value1
Automobilista 2 Plugin 2020-04-05
SimTools game plugin for Automobilista 2
  1. Brett Horton
    Brett Horton Active Member
    Program Manager / Pilot
    Tampa FL
    118Coins
    Just upgraded my rig to the RS150 linear actuators using the Thanos controller. All is working well with all sims except AMS2. I can select under shared memory "project Cars 1" and motion works fine, but simhub (bass shakers and data screens) does not work. I can select "project cars 2 and simhub works but no motion.
    I assume there is a UDP port forwarding I need to do, but unsure how to? Any help would be appreciated guys!
  2. Robdog
    Robdog Member
    Newcastle, Australia
    104Coins
    3DOF, JRK
    I have managed to get the motion working again by changing shared memory from Project Cars 2 to Project Cars 1. Thanks for the help.
  3. Michail
    748Coins
    So I want to ask something, as Iam using Simhub for the Bass Shaker before the motion rig, I allready setup the telemetriy without ui:pcars in the system settings. shared memory to project cars 2, off and UDP Protocol to Project cars 1.
    Even when I start with -ui:pcars the ui is not changing and I can not find anything else.
    I thought, that the reason of no motion was the 0 values at the tuning center... So I am trying the quotet values above. no changes. Have anyelse theese days similar issues?
    153,691Coins
    Running SimHub and SimTools can create a port conflict, see the SimHub port forwarding as a workaround: https://www.xsimulator.net/community/faq/simhub-port-forwarding.356/
  5. Pino Pistolidas
    Pino Pistolidas New Member
    Netherlands nijkerk
    174Coins
    I had the same issue as @Brett Horton and @Michail
    Try the following:
    Shared memory: Project cars 2
    UDP Frequency: 9
    UDP Protocol Version: Project cars 2 (or Project cars 1 both worked for me)
  6. Brett Horton
    Tampa FL
    118Coins
    Perfect!
    Fixed my issues as well.
    Thanks so much
  7. Michail
    748Coins
    Thank you mate! work fine I activate in simhub port forwarding also.
  8. dirkdig123
    dirkdig123 New Member
    usa
    7Coins
    Hey all. I'm having trouble patching the game. All of my other settings or correct, including the shared memory part, but for some reason I cant get it to successfully patch. Any advice or something i may be missing?
    153,691Coins
    What patch path is used and what patch error message do you get?
  10. MasterYoda
    MasterYoda Active Member Gold Contributor
    Portland/USA
    322Coins
    2DOF, SCN5
    Guys,
    I need some help on this one since I have never seem this before.
    I got game telemetry data on the Tuning Center (pic below), but no motion.
    What could that be?
    My in game settings are:
    UDP Frequency: 9
    Thanks for any help.
  11. GWiz
    GWiz Active Member
    Dentist
    Aberdeenshire, Scotland
    1,509Coins
    You just need to have some max and min values. I'm assuming you are using the DOFReality files as these don't have max/min for AMS2 for some reason. Either copy across the values from Project Cars 2 or capture Max/min values yourself after running a lap without crashing. Save new settings and then you'll be sorted.
  12. MasterYoda
    Portland/USA
    322Coins
    2DOF, SCN5
    Not sure what dofreality is, but the max/min capture did the trick. Thanks a lot.
    Thank you!
  13. VFX Pro
    VFX Pro Member
    Los Angeles
    431Coins
    Motion platform, 6DOF
    How can someone tell if a plugin will work with SimTools3? Is it a separate download in the forum?
  14. Salvatore21872
    Salvatore21872 New Member Gold Contributor
    Technician
    Australia
    - 90Coins
    Hi try to bring up your tuning page and see if it generates angles follow the tuning method by recording new percentages
  15. Salvatore21872
    Technician
    Australia
    - 90Coins
    UDP 9 is very slow, 1 is ideal
  16. Salvatore21872
    Technician
    Australia
    - 90Coins
    I am using the patch that is downloadable from this site
  17. VFX Pro
    VFX Pro Member
    Los Angeles
    431Coins
    Can someone please this plugin, so the motion telemetry is not sent while the game is in replay mode? It's insane trying to watch a replay while I'm being thrown around like crazy and can't click the mouse to anything due to motion. Iracing and ACC plugins don't have this issue and respect the "pause or replay mode".
    Thanks,
    Ben
  18. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    Hi @VFX Pro i just tested AMS2 with Simtools v3 and i get no motion in replay, have you tried Simtools v3 beta yet?:thumbs
  19. VFX Pro
    VFX Pro Member
    Los Angeles
    431Coins
    That is good news, the problem is that I can't use ST v3.... ProSimu refuses to provide the plugins I need until STv3 is fully released... I can't be part of the beta. :(
  20. VFX Pro
    VFX Pro Member
    Los Angeles
    431Coins
    I'm grateful for your motion plugin. Can you please make a small update to it so it respects the replay value? I'm getting shaken to my core trying to view replays or after the race is over (ie replays).
