value1
Euro Truck Simulator 2 Plugin 2.0.2.2
SimTools game plugin for Euro Truck Simulator 2
  1. kiennt
    kiennt New Member
    - 70Coins
    4DOF
    I got an error after patching the game, help me
    153,740Coins
    That message is not an error, it is asking you to select the file directory where ETs2 is installed, so it can patch the game.
  3. kiennt
    kiennt New Member
    - 70Coins
    4DOF
    Thank admin i has been doing
    153,740Coins
    Can you please post pictures of all of your settings, including the Tuning Center while ETS2 is running.
  5. pabstar26
    pabstar26 New Member
    103Coins
    4DOF
    SOLUTION FOR ETS2 / ATS MOTION !!!
    Hi all, it's my first post since I don't use SIMTOOLS but LOGYKAL for now.
    BUT, I found this thread because my 2-DOF SCN6 motion rig wouldn't work with ETS2 nor AMS...
    I tried everything here and my Logykal Lince would recognize ETS2 or AMS was in use but I couldn't obtain any telemetry, and I wouldn't see the SDK prompt at startup.
    I used to put my plugin alongside the "eurotrucks2.exe" file like the other dll's, like recommended, but nothing worked.
    After a lot of trial and error, I created a "plugins" folder inside the x64 folder to put my Logykal plugin and IT FINALLY WORKED !
    Just thought my experience might help some others.
    THE SOLUTION WAS (for me at least) :
    - Create a "plugins" folder like this /{ETS2 install dir}/bin/win_x64/plugins
    - Put the motion plugin (dll) into this newly created folder
    - Launch the game
    - ENJOY !
  6. el_marius90
    el_marius90 Simracer simulador 2dof
    Electricista
    Madrigueras
    - 928Coins
    hello, did you manage to make it work with simtools? I can't get movement in the motors
  7. Rodrigomarcos1978
    Rodrigomarcos1978 New Member
    Brasil
    103Coins
    Hello
    I had this plugin installed and working normally. A friend complained that he was having trouble patching Simtools 2.6.
    I unpatched that plugin on my computer and started getting the same error and I can't resolve it either. Can anyone help?
    Windows 10, simtools 2.6.
    I already tried removing the plugin from the Simtools folder and reinstalling it, I selected all possible folders of the installation directories at the moment to do the Patch, but I only get this error from the attached image.
    THE SELECT PATCH IS NOT VALID FOR PATCHING !
    Help !!
    153,740Coins
    If I recall correctly, as I am away from my computer, you need to select the ETS2 folder in My Documents where it stores configurations as the patch path, not the game install folder.
  9. Rodrigomarcos1978
    Brasil
    103Coins
    Hello..
    The patch is made in the game's installation folder. It's not My Documents. There's some other kind of problem anyway.
    I even managed to perform the Patch in the Simtools 3.0 version, where it also asks for the installation path and I select the Steam folder where the game is installed, without errors.
    However in version 2.6, this error occurs.
    However I wouldn't want to use the Simtools 3 version as it still has some other drawbacks due to it being a Beta version.
  10. yobuddy
    51,524Coins
    I believe they removed the "plugins" folder from the win_x86 and win_x64 folders.
    Should look like win_x86/plugins, and win_x64/plugins.
    Creating these folders should allow the patching to work.
    The v3 version of the plugin is better, what drawbacks are keeping you from running it?
    Take care,
  11. noddyier
    noddyier New Member Gold Contributor
    - 384Coins
    any solution for 2.6 ??
    i try create plugins folder
    win_x64/plugins in steamapp / ets2
    but still cannot patch
    153,740Coins
    Can you please be more specific about your issue, including screenshots.
    As per my earlier post is this what you have done, or can you please be specific about what you have and have not done:
  13. DE CASTRO
    DE CASTRO Gaby SimAxe Beta Tester Gold Contributor
    Cahors France
    611Coins
    2DOF, 3DOF
    The plugin is installed in the ets2 folder in the my documents directory and works perfectly.
    Not in the game installation folder for me.
  14. Viktor_s
    Viktor_s New Member
    Russian Federation
    - 32Coins
    Hi there.
    Anyone resolve the problem with incorrect SWAY telemetry data?
    I use SimTools v3.
  15. Fahim
    Fahim Member
    553Coins
    What do you mean incorrect SWAY telemtry? Can you please give more detail.
    I could do with knowing as I am about to purchase the MOZA truck wheel and base.
    Will be using simtools and travel on actuators is pretty large.
  16. Viktor_s
    Viktor_s New Member
    Russian Federation
    - 32Coins
    Read the post #95 in this tread. The problem is still exist.
    I use Yaw-Rate channel instead SWAY till another solution will appears.
  17. Fahim
    Fahim Member
    553Coins
    So basically the sway is broke but it is possible to fix by making a new plugin or adjusting some values from the old plugin?
    so it is possible then, if so i will still purchase the steering wheel and base and maybe try my self to learn how to create plugin.
  18. Fahim
    Fahim Member
    553Coins
    I nearly broke the simulator by using YAW on 100% lol.
    I did a full lock with a curtain sider lorry and god knows what happened. I heard a big bang bang and the simulator went crazy.
    4DOF; back two actuators are using sway. So I removed sway and used YAW instead. One obviously "INVERTED" like we do when we use sway.
    Can you please tell me why this would have occurred.
  19. Fahim
    Fahim Member
    553Coins
    Does Yaw was as good as the sway. good enoughlike?
