Assetto Corsa Competizione Plugin 2.0.0.0
SimTools plugin for Assetto Corsa Competizione
  1. yobuddy
    51,682Coins
    Use extra 1 buddy
  2. prosimu
    prosimu Member Gold Contributor
    - 940Coins
    In axis 5 it's for the front actuator, and the front traction loss, it's extra 3, axis 6 for the rear. All it depend of your feeling, you can choose extra 1 or 2.
    And you can contact us directy on our website if you need help too. In contact ;)
  3. Suglock
    Suglock New Member
    46Coins
    Thank you for this plug in but I have a question, the turns are not reversed, i.e. I follow the curve of the turn instead of going in the opposite direction with the centrifugal force and I can't increase the surge effects
    Thanks for your feedback
  4. Hermant Alexis
    Hermant Alexis Member
    238Coins
    I just downloaded this plugin-> https://simtools.us/plugin/?varname=26&color=0e97dd
    is this plugin working with the new simtools v3 ?
    The downloaded file is "AssettoCorsaCompetizione_V2_GamePlugin.zip", but it's noticed "
    Plugin Upload: 2 (v3.0)" on the page. So I'm a bit confused...
  5. yobuddy
    51,682Coins
    Yes, this is a v3 plugin.
    All of the v3 plugins are available directly in the app (plugin manager).
    Take care,
  6. luu trung
    luu trung Member
    172Coins
  7. yobuddy
    51,682Coins
    The plugin uses their API so i believe it should work, yes.
  8. luu trung
    luu trung Member
    172Coins
    wow.thanks
    154,588Coins
    +11,190 / 57 / -2
    @luu trung please report back after you try it, to confirm it works, or alternatively identify issues if it does not.
  10. Guus Franken
    Guus Franken New Member
    - 45Coins
    2DOF, AC motor, Arduino
    Hello
    can anybody tell me why this plugin don't work anymore ?
    using SimTools_2.5.1
  11. yobuddy
    51,682Coins
    The plugin uses their official API so I believe it should work.
    (The SimTools v3 version of the plugin was working last we checked.)
  12. Shige Tanaka
    Shige Tanaka FREX Actuator Supplier http://www.frex.com/gp/ SimAxe Beta Tester Gold Contributor
    FREX
    Osaka Japan
    - 324Coins
    2DOF, 6DOF
    Hi yobuddy,
    We’re glad to have a SimTools 2 plugin for Assetto Corsa EVO as well. SimTools 2 is very useful when adding extra actuators alongside the 6DOF system driven by SimTools 3.
    Thank you!
  13. yobuddy
    51,682Coins
    Hi Shige,
    Hope you are well buddy!
    I don't quite understand why you would need to use SimTools v2 and v3 at the same time? As SimTools v3 can be configured to run 3 independent Simulators, all with their own axis and max/min settings. I know our manual probably needs some more information these settings, but feel free to buzz me if you want some more info on this setup.
    Take care!
  14. Shige Tanaka
    FREX
    Osaka Japan
    - 324Coins
    2DOF, 6DOF
    Hi @yobuddy,
    Because it was very easy to use 6 axes with SimTools 3 and 2 additional axes with SimTools 2, I was able to control all 8 actuators individually.
    Question:
    I changed the SCN ID from 0 to 1 and entered Interface Settings > Assigned Axis 1b. SimTools 2 works, but I couldn't get it to work with SimTools 3.
    Question:
    How can I set different speed and acceleration for 1a and 1b using a single menu?
    Thank you in advance.
  15. yobuddy
    51,682Coins
    Hi @Shige Tanaka,
    SimTools v3 will allow for 18 individual axis to be configured and assigned as needed.
    In SimTools v3, we can go to B Axis Assignments, and set the Min/Max input source to Set #2.
    Then under Min/Max Tuning, we can select Min/Max Set #2, and adjust the settings as needed just for our B Axis Assignments.
    The v3 SCN interface was built from the v2 one, so I can't think of why it would not work off hand, so I will take a look at the SCN v3 interface and see if I see any problems.
    Unfortunately the settings on the form are for all of the actuators attached to the interface. Most people need 2 scn's to built a chair, so this has not been a problem. So ror now, you would need to use the SCN on its own usb adapter and Interface setup for different settings. A custom SCN interface could be produced for separate settings in the future should it be needed thou.
    Take care!
