SimTools v3 Public Beta
  1. Suglock
    Suglock New Member
    46Coins
    Thank you this new software.
    I tried but I can't configure my motion..they are PRS 200 from Prosimu and in the setup interface there is nothing, how to do it please
    Thx for your help
    Regards
    Eric
  2. Krzysztof Dej
    Krzysztof Dej Active Member
    Poland
    1,100Coins
    This plugin is what this game need!!! Fantastic. All smooth and responsive, no surge problem at last!!!! V3 instalation proces is little not intuitive. Becouse The process seems to hang and nothing is happening for a long while, but it working and for about a minute or maybe long start working and installing. Configure process is different to the sim tools 2, but easy and for me is better. Also parking option is awesome, bo more hard starting. One problem for me that after creating profile and stop playing one motor was hot. Maybe becouse by mistake on the end I was set surge and sway on the one force. This need to test it longer. But my face was smiling like on christamst gift on this brilliant rbr profile. Thank you very much for your effort
  3. gigi
    gigi Active Member
    919Coins
    2DOF, JRK, 4DOF
    hello Youbuddy and good morning to the whole community. Please excuse me if I didn't answer your question earlier. As I wrote a few weeks ago I had some health problems .... now fortunately almost solved and I could not devote myself to the simulator and simtools. However, this morning I started simtols v3 and after the update everything works perfectly. I no longer have the problem of the small and unreadable interface. Now I'm finally ready to test all the new features in v3. Thank you thank you and thank you again for the support
  4. yobuddy
    51,523Coins
    I sent the ProSimU guys a test interface last week, but have not heard anything from them.
    I will work on releasing the interface api in the next week or so, so we can get you supported.
    Awesome!
    Thanks for the feedback buddy, glad your feeling better!
  5. Wanegain
    Wanegain Active Member
    Bruxelles
    2,018Coins
    This new version is incredible ! Exactly what we need hug:
  6. Krzysztof Dej
    Poland
    1,100Coins
    For me I found an error that not exist in sim tools 2. When I create 2nd interface profile, application crashed and turn off
  7. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    Hi @Milt if you are still looking for a fix for simhub and simtools with dirt rally 2.0 then add these lines in the hardware_settings_config file
    <udp enabled="true" extradata="3" ip="127.0.0.1" port="20777" delay="1"/>
    <udp enabled="true" extradata="3" ip="127.0.0.1" port="4123" delay="1"/>
  8. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    Hi are there any v3 plugin guides need a detailed udp one like a v3 plugin guide for dummies:grin
  9. yobuddy
    51,523Coins
    Please show me how to recreate the problem buddy, as I can't seem to do it.
    Thanks!
  10. seb414
    seb414 New Member SimAxe Beta Tester Gold Contributor
    - 335Coins
    I just started up my sim rig after a year and found Simtools has an upgrade!!! Its much easier to navigate than the old Simtools and I managed to set up my simulator in half the time....
    My only issue now is that F1 2022 plugin will not launch EA F1 2022 (Half price on EA). When I run the plugin it launches a Steam video rather than the F1 game on EA. I added F1 to Steam as a Non Steam game but no joy. Any ideas?
    Many thanks....
  11. yobuddy
    51,523Coins
    Hi @seb414,
    To update a launch path for a game plugin, simply drag and drop the games exe or shortcut on the banner for the given game plugin.
    Take care!
  12. SteULM
    SteULM Active Member
    601Coins
    Hi all, I have installed and registered the v3 configured the com interfaces and the axes with the settings of the v2 but I have no movement with the axis test and not even starting the game. Can you help me understand where I'm wrong, thanks.
  13. SteULM
    601Coins
    I inserted an image of the Motion setup but I also configured the other axes ...
    Logically with the v2 with the same settings everything works correctly.
  14. SteULM
    601Coins
    Ok solved, I deleted the space in the string on "Interface / Output" (Axis 1a in Axis1a) and the axes now move ....
    Only the movements don't match, now I'll waste some time.
  15. SteULM
    601Coins
    I can't get the six axes to work at the same time using the image setup I posted earlier, only one axis works .....
    :sos
  16. yobuddy
    51,523Coins
    Please remove the spaces buddy, Example... <Axis1a><Axis2a>
    Also, your sending both with an 'A', I'm not sure what hardware or sketch your using, but i bet one should be... B<Axis4a>
    153,722Coins
    From the rest of the settings it looks likely SMC3, so as you say it should be this format: [A<Axis1a>][B<Axis2a>][C<Axis3a>]
  18. SteULM
    601Coins
    Thanks for the help, indeed with v2 (SMC3) I have:
    [A<Axis3a>][B<Axis4a>]
    [A<Axis5a>][B<Axis6a>]
    in the rush to try v3 I made this mistake, also due to lack of experience......
    Thank you my friends, I'll try everything tomorrow and I'm sure I'll get there!!
    :thumbs
  19. SteULM
    601Coins
    I was too curious and I immediately tried ......
    Works great!!!
    Thanks to the "legendary" yobuddy and the "indefatigable" noorbeast.
    hug::cheers:thumbs
  20. SteULM
    601Coins
    In Capture Min\Max it seems that only Traction Loss is received and mom axes move while in test they work.....
