News Gran Turismo 7 with XSim soon ?
Discussion in 'News' started by vthinsel, Jul 28, 2022.
  1. vthinsel
    vthinsel Well-Known Member
    FRANCE
    6,030Coins
    Arduino, 4DOF
    • Like Like x 6
  2. vthinsel
    FRANCE
    6,030Coins
    Arduino, 4DOF
    Well :)
    Still needs polishing and proper packaging to include the Proxy, but works pretty well.
    So happy to have such license with XSim !
    As you can see there are many metrics for tires. Was wondering what could be used for accurate traction loss :nerd. Any ideas appreciated here :)
    • Optimistic Optimistic x 1
  3. levers
    965Coins
    Hi, if there's no actual output for traction loss then is it possible to use the rate of change of yaw relative to speed? I noticed at about 2:08 the yaw angle has been steadily descending as you take the corner then suddenly increases as the rear end steps out then drops back just as quickly before steadily descending again.
  4. vthinsel
    FRANCE
    6,030Coins
    Arduino, 4DOF
    Hello ! Time for some news on this plugin. The first version I made a couple of weeks ago gave good results. Now, it feels awesome ! The reason is that I assumed roll/pitch/yaw was provided directly. I was totally wrong. All telemetry data is provided through quaternions...... very powerfull notion, but very complex. So I got help from guys from the GTPlanet forum, to understand all this stuff and change the code accordingly.
    And here is the result (including traction loss...) :
    You can already check the proxy part which gets telemetry data and can generate csv files, in addition to forward data to the upcoming GT7 XSim plugin: https://github.com/vthinsel/GT7Proxy
    There are binaries too: https://github.com/vthinsel/GT7Proxy/releases
    A video will come soon too.
  5. Дмитрий Кученин
    Дмитрий Кученин New Member
    282Coins
    I pray to God that everything will work out for you, I am waiting for the day when our community will be able to launch its platforms in GT, I am an ardent fan of PS and PS VR. I decided to build my platform when I found out that it was possible to extract telemetry. I do not have the opportunity to buy a ready-made one.
  6. Neftali
    Neftali PS5/GT7/NLR GT Track/Fanatec setup
    The Netherlands
    2Coins
    Hi, i was just looking the whole internet for this.. can it also work with individual bassshakers on gt7? want to know before buying the license. hope to hear soon and great job!!
    151,479Coins
    +11,041 / 56 / -2
  8. Neftali
    The Netherlands
    2Coins
    Hi, yes i have read this but don't see anything about the basshakers, i want to control them individually if possible, can i use a test or trial license before buying an actual license?
    151,479Coins
    +11,041 / 56 / -2
    The Simools V3 link in the post shows Vibe support: https://simtools.us/plugin/?varname=30&color=0e97dd
    The fully functional Live For Speed plugin is provided with the demo version of SimTools, specifically for testing purposes.
  10. Neftali
    The Netherlands
    2Coins
    Tnx a lot, i will start with this as soon as possible, hopefully all works like i hope it will be.
  11. vthinsel
    FRANCE
    6,030Coins
    Arduino, 4DOF
    There should be no issues with bass shaker, as I populate the various fields. Not having one myself, I couldnt test for real.
    I suggest you go for the simtools v3 as well.
  12. Neftali
    The Netherlands
    2Coins
    Hi, thank you for answering, ill give it a try.
    i want to use the bass shakers for better driving… maybe when driving over curbs or when my brakes block…, if all works well i let you guys know.
  13. j0k3r
    j0k3r Member
    307Coins
    2DOF, Motion platform
    Hi @ all,
    1st of all thanks for that nice piece of software. Sadly I cant get it to run :/ got a njMotion Compact-R and wanna try to play GT7 with motion, but that thing doesnt work on my win11 Computer. I post a screenie from my desktop, would be nice when anyone could help me out. Thanks in advance :)
  14. vthinsel
    FRANCE
    6,030Coins
    Arduino, 4DOF
    Hello .
    Try in something else than powershell ISE.
    A simple cmd window should do the job.
    Happy new year !
  15. j0k3r
    j0k3r Member
    307Coins
    I wish you and your fam a happy and a nice new year :) I tried it with the nornal cmd app of win11 but with that I got a tineOut, I make a Picture asap and show you what I mean, thx for helping :)
  16. j0k3r
    j0k3r Member
    307Coins
    ...thats the output that I got when I use a normal cmd window on my win11 pc.
  17. j0k3r
    j0k3r Member
    307Coins
    hmm sorry for pinging, but I cant edit my posts :/ I tested a random iP instead of my PS5 iP, and I got the same output as I showed you in the screen before (with the satndard cmd of win11). Thats crazy cause thats an iP outside of my iP range : I tested : .\GT7Proxy --ps_ip 192.168.0.109 and .\GT7Proxy --ps_ip 192.168.5.13 and both gave me the same output/result.
  18. vthinsel
    FRANCE
    6,030Coins
    Arduino, 4DOF
    Telemetry uses UDP, with no handshake or whatever. So you can put any IP you want, it will alaways give the same result. Check firewalls (including on your windows PC).
    Timeout messages can be an issue related to antivirus/windows TAP/VPN interfaces. Anyway, even with timeout you can get telemetry data. That's my case on one of my windows 11 laptops.
  19. j0k3r
    j0k3r Member
    307Coins
    hmm, I dont get that thing to work :( I disabled every security releated settings in windows and disabled my AntiVir, but sadly with the same result. I tried already to ping my PS5 in my homeNetwork with success, but everytime I try GT7Proxy I get that timeOut and no Packet iD :/ do you see my router settings where forwarded the UDP ports? Maybe something is wrong there...?
  20. j0k3r
    j0k3r Member
    307Coins
    okay got something to work, when I start GT7 and start driving my cmd window starts to make something ;) and my njMotion ComactR starts with the motion BUT with a strange feeling, all is feeling vice versa, when I accelerate my seat starts moving forward and when I brake my seat is moving backward, normaly the seat have to move forward when I brake. Something iss not working on my setUp I think :/
    https://streamable.com/q978ja
