Icy7CE
  1. noorbeast
    151,467Coins
    +11,038 / 56 / -2
    Please post pictures of your setting.
    For flight sims you should be using larger axis assignments and Tuning Center values, see the FAQ tuning tips, in particulate not the comments regarding flight profiles: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  2. Arianus One
    Arianus One Tony Rom
    empleado
    - 26Coins
    Well, I can get it to roll correctly or with the same i`te`sity to the left as to the right, right rolls well but left very little, I have touched everything
    151,467Coins
    +11,038 / 56 / -2
    This showing settings for Assetto Corsa, even so your settings seem odd.
    What physical design is your rig?
  4. Arianus One
    empleado
    - 26Coins
    I made the wrong photo, my rig is 2dof, I show the photo with the best cofiguration achieved, but the warping to the right is still weak
    151,467Coins
    +11,038 / 56 / -2
    For a traditional 2DOF I would expect Axis2a to have the same axis configuration designation as Axis1a, with the DIR being checked orange or not determining which way each of the two axis moved.
  6. Arianus One
    empleado
    - 26Coins
    ok Noorbeast thanks you very much, i will modify configuration
    Greetings
    151,467Coins
    +11,038 / 56 / -2
  8. Dronneau.Y
    Dronneau.Y Member Gold Contributor
    france
    95Coins
    Hello @noorbeast, Hello everyone.
    I just downloaded the latest plugin.
    The game does not connect, nothing happens. I have MFS2020_GamePlugin.dll in the Gameplugins directory as well as SimConnect.dll, but what should I do with SimConnect_UDP.exe and SimConnect_UDP_config.txt that I can't find anywhere? I specify that it is about the Steam version.
    Thank you for helping me.
    L.Fleur
    151,467Coins
    +11,038 / 56 / -2
    There are specific instructions for MSFS2020, can you please verify you have followed each step:
    • This plugin installs and runs a separate application that it uses to get motion data from the game. This may require GameManager to be run as administrator when patching.
    • A config file is included with this application and is located in AppData\Local\SimTools\MFS2020. This file can be used to set the rate of data transmission, which by default is 100 Hz. It can also be used to change the IP address that the application sends data to, which is necessary when the game and GameEngine are running on different PCs. In this case, change TargetIP to the internal IP address (e.g. 192.168...) of the PC running GameEngine.
    • If you are having problems with motion data, try replacing the file SimConnect.dll in AppData\Local\SimTools\MFS2020. A different version of this file may work better on your system. Look for one in the game installation directory, or install the SDK and look in MSFS SDK\SimConnect SDK\lib.
  10. Dronneau.Y
    france
    95Coins
    Thank you Noorbeast for your answer.
    After patching the game with SimTools_pluginUdater:
    1) Game menager is well executed in administrator mode.
    2) I don't have MFS2020 folder in AppData\Local\SimTools\
    3) I replaced the SimConnect.dll from the AppData\Local\SimTools\GamePlugins folder with that of the MFS2020 SDK.
    Thanks.
    L.Fleur
  11. Dronneau.Y
    france
    95Coins
    @noorbeast,
    I was just listing what I did and the results I got, but it doesn't work.
    and as I told you, I don't have MFS2020 folder in AppData\Local\SimTools.
    L.Flower
    151,467Coins
    +11,038 / 56 / -2
    Try creating the folder and locate files like this:
  13. Dronneau.Y
    france
    95Coins
    Ok, thanks This works after manually creating the MFS2020 folder as instructed and unpatching and repatching the game.
    have a nice day.
  14. ilbiga
    ilbiga Active Member
    Network Engineer
    103Coins
    Hello everybody, especially @noorbeast
    After a few months, I am starting to work on a new simulator.
    I tried to download the plugin for Flight Simulator 2020 and, despite my 409 coins, the download is not available.
    Any idea? :think
    Thank you at all!:thumbs
    151,467Coins
    +11,038 / 56 / -2
    Use 250 of your coins here, that will unlock a weeks access to as many plugins as you care to download, including MSFS2020: https://www.xsimulator.net/community/shop/
  16. ilbiga
    Network Engineer
    103Coins
    Oh ok!!!
    I did not remember this!
    My first simulator died for the flooding of the garage :( and I haven't updated the plugins for a few years!
    Thank you @noorbeast !!!:thumbs
  17. VFX Pro
    VFX Pro Member
    Los Angeles
    371Coins
    Motion platform, 6DOF
    After Microsoft Flight Simulator open, while in the main menu, the whole rig starts moving and non-stop making impossible to move the mouse and select something. Especially, worse when using helicopters. Is that a problem for anyone else? What could be causing such issue? MS is incorrectly sending telemetry while in the main menu?
  18. DZSchneider
    DZSchneider New Member
    Toronto
    64Coins
    I experienced the same thing. Works fine when in-flight, but constant shaking in the menu.
  19. radist07
    radist07 Valeriy
    Учитель
    Россия
    630Coins
    there is no movement. Unable to load DLL "SimConnect.dll ": The specified module was not found. (Exception from HRESULT: 0x8007007E)
    151,467Coins
    +11,038 / 56 / -2
    Just checking, have you followed the following:
