SimTools v3 Public Beta
  1. Milt
    Milt Member
    USA
    32Coins
    Thanks!! I'll try it when I get home tonight!
  2. gigi
    gigi Active Member
    917Coins
    2DOF, JRK, 4DOF
    Thanks Daguru, I will try this evening and let you know.
  3. Avee
    Avee Virtual Pilot
    1,167Coins
    Any prognosis on when plugins for flight simming will become available?
  4. yobuddy
    51,227Coins
    Hi Guy's.
    I have the family out for thanksgiving, and will be back at it this weekend.
    Would be sweet, and I go back and forth on how this should work.
    I'm afraid I don't have enough time with VR gear to know what will work best yet.
    But it would be cool, if you could send out a general video stream, and any number of vr headsets could tap into the feed.
    I have been playing with android apps a bit lately, so as i learn more, who knows.
    Would be cool if it worked with the cheaper android headsets I think.
    If we can stream 360 video to VR headsets with vlc, then I believe we could do it fairly easily.
    I did not write all the plugins myself, so with some of them I need to start over, or reach out to the original authors of the plugin. I have not heard back from some people yet, so hard to know for sure.
    I would like to play with some sort of remote profiler next.
    I would like to try to make it work with android and iso this time.
    (As we all have phones or tablets sitting around.)
    Anyway,
    Take care everyone and chat soon!
  5. seb414
    seb414 New Member SimAxe Beta Tester Gold Contributor
    - 335Coins
    Hi, many thanks....
  6. gigi
    gigi Active Member
    917Coins
    2DOF, JRK, 4DOF
    Hallo guys,
    I post a new video in wich you can see that I turn on test only one 1x and simtools crash
  7. yobuddy
    51,227Coins
    @gigi,
    May I see your interface settings for vibe, your sound card setup.
    Just trying to figure out where to look is all.
    Chat soon,
  8. VFX Pro
    VFX Pro Member
    Los Angeles
    425Coins
    Motion platform, 6DOF
    I really hope that SimTools 3.0 will allow instantly disable an axis like SimRacingStudio instead of having to shut down a game. remove the assignment, reboot, etc... Such feature is so useful when trying to adjust/configure settings.
  9. VFX Pro
    VFX Pro Member
    Los Angeles
    425Coins
    Why can't Simtools v3 window be resizeable? I have a 5120x1440 resolution. The entire UI should be responsive and works at all resolution is possible. Thanks. Can't wait to be allowed to create skins and replace icons, colors, etc...
  10. yobuddy
    51,227Coins
    We could have axis enable-disable buttons in the plugin, totally an option.
    Right now you just click the stop button, adjust and click play again. (all while the game is running and without a reboot), even v2 does this.
    To keep things easy for plugin writers, we decided to stick with winforms, and winforms does not do re-sizing very well. Honestly, It's enough work just getting all the different DPI settings working.
    We can see what I can do, but I need the gui completely done first before I can take a look.
    Take care,
  11. VFX Pro
    VFX Pro Member
    Los Angeles
    425Coins
    I didn't even know or notice the on/off button! LOL. I will try that next and see if I can turn off an axis to fine tune motion without having to quit the game... Great tip.
  12. Hermant Alexis
    Hermant Alexis Member
    238Coins
    Finally mounting a new PC for assetto corsa competizione. Happy to test this new release! Let's go!
  13. Wagnard
    Wagnardsoft
    Canada, Quebec, Mirabel
    5,216Coins
    @yobuddy Tried updating the XML today for Elite Dangerous but it seems to not work, the Simtools doesn't see the update.
    EDIT: NVM it seems it took a few minutes before it see it.
  14. yobuddy
    51,227Coins
    It takes about 15 minutes for the files to migrate thru the system.
    Then after a SimTools restart, they should come down as updates.
    Thanks for the update!!
  15. Krzysztof Dej
    Krzysztof Dej Active Member
    Poland
    1,100Coins
    Hi I also noticed that when u press test axis there is no soft start! When u press stop test it's parking correct. But on start not working soft. Cheers
  16. VFX Pro
    VFX Pro Member
    Los Angeles
    425Coins
    I know Simtools auto detects the game, but can v3 auto detect the car I'm using and change it's settings accordingly like SimRacingStudio does?
  17. yobuddy
    51,227Coins
    If the games telemetry data supports the current vehicle, yes.
    I will take a look.
  18. Pims578
    Pims578 New Member Gold Contributor
    45Coins
    3DOF, SCN6, Motion platform
    Sorry
    hello i have a problem with the v3 version, i have a prosimu t1000 3m, with the old simtools v2 version i had to set the 3rd jack to extra1 but i can't find it in the v3 version? moreover the cylinders do not work correctly in the game
    barely moves 5% to 10% of the stroke?
  19. yobuddy
    51,227Coins
    Traction Loss is Extra1 in v2 and v3 for iRacing.
    Have you tuned in the max/min settings for the game?
    Take care,
  20. Krzysztof Dej
    Poland
    1,100Coins
    Hi. I found a time to complete the belt tensiiner and I continue to have a problem with sim tools 3 turning off ,when I have 2 interfaces. It shuts down despite whether one is unplugged or both are plugged in. It shuts down in every game. But when I give the interface test it works. When I give a test in a game plugin it shuts down. In sim tools 2 work normally side by side. I do not enable Smc3Utils. Any ideas what to check? I was also disappointed that only in rbr again os surge works weird. In Dirt rally or assetto all is smooth and once set it works great and in rbr it works as if the signal is truncated. I only have the smooth filter at 15 percent. When I fight capture max min it works great. When I save the parameters it works as if the parameter is too high, making the motion too weak. When I lower the parameter manually it is still not the same when I turn on capture
