3dof---jazzy wheelchair motors---flight sim version
Discussion in 'DIY Motion Simulator Projects' started by stanley johnson, Oct 14, 2022.
  1. Halloween2go
    Halloween2go Active Member Gold Contributor
    1,395Coins
    Your doing great! I'm mounting the TL motor next episode.. it will be on the midframe, cause I really wanted to mount it on the bottom but there's just no room.. So mid frame. trying to make the most of the TL.. but you actually dont need too much .. unless you plan on 'drifting' and if I was designing a drift sim, I would probably modify both frames to accomodate a longer rod.. Thanks for watching! I'm trying to grow my channel before I retire from 'work', so all helps out a bit.. Dave
  2. stanley johnson
    stanley johnson Active Member
    Diesel tech
    Nashville
    82Coins
    Awesome Dave, can’t wait for the next video, interested in how you mount the to motor. Man I tell you Dave I have watch all your YouTube videos around 5 to 6 times, find something new every time I watch them, You Rock
  3. stanley johnson
    Diesel tech
    Nashville
    82Coins
    That’s not gonna work, got to neaten that up
  4. Halloween2go
    1,395Coins
    Thanks Stanley.. I'm just a guy having fun out here.. I totally appreciate you watching the videos.. That really the easiest way to get the information across.. more coming up.. I get home on friday.. should be back to working on it a bit 'cant wait to get this thing running' cause it's going to be better than the other 3DOF rig.. Dave
  5. stanley johnson
    Diesel tech
    Nashville
    82Coins
    We got POWER
  6. stanley johnson
    Diesel tech
    Nashville
    82Coins
    Traction loss wheel plate done!
  7. stanley johnson
    Diesel tech
    Nashville
    82Coins
    Seat u-joint mounted, lower and mid frame done
  8. stanley johnson
    Diesel tech
    Nashville
    82Coins
    08ED8092-C3FF-4F5B-9040-0664C3291635.jpeg 08ED8092-C3FF-4F5B-9040-0664C3291635.jpeg 188D0102-A527-4C3B-9B83-5410850E5427.jpeg Upper frame coming along
  9. stanley johnson
    Diesel tech
    Nashville
    82Coins
  10. stanley johnson
    Diesel tech
    Nashville
    82Coins
    It’s time to mount some motors!!! F7E4BFC2-4581-4DCF-A342-1FF595A0BEC9.jpeg 9C6D7865-74D2-4AD8-B9C4-B2FB1DA0D563.jpeg
  11. stanley johnson
    Diesel tech
    Nashville
    82Coins
    Two motors mounted and one to go
    153,697Coins
    Nice progress :thumbs
    When do you plan hooking the motors up and conducting your first motion test?
  13. stanley johnson
    Diesel tech
    Nashville
    82Coins
    I will be hooking everything up this weekend, fingers crossed, lol
  14. stanley johnson
    Diesel tech
    Nashville
    82Coins
    Front motor linkage installed. F9B35A2C-239F-46CF-9135-4C39549EFE7B.jpeg 50BD7514-4833-443D-967E-E1E27307BDC6.jpeg 30877CEB-9576-4F94-BFDD-757EDECD0DD8.jpeg F9B35A2C-239F-46CF-9135-4C39549EFE7B.jpeg
    153,697Coins
    I am looking forward to seeing your initial test run, it is always a moment of trepidation followed by relief, if everything goes to plan.
    What is the CTC distance on the leavers, it looks pretty big for a full frame compact design?
  16. stanley johnson
    Diesel tech
    Nashville
    82Coins
    5 inches
    153,697Coins
    Testing will be interesting, my guess is that the lever CTC distance will possibly need to be reduced to about half of that.
    I use 60mm CTC on my compact rig.
  18. stanley johnson
    Diesel tech
    Nashville
    82Coins
    I was just guessing, if they are too long I will cut them back to 60mm. You thinking my throw will be too much?
    153,697Coins
    It is easy enough in the construction phase to add some CTC options, without compromising the strength of the lever too much, you don't need to cut the lever until you determine the ideal hole CTC for your rig.
    I would suggest you add a hole at 60mm, start with that in testing and see if it can be extended, which really comes down to the actual mass of the upper frame/peripherals/user, the power of the motor and the gear ratio used.
  20. stanley johnson
    Diesel tech
    Nashville
    82Coins
    So start at about 2.5 inches from center of shaft?
