  1. Joe Cortexian
    1,537Coins
    The SMC3 code will not drive the rig outside of the clip limits. If the rig is outside the clip limit the SMC3 code will drive the motor back to the center position. The motors are not disabled in this case. You can potentially set the max limit to 0 which would in theory never disable the motors.
    This effectively disables the max limit. This could lead to the motor being damaged in certain theoretical situations. You need to avoid the case where that drop position is between 2 and -2 (or 1022). In the case of crossing over the zero point it could driver the motor the wrong direction and damage it. So you may want to make the max limit 2 and the drop point 10 (for example) to avoid any possibility of going the wrong direction.
    Once you exceed the max limits you cannot move. You have to backdrive the motors back inside the limit and then reset the Arduino or Enable to motors from SMC3Utils.
  2. motiondynamics
    motiondynamics Member Gold Contributor
    1,235Coins
    2DOF, 3DOF, DC motor, AC motor, SimAxe, Arduino, Motion platform, 6DOF
    What is the technique for correctly setting the Clip Input values? I've read what the values are for, but I don't know how to set them up. Is it done in realtime with Simtools or with the game running? How do I configure the correct values?
    153,710Coins
    Do not run SMC3 and SimTools at the same time, it will create a port conflict.
    From a mechanical efficiency point of view around 38-40 degrees of lever movement up and down is about the limit of effective torque utilisation, over that puts unnecessary strain on the motors.
  4. Joe Cortexian
    1,537Coins
    Those parameters are set from SMC3Utils one time. You can move the motor manually to a point you consider the limit of where you want it to go and set the clip limit there.
    You said you have a lead screw, to me that implies multiple revolutions on the pot. If that is the case then it’s not going to work without a software change.
  5. motiondynamics
    1,235Coins
    Hi guys, thanks for the help.
    I tried again to change the parameters in SMC3utils but I don't know if I entered the correct values. That is, now I will better explain the steps I did in SMC3utils. Introduction, today I did the tests with my prototype with 12V micromotors and Arduino and BTS7960. I have selected the following parameters shown in the figure, obtaining the graph you see.
    So I maximized the Clip Input value, but the graph hasn't changed, so the rotational motion of the motor arm has the same angular rotation.
    The effects of the PID values are seen in real time instantly as the motor moves.
    Are the effects of changing Clip Input values also displayed in real time in SMC3utils?
  6. motiondynamics
    1,235Coins
    I hope to receive an answer soon because my ideas are very confused and I don't know what steps to take
    :sos:(
    153,710Coins
  8. Joe Cortexian
    1,537Coins
    That's correct changing the clip values does not change the amplitude of the waveform sent by the test programs. There is no way to set the amplitude in SMC3Utils.
    Use manual mode to move all the way to the clip limits. So where you clicked on "Triangle Wave" to get this plot click on "Manual". Now the graphic to the left of the plot can be used to move the target position anywhere within the non-clipped area. Drag the dot with the mouse or click I don't remember which.
  9. motiondynamics
    1,235Coins
    Hi guys and thanks for your help.
    Message to Joe: The PNG file is all black with a pixel in the center.
    So I took a step forward with SMC3utils, namely:
    on the left of the window I selected "Manual", I set the value of 255 in Clip Input, I moved the blue cursor manually within the range and the motor rotated perfectly until it reached a maximum angle of about 60 °. Then I exceeded the Clip limit and the engine did not rotate beyond the limit, I went back inside the limit and it started working again, perfect.
    Then I set the value of 200 in Clip, I moved the blue cursor manually within the range and the motor rotated until it reached a maximum angle of about 80 °. Then I exceeded the Clip limit and the motor did not rotate beyond the limit , I went back inside the limit and it started working again, perfect.
    So I guess I'll leave the value of 200 in Clip Input, this is already a big step for me, having set a value chosen wisely.
    I know that SMC3utils is absolutely necessary to set the values of PID, PWM and safety limits. Also I noticed that the value of 200 that I set in Clip Input is strictly related to the value of "Amount of Axis to Use" (Output Testing) of Simtools, that is, if I set a Clip Input value of 255, the angular rotation goes from 60 ° to -60 ° when I move the slider of "Amount of Axis to Use", if I set a Clip Input value of 200, the angular rotation goes from 80 ° to -80 ° when I move the slider of "Amount of Axis to Use ".
    But I have a question: suppose that due to a software configuration error or a hardware problem, the motor exceeds the range of the Max Limits set in SMC3utils and blocks for safety reasons. How do i unlock the engine? Do I have to act mechanically or simply as a computer?
