Question One of your Interfaces Requires GameEngine to be Restarted
Discussion in 'SimTools DIY Version' started by IRaceSim, Jan 4, 2019.
  1. noorbeast
    152,535Coins
    +11,085 / 56 / -2
    Can you please post pictures of all of your settings, that may help others to make suggestions.
  2. IRaceSim
    IRaceSim Impalone
    Geometra
    Teramo
    63Coins
    2DOF, SCN5, Arduino
    This is the screenshot of my settings.
  3. IRaceSim
    IRaceSim Impalone
    Geometra
    Teramo
    63Coins
    2DOF, SCN5, Arduino
    I tried with an old xsim converter, and the actuators are detected.
    The problem must lie in the settings of the Xsimulator Engine, I try to reinstall an older Xsimulator and I tell you.
    152,535Coins
    +11,085 / 56 / -2
  5. yobuddy
    51,183Coins
    It looks like your trying to run 4 scn actuators?
    2 scn's connected to each serial adapter?
  6. IRaceSim
    IRaceSim Impalone
    Geometra
    Teramo
    63Coins
    2DOF, SCN5, Arduino
    No. Each SCN5 has its own card with its own port
  7. yobuddy
    51,183Coins
    Your assigning 2 axis to each thou.
    This tells the interface you have 2 scns attached, one with the id of 0 and one with the id of 1.
    So you probably need to remove the second one.
    Take care,
  8. IRaceSim
    IRaceSim Impalone
    Geometra
    Teramo
    63Coins
    2DOF, SCN5, Arduino
    Finally thanks to you yobuddy, I didn't understand the drop-down menu. I am very rusty and I hope that this can still be of support to the community, I have been standing for two years but now I am back to have fun on the Sims you are number 1.
