Wagnard
Elite Dangerous Horizons/Odyssey Plugin (XML edition) 4.2.0.2 pointer update
  1. Leandro Tercette
    Leandro Tercette Member Gold Contributor
    166Coins
    2DOF, 3DOF, DC motor, AC motor, SCN5, SCN6, Motion platform, 4DOF, 6DOF
    Hey guys.
    i have installed the plugin , patched edtc.. but when i started the simtools, it shows lite
    Could not find the file
    ....\EliteDangerous64_Configs.xml
    What i missing here please
  2. kev b
    kev b Active Member
    Academic Lecturer - Electrical Engineering
    Swindon, UK
    933Coins
    3DOF, Arduino, Motion platform, 6DOF
    Aw no - update 12 has killed the motion. After what seems like ages since the last ED update - really hoping @Wagnard can work his usual magic :thumbs (joystick mode just isn't the same)
  3. Wagnard
    Wagnardsoft
    Canada, Quebec, Mirabel
    5,118Coins
    I'm already on it.
  4. Wagnard
    Wagnardsoft
    5,118Coins
    Here is EDH and EDO pointers for update 12.
    • Winner Winner x 5
  5. kev b
    kev b Active Member
    Swindon, UK
    933Coins
    Latest xml work great - as usual. Many thanks again @Wagnard
  6. Roons
    Roons New Member
    - 20Coins
    @Wagnard
    Thank you for all that you do!! :)
    I've had a report that the Odyssey XML is causing an issue of detection between the Spaceship and SRV. When reviewing the XML file, it looks like the Odyssey memory locations are the same for both the ship and SRV "0551D2A8" where as for Horizons its different "041D5438" for the ship and for the SRV "041CB998"
    Do you think this would cause the issue of motion software being confused in Odyssey and switching back and forth between ship and SRV motion profiles?
    Thanks again for finding these!
  7. Shelmak
    Shelmak New Member
    20Coins
    Hi.
    First of all, thank yoy @Wagnard for your awesome work, getting the memory pointers is a tedious job and I really appreciate your work.
    I'm the one with this switching profile issue, it happens in Oddysey only, I've tried with horizons and it seems to work correctly. Problem is that it seems every time I put joystick, pedals and throttle in neutral positions, it switches to the srv profile.
    Nowadays... it seems frontier just updated the oddisey version again, so right now the motion doesn't work. It works only in Horizon
    For curiosity... anybody knows how srs profile is selected? Maybe it is selected when there are switching variables on the memory pointers?
  8. Wagnard
    Wagnardsoft
    5,118Coins
    Pointer updates for update 12 Hotfix.
  9. Roons
    Roons New Member
    - 20Coins
    You rock Wagnard!! Thank you!! :)
  10. Shelmak
    Shelmak New Member
    20Coins
    Thank you very much! It works.
  11. Wagnard
    Wagnardsoft
    5,118Coins
    I'll check that but it's possible. There is no easy way to tell when we are in SRV / ship so I kind of did a few things here and here to give the sim a Hint.
    Tell me if with the new pointer update you still have the issue. Also If I understand you are not using simtools ? because the stuff I did to avoid that is in the simtool plugin.
  12. Wagnard
    Wagnardsoft
    5,118Coins
  13. Shelmak
    Shelmak New Member
    20Coins
    Yeah... I'm not using simtools, currently I am using SRS.
    It still happens, but I suppose SRS is only getting your memory pointers to the variables to move the platform.
    How SRS determine if its a spaceship or a srv I don't know, but I expect that it's doing some checks on the variables in order to select one profile or the other one depending the values on memory. At least that is what I would try.
    Thanks again, pointers are working perfect.
  14. SaintFrank
    SaintFrank Member
    Proces operator
    Nederland
    184Coins
    I can't get ED to work with flypt .
    It gets connected if you look at the red box on connect , but no data is coming in .
    Can anyone help me with this problem.
    Does it have anything to do with pointer updates ? and how does that work
  15. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,043Coins
    3DOF, DC motor, Arduino, 6DOF
    Enumerate all the steps you did to connect, so we can know if you missed something.
  16. SaintFrank
    SaintFrank Member
    Proces operator
    Nederland
    184Coins
    -I started Flypt
    -Added source in flypt for elite dangerous .(connect box is yellow)
    -Opended steam
    -Started Elite Dangerous
    -Connect source in Flypt ( connect box changes from yellow to red )
    also tried to start ED first and then Flypt with same result.
  17. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,043Coins
    It's been a while since I connected anything so other people might be better than me for checking this out.
    But, ED requires Simtools, No? I don't remember a direct connection from Mover. Am I wrong?
    And with Simtools, you need to patch the game.
  18. Nisch
    Nisch Member Gold Contributor
    Software Developer
    Phoenix, AZ
    249Coins
    The FlyPT Mover source for ED does not work. I had to create a custom source using Wagnard's offsets. I can provide more info when I get home, but it works rather well, and whenever a new patch comes out, you just have to change the offset address to the new one and it works as before.
  19. SaintFrank
    SaintFrank Member
    Proces operator
    Nederland
    184Coins
    Hi Nisch , that would be great I like flypt with MSFS so prefer to get ED running in it .
  20. Nisch
    Software Developer
    Phoenix, AZ
    249Coins
    Here you go. You'll have to modify the rig parameters and whatnot, or just delete everything but the source module and then merge it with your current Mover profile.
