value1
City Car Driving Plugin 2.0.8.3
SimTools game plugin for City Car Driving
  1. Oms
    Oms known as "Doc6dof"
    France Colomiers
    - 173Coins
    DC motor, AC motor, Arduino, Motion platform
    A ok, I understand (I though that was easy to find parameters, with standard tables required by directX. I thing I will also tried this kind of exercise when I will have a moment...)
    Bye bye
    152,235Coins
    +11,066 / 56 / -2
    The DIY license does not cover extended applications like Game Vibe, that requires a Pro SimTools license.
  3. pepmoo
    pepmoo pepmoo
    - 71Coins
    This game still fills quite the unique and extremely practical place to driving simulation, to make better irl drivers. And hasn't updated for a long time, and who knows when (or if) next. A proper working plugin now would be fantastic for immersion and could be final for all we know. BrazilianGuy's the only one I got working and it's such a good tease for what it could be! Please consider updating this to 1.5.9.2! :)
  4. fastrella
    fastrella New Member
    Argentina
    - 251Coins
    Hello BrazilianGuy !!!. It seems that they did some update and the plugin does not work, any ideas about what it can be? the manager recognizes the game and turns it on, but I have no movement reading.
    Thanks for the plugin above!
  5. Volvox
    Volvox New Member
    Ukraine
    1Coins
    DC motor, Arduino, 4DOF
    I have exactly the same situation. Repatch and restart doesn't help.
  6. Gustau
    Gustau New Member
    Barcelona
    213Coins
    Thank you. You make my day.
  7. Dimm-vir
    Dimm-vir New Member
    programmer 1C
    Belarus Kletsk
    - 1Coins
    Great job. Thanks, just checked, everything. Not working Pitch and roll
  8. fastrella
    Argentina
    - 251Coins
    Have you tried it with the latest version of Steam?
  9. Youngking
    Youngking New Member
    - 5Coins
    I've tried the plugin with the Steam ver. CCD, and Microsoft .Net Framework error occured:
    the dialog said:
    System.ComponentModel.Win32Exception (0x80004005): ReadProcessMemory 또는 WriteProcessMemory의 일부 작업만을 마쳤습니다
    at System.Diagnostics.NtProcessManager.GetModuleInfos(Int32 processId, Boolean firstModuleOnly)
    at System.Diagnostics.ProcessManager.GetModuleInfos(Int32 processId)
    at System.Diagnostics.Process.get_Modules()
    at CityCarDriving_GamePlugin.GamePlugin.GameStart()
    at SimTools_GameManager.Mod_Lib.GameStarted()
    at SimTools_GameManager.frm_GameManager.tmr_IsGameRunning_Tick(Object sender, EventArgs e)
    at System.Windows.Forms.Timer.OnTick(EventArgs e)
    at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
    Do you have any solution?
    152,235Coins
    +11,066 / 56 / -2
    Have you tried repairing or reinstalling .NET
    You could also try setting your computer to English Local, to rule out a known bug: https://www.xsimulator.net/community/faq/simtools-language-setting-bug-change-to-english-local.233/
  11. Youngking
    - 5Coins
    Thank you for your comments, noorbeast!
    Actually, I've already searched almost all articles related to similar errors in xsimulator.net, and tried the solutions such as
    - reinstall the NET Framework
    - change my local computer location
    - reinstall the Simtools and the plugins
    - Access with admin accounts
    - Edit the config files
    - so on else ..
    but they didn't work. :(
    However, I've still tried other strategies, and I'll tell here if I fix the issue!
    152,235Coins
    +11,066 / 56 / -2
    @yobuddy do you have any insights or suggestions to offer @Youngking?
  13. yobuddy
    51,074Coins
    0x80004005 is a non specified error, but usually relates to permission errors.
    So I'm thinking antivirus?
    What antivirus are you using?
    Maybe whitelist SimTools and see what happens.
    Take care!
  14. ChuckyP
    ChuckyP Active Member
    Chicago, IL
    748Coins
    I have just installed the plugin and I’m only receiving Sway in Tuning Center. Is this still working normally for other users?
    152,235Coins
    +11,066 / 56 / -2
  16. ChuckyP
    Chicago, IL
    748Coins
    I’ll try the link you gave me to be sure I have the most recent version. I am using that “Brazilian Guy’s” version though. I’ve been getting most of the other plugins working reading back through the threads of each one but this one is fighting me.
    when I select capture settings it is only giving me sway telemetry.
    152,235Coins
    +11,066 / 56 / -2
    If only sway telemetry is available a game update has likely broken the plugin pointers and @BrazilianGuy has already indicated he would not be doing ongoing updates.
  18. ChuckyP
    Chicago, IL
    748Coins
    That was my thought as well. Just verifying. My daughter loves this game so maybe I will take a look at the tutorial about getting into the game data.
    thanks for the reply.
    152,235Coins
    +11,066 / 56 / -2
    Good on you for giving plugin development a go, it is not easy and takes considerable time and skill :thumbs
    See @value1's tips in the FAQs for finding pointer values with CheatEngine: https://www.xsimulator.net/community/faq/a-brief-introduction-to-using-cheat-engine.236/
    The SimTools 2 API is here: https://www.xsimulator.net/communit...lugin-for-simtools-2-0-api-documentation.131/
    But it may be better to hold off a bit and do it for SimTools 3 instead, as the API for it will soon be released: https://www.xsimulator.net/community/threads/simtools-v3-public-beta.17329/page-14#post-234141
  20. yobuddy
    51,074Coins
    Can't we simply roll back to the earlier working version of the game in steam?
