Question Servo motor problem
Discussion in 'Motor actuators and drivers' started by cong007, May 24, 2022.
  1. cong007
    cong007 New Member Gold Contributor
    - 192Coins
    Thank you very much. I keep studying.
  2. cong007
    - 192Coins
    Simtools has installed the game plug-in and AMC plug-in, and the AMC controller is correctly connected. However, when simtools clicks the axis test, the AMC screen does not display motion data. What is the reason?
  3. Thanos
    Electronics Engineer
    2,871Coins
    The test sliders will work if you select AXIS, not DOF... like in this video:
  4. cong007
    - 192Coins
    I set simtools according to the instructions, but the servo motor still can not move. I want to know what the problem is?
  5. Thanos
    2,871Coins
    Is your PC non-unicode set to US locale?
  6. cong007
    - 192Coins
  7. cong007
    - 192Coins
    Thank you very much. I can control the servo motor through simtools. I'm so happy.
  8. zhai1987
    zhai1987 Member
    320Coins
    2DOF, 3DOF, AC motor
    Brother, can you use Ethernet motion controller to connect with simtools?
    152,971Coins
    +11,115 / 56 / -2