  10. Joe Cortexian
    1,537Coins
    First of all I didn’t post a PNG so far as I know.
    Yeah once you are outside the limit SMC3 software will not move the motor ever. So you either have to manually move it or move the pot. The logic in the Arduino is if target exceeds limit disable motor. That means drop the motor enable I/O bit.
    It is possible to write a different program for the Arduino that would move the motor. However, mechanically moving it is likely easier.
  11. motiondynamics
    1,235Coins
    Hi Joe and thanks for the replies, I will run further tests and let you know.
    NOTE
    I have attached the screenshot of your attached file, I don't know how that is possible.
  12. Manes
    Manes Member
    179Coins
    Hello guys. I hace a problem with SCM3. I format my pc, and when reinstalate the SCm3, the PWMmax is always in 1. I put more power, he put 255 , and when I save and close, the motors dont have power. I open the SCM3 again, and the PWMmax is in 1. Anybody knows? thanks guys!
  13. motiondynamics
    1,235Coins
    Make sure you have selected the correct COM.
    Go to "Device Manager" and look at which COM port your board is associated (for example Arduino) ...
    You have to open the "SMC3Utils" file and enter the same COM port
  14. Manes
    Manes Member
    179Coins
    Yes. The Scm3 and Arduino are conected. I select the com Port and Scm3 and Arduino works. The problem is pwmax is in 1, i Up to 255, save, close, open again, and pwmax is in 1. I try to delete and reinstalate but the problem is the same....
  15. Elvis A. Ramírez
    Elvis A. Ramírez Flight simulator
    Engineer
    Dominican Repúblic
    79Coins
    Hi guys! I want to know if MODE 1 works for L298n motor driver?
  16. noorbeast
    153,710Coins
  17. DerKlausi
    DerKlausi New Member
    117Coins
    Hi all,
    is there any way to read the raw data (=sensor output and other values) from SMC3-Utils instead of just watching the graph output? Or even better: where may I find the source code of the SMC3-Utils?
    Thanks,
    DK
  18. kalbasator
    kalbasator Active Member
    Kazahstan, Almaty
    170Coins
    3DOF, DC motor, Arduino, Motion platform, 4DOF
    Hello! If it's still relevant, then I got rid of the squeak by increasing Fpwm.
  19. Slybynight
    Slybynight New Member
    128Coins
    Hi guys, I have a problem. one of my motors on my 2DOF rig cuts out after about a minute of gameplay. Everything works fine in SMC3, the problem happens on all games. Everything works fine when moving slider on Simtools game engine - I did this for ages in case it was a thermal thing - it didn't cut out. So my thinking is.
    Motors are fine
    Pots are fine
    Driverboards are fine
    Game is fine
    Problem has to be in the arduino right? So long story short I'm trying to make sure the code in my arduino is up to date.
    How do I know what version it is?
    What is the latest version? Some places say V0.7.0, some say V1.1, can someone please point me to a link to the latest version?
    EDIT - I think I get it now - ino is V0.7 and all other version numbers refer to simtools right?
    But I still have my problem - re-uploading ino V0,7 to the arduino did not fix it.
    If I quit simtools and load up SMC3utils, the 2nd motor jerks back into action. Then I can close SMC3, restart simtools and everything works fine again.
    For about a minute, then the same motor stops responding again.
    I am nowhere near my max limits or clip inputs.
    EDIT 2
    By Jove I think I have found the problem!!! Took me ages to find it, but it might be useful to anyone else having the same problem. The problem goes away when I disconnect the cooling fan for my IBT controllers. I think the fan motor is too close to the whole IBT heatsink and is causing some sort of interference with fast moving game data - that would be why the problem never showed in SMC utils or Game Engine sliders - too slow. DONT MOUNT YOUR COOLING FANS TOO CLOSE TO YOUR MOTOR DRIVER BOARDS FOLKS!!!
  20. Krzysztof Dej
    Krzysztof Dej Active Member
    Poland
    1,100Coins
    Hi I use ibt motor driver and wiper motor. Trying to do belt tensioner and have a problem. Before wiper motor Smc3Utils go only down like on picture, I change arduino and ibt and still the same, then I changed motor to wiper motor and when run Smc3Utils. Program start and I see pot sygnal and then when I switch power on Smc3Utils crashes. When I start Smc3Utils with power on its crashes instantly. What is the problem. Wiper is ground protected. Psu is:
    Power: 150W
    Voltage : 12V
    Amperage : 12,5A
