SimTools v3 Public Beta
  1. noorbeast
    153,764Coins
    +11,149 / 57 / -2
    Why does Roll Max have a non numerical setting?
  2. SteULM
    SteULM Active Member
    601Coins
    I do not know....
    I try in testing and everything works but if I play nothing moves and in capture I find what you see in the picture and only the Traction Loss value moves.
  3. SteULM
    601Coins
    If I launch LFS instead everything works....
  4. SteULM
    601Coins
    I uninstalled v3 and reinstalled everything and now everything seems ok....
  5. MGFarao
    MGFarao New Member
    Madrid
    - 85Coins
    DC motor, JRK
    Hi everyone ive tried to look for this info but im a bit lost,
    I need some specific things for my rig to work so I made a custom interface plugin.
    How can I import that plugin in V3, in simtools v2 you could import through the plugin updater but I cant find info on how to do it on the new software. thanks in advance!
  6. yobuddy
    51,526Coins
    You can't use v2 plugin in v3 unfortunately.
    And the v3 interface api is not out yet, but will be soon.
    But to answer your question, you can just drag and drop plugins into the main v3 gui.
  7. MGFarao
    MGFarao New Member
    Madrid
    - 85Coins
    DC motor, JRK
    thanks for the reply yobuddy!
    So as I understand ill have to wait until the api for the V3 is out to write my own plugin? any time frame for this? im really looking forward to using V3
  8. yobuddy
    51,526Coins
    Afraid so. :oops:
    It's next on the to-do list.
    w00t! :thumbs
  9. MGFarao
    MGFarao New Member
    Madrid
    - 85Coins
    DC motor, JRK
    Ok great!
    one last thing, where can I check to see when the API is available?
    thanks again for the reply!
  10. yobuddy
    51,526Coins
  11. Krzysztof Dej
    Krzysztof Dej Active Member
    Poland
    1,100Coins
    I recorded a video. In Smc3Utils u can see on port 7 u have one motor for belt tensioner. My primary 2dof is on port 4. When I'm turn on sim tools 2. And go to output testing my motor in 2nd interface work. When I'm turn in game it work also and sim tools work. On sim tools 3 beta. When I create 2nd interface and test it. It works well. But problem is when I try turn in game or try game test. Then sum tools crashes. Also in different game. I try on rbr and dr2.
  12. yobuddy
    51,526Coins
    The Interface connected to com 4 makes me think the com ports are locked up for some reason.
    I would suggest rebooting the PC and trying v3 again right after reboot.
    (Pleas try v3 right after restart without running v2 or the smc3 app.)
    Chat soon!
    Dustin
  13. yobuddy
    51,526Coins
    Also, maybe click save in axis assignments before clicking test settings.
    We will figure it out buddy!
  14. Krzysztof Dej
    Poland
    1,100Coins
    Hi. I must test it more, becouse one time when I start dr2 without Smc3Utils it was working. But when later I play in assetto sim tools 3 crashed with 2nd profile. I also see Different game profiles have differently assigned axis directions and another suggestion is can u soft start test axis also :)
  15. gigi
    gigi Active Member
    919Coins
    2DOF, JRK, 4DOF
    good evening everyone I want to show a problem that I discovered today trying to set up vibe. after setting up my sound card i try to select an effect but as soon as i go into test simtools it closes. watch the video I attach. What do you think could be the problem?
  16. yobuddy
    51,526Coins
    @gigi,
    When you click test settings you go to the upper right and move the slider around,
    And the round x button to stop testing.
    My guess is you were able to turn on the tester 2x and it crashed.
    I will take a look buddy.
    Thanks for the report!
  17. yobuddy
    51,526Coins
    Only one app can use the port at a time.
    So if Smc3Utils is running, simtools can not connect to the interface.
    Take care!
  18. HASAN1453
    HASAN1453 Member
    Vr arcade owner
    VANCOUVER
    424Coins
    2DOF, 3DOF, Motion platform
    Hello everyone. Hope all good. I am wondering about video ride recorder/creator player within v3. Will we be able do 360 YouTube vr rides with our simulators?
    thank you
  19. gigi
    gigi Active Member
    919Coins
    2DOF, JRK, 4DOF
    Hi Yobuddy, thanks for your reply
    yes indeed in the video you can see that I pressed the "test" button twice. But I tried many times even pressing the key correctly (once) and it always crashes.
  20. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    give this a try @gigi
    FYI thats with headphones selected to play sound as i dont have buttkicker setup at the moment lol
