Peacemakers 6dof Unicorn Build
Discussion in 'DIY Motion Simulator Projects' started by Peacemaker105, Oct 5, 2018.
  1. Jaime Godinez
    Jaime Godinez New Member
    224Coins
    Haha,we actually get our Ballscrews from the same manufacturer..... I did contact them Yesterday afternoon to inform them about the slight bend.... I asked that for the next order to QC the rods on straightness before shipping so that i don't need to straighten them myself...
    Cheers and thanks again for the reply
  2. misoswan
    misoswan Active Member
    1,032Coins
    3DOF, Arduino, JRK
    bend that bad :(
  3. Jean Paul Andrade
    Jean Paul Andrade Member
    272Coins
    hello my friend, I'm really inspired by your actuators design, I started to biuld my own with the same servomotors and the principles of your design. my first build was a 2Dof with traction loss and have been working pretty good the last 2 years. can you please tell what doccumentation should I read to calculate de exact dimmentions of the base and the upper platform? thanks!
  4. Jaime Godinez
    224Coins
    It's a very small bend, you'll really just notice it when it is setup without the tube. Also when you roll it on a flat surface, you can see the gap between the table and the screw when a light is placed behind it.
    When i fully assemble the actuator, it seems to forcefully keep it in check. But when you run it in fast mode and hold the actuator, you can feel the vibration. I will straighten it tom. and test again :)
  5. Peacemaker105
    Perth, Aus
    2,019Coins
    Hmm.. Strange.. i have seen some other people with wierd wobbles. Is there anyway you can check the straightness of the screw at all?
    Maybe post a video if you can so wee can see :)
  6. Peacemaker105
    Perth, Aus
    2,019Coins
    Soon this thing wont be able to lift off the ground.. i swear.. haha
  7. Jaime Godinez
    224Coins
    Yes, After I noticed the Wobble, I dis-assembled the Ballscrew and did 2 checks... the first simple one would be to roll it on Glass, then shine some light behind it. First thing you'll notice when you roll it fast, is that you hear a rythmic sound instead of a constant... Then when you shine the light behind while rolling. you can see that the gap under fluctuates. The second test would be to place the ballscrew between two bearings , then you roll it while having a Dial measure the fluctuation (watch the 3rd Video below)
  8. Jaime Godinez
    224Coins
  9. Jaime Godinez
    224Coins
    This was the wobble at medium speed
  10. Jaime Godinez
    224Coins
    The C5 should only have a fluctuation tolerance of 0.025...... Mine had 0.24, seems small , but it compromises the ball screw at high speeds when fully assembled
  11. Jaime Godinez
    224Coins
    I am now building this... It actually is not expensive. You can use a 1 ton Arbor press( which is about $60) and also much shorter rails.. with this, I can make sure I get the tolerances correct. better smoothness and less noisy.
  12. Jaime Godinez
    224Coins
    This was my actuator after the initial straightening with my crude device. It needs a little more but pretty much reduced the wobble tremendously.... I will do another pass when i finish making the new straightening device
  13. Jaime Godinez
    224Coins
  14. Bobbitchin
    Bobbitchin SennaMental
    Perth Australia
    543Coins
    Hi, I just bought Flag Ghost's belt tensioner and was going to use the same motor as you did as I have the same motors for my actuators. I was wondering if you could share your modified motor pulley stl, and also could you add a link to the motor with white controller and also the motor bracket. Cheers
  15. Bobbitchin
    Perth Australia
    543Coins
    can you please tell what doccumentation should I read to calculate de exact dimmentions of the base and the upper platform? thanks![/QUOTE]
    This is peacemakers dimensions from an earlier post cheers
  16. Bobbitchin
    Perth Australia
    543Coins
  17. Jaime Godinez
    224Coins
    This is where we get the motors and also motor brackets etc... https://www.aliexpress.com/store/3223052?spm=a2g0o.store_pc_home.pcShopHead_36126704.0
    With the modified Pulley stl, I also purchased the same from Ghost, I did the modification of the spindle on Fusion360, but please check it ... the 90st' shaft dimension is 16h7 while the 80st is 19h7 . when i enlarged the shaft hole, the key hole got quite close to the outer wall, Cura left a layer gap on the key slot. Though there really would not be any mechanical pressure there , I may still close it with cured resin or epoxy.....
  18. Jaime Godinez
    224Coins
    153,001Coins
    +11,116 / 56 / -2
    If you have a zip file that should upload, but if it does not I am guessing it must be pretty large. If that is the case a file host and link is an option, or our site admin @RaceRay may be able to help out, as I am sure members would appreciate access to the STLs.
  20. Jaime Godinez
    224Coins
