Thank you!
    I've ordered two wheelchairs motors that seem to be very similar to those in your videos
  19. Terje Helle
    Terje Helle New Member Gold Contributor
    138Coins
    Your build and your videos made me take the plunge.
    I’m now a motion sim builder.
  20. tsamt
    - 102Coins
    This is a very good teaching case, but I am not a good student. I made a mistake in wiring. Could you send the wiring diagram again?
