Showroom Motion platform "Catopult"
Discussion in 'DIY Motion Simulator Projects' started by kalbasator, Jul 1, 2022.
  1. kalbasator
    kalbasator Active Member
    Kazahstan, Almaty
    400Coins
    3DOF, DC motor, Arduino, Motion platform, 4DOF
    151,516Coins
    +11,041 / 56 / -2
  3. kalbasator
    Kazahstan, Almaty
    400Coins
  4. kalbasator
    Kazahstan, Almaty
    400Coins
    Hi all! Some photos of the process...
  5. kalbasator
    Kazahstan, Almaty
    400Coins
  6. kalbasator
    Kazahstan, Almaty
    400Coins
    Hey @noorbeast!
    Do you have knowledge of hypoid gearbox? Or perhaps you can recommend someone to help me choose a hypoid gearbox. Or are such gearboxes not suitable for our platforms?
    151,516Coins
    +11,041 / 56 / -2
    I don't profess to be an expert.
    Design wise a hypoid gearbox for a given ratio should be more efficient and a wormdrive more compact and lighter.
    Cost can be a factor, but there are so many other possible variables there, same with quality.
  8. kalbasator
    Kazahstan, Almaty
    400Coins
    I'm just not able to figure out what gear ratio I need. Now I have a 50:1 worm gear. But in hypoid gearboxes, the gear ratio is indicated somehow differently, and this is where I got confused.
  9. kalbasator
    Kazahstan, Almaty
    400Coins
    And I also have a small update - I made a rack for three monitors of 32 diagonals. I used a profile pipe 40 * 40. I think the safety margin is enough :):grin
    151,516Coins
    +11,041 / 56 / -2
    I am not sure what you mean, independent of whatever box is used the motor input shaft speed is ultimately converted to an output shaft rotation speed, and that ratio is what we commonly refer to with respect to our rigs.
    Of course being different types of gearboxes if you are counting gear teeth then yes they will differ, given the different type of gearbox construction.
  11. kalbasator
    Kazahstan, Almaty
    400Coins
    Platform test 4 DOF, pilot 40 kg
  12. kalbasator
    Kazahstan, Almaty
    400Coins
    Dirt rally 2.0 Test drive with Motion Simulator Platform 4DOF. Triple screen.
  13. kalbasator
    Kazahstan, Almaty
    400Coins
    @noorbeast , Hello! I wanted to ask - have is the game - Drift simulator, with an available plug-in for it?
    I looked at the plugins section, but didn't notice anything similar.
    151,516Coins
    +11,041 / 56 / -2
    I am not sure what you mean by:
    There is the FURIDASHI: Drift Cyber Sport plugin: https://www.xsimulator.net/community/marketplace/furidashi-drift-cyber-sport.210/
    But you can also use the likes of Assetto Corsa, which has a whole host of drift mod tracks and cars available: https://ac-driftgame.com/
  15. kalbasator
    Kazahstan, Almaty
    400Coins
  16. noorbeast
    151,516Coins
    +11,041 / 56 / -2
    If you go the AC drift route, which I would recommend, then also use Content Manager to install and manage both mods and fine tune AC settings: https://assettocorsa.club/content-manager.html
  17. kalbasator
    Kazahstan, Almaty
    400Coins
    Thanks a lot for the recommendation!
  18. kalbasator
    Kazahstan, Almaty
    400Coins
    Gradually I put things in order.
      131.5 KB
      182
  19. kalbasator
    Kazahstan, Almaty
    400Coins
    Hi all! We continue to test, it seems to work well :). But i may still have to make some adjustments to the software.
