SimTools v3 Public Beta
  1. yobuddy
    51,547Coins
    SimTools V2 works with your sim and it works side by side with v3.
  2. TomKlash
    TomKlash Member
    FRANCE
    425Coins
    2DOF, 3DOF, DC motor, SCN5, Arduino
    I want to add absolut value of sway, if the value is positive ok, if the value is negative I must convert it to positive value. Is it possible to do that with simtools ?
    Thanks.
  3. yobuddy
    51,547Coins
    Click the 'Dir' box by the dof in Axis Assignments, and it will flip the direction of the axis.
    Take care,
  4. yobuddy
    51,547Coins
    Sorry I miss understood the question.
    What are you trying to do here?
    Thinking...
    153,950Coins
    +11,160 / 57 / -2
    I am guessing what you mean is to clip values, as @BlazinH did with modified SMC3 code for Gseat: https://www.xsimulator.net/community/faq/modified-smc3-code-for-g-seat.325/
  6. 02c5zo6
    02c5zo6 New Member
    16Coins
    We are unable to get v2 to work on Windows 11.
    153,950Coins
    +11,160 / 57 / -2
  8. Michail
    748Coins
    Do we have any news about the motion cancelation plug-in in v3? This was mentioned in the motion cancelation thread.
  9. yobuddy
    51,547Coins
    I'm afraid not.
    Trying to do motion cancellation directly from the same computations that run the sim simply does not work in my tests. I think we really need a non-drifting way to know exactly where the sim is at any time.
    I think the best approach, may be to use something like open track to get a non-drifting solution.
    I just have not had any extra time for testing something like this.
    Take care,
  10. TomKlash
    TomKlash Member
    FRANCE
    425Coins
    Hello everyone, happy new year !!!
    I read this post but I think it's not that i want to do. This custom SMC3 code allow to cut negative values but I need to convert it in positive value.
    In simtools v3 it's possible to invert value but not to take absolut value. Maybe you have a trick to to do it in Simtools.
    Thanks.
  11. yobuddy
    51,547Coins
    You can control the direction of the axis here:
  12. bruno1210
    bruno1210 schumi06
    103Coins
    Hello, the updates for f1 games are perfect with the 2022 format for the 2022 games just a little problem with simhub, simtools v3 alone works but when I turn on simhub works and simtools closes.
  13. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    Hi @bruno1210
    I have Simhub and Simtools v3 working fine together using these settings
    Simhub use forward udp packets to Simtools port 4123
    Then in game settings like this
    Hope this helps :thumbs
  14. bruno1210
    bruno1210 schumi06
    103Coins
    I will test thank you .
  15. bruno1210
    bruno1210 schumi06
    103Coins
    simtools closes when launching the game but the telemetry works on simhub weird pity thank you.
  16. bruno1210
    bruno1210 schumi06
    103Coins
    Simtools closes with all games ! setup
  17. TomKlash
    TomKlash Member
    FRANCE
    425Coins
    I need absolut value not invert. Is there fonction abs() in simtools ?
  18. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    @bruno1210 i had that the other day the only fix i found at the time was to uninstall then reinsatall Simtools and yes pain in the butt to reinstall all plugins and set them back up, but good job i took screenshots of my axis and max min settings lol
  19. yobuddy
    51,547Coins
    In v3, once a game is setup and configured properly for your sim, you can go to options / export wizard and export a custom plugin. The Custom plugin can hold all your configurations for the game, and then a drag and drop installation into SimTools will 100% re-set up the plugin for you.
  20. yobuddy
    51,547Coins
    You can only have 1 application accessing the games telemetry port at a time.
    So whichever app you start first will work.
