SMC3 Arduino 3DOF Motor Driver with SoftStart
Discussion in 'SimTools compatible interfaces' started by BlazinH, Jan 4, 2017.
  1. iLLuac4
    iLLuac4 Active Member
    891Coins
    My first two steps to troubleshoot would be to try bound rate 460800 and lover the com port to less than 10.
    Bound rate depends on the serial chip being used on the arduino board. If it is ch340 then 460800 would be a way to go.
    CH340 supports common baud rate: 50,75,100,110,134.5,150,300,600,900,1200,1800,2400,3600,4800,9600,14400,19200,28800, 33600,38400, 56000,57600,76800,115200,128000,153600,230400,460800,921600,1500000,2000000
  2. Design89
    Design89 Member
    Netherlands
    214Coins
    I uploaded the soft start to my Arduino.
    Startup the Arduino and only motor 1 and 2 are moving forward, this is what I have in SMC3
    Motor 3 is not turning at all..
    What could be the problem?
    153,950Coins
    +11,160 / 57 / -2
    C
    Check your wiring, in particular make sure your motor is not wired backwards.
  4. Design89
    Design89 Member
    Netherlands
    214Coins
    What exactly do you mean?
    Reversing the + and - of the motor only makes the motor turn the other way. This is what the IBT2 does, isn't it?
    Could it be that the wires need to be connected differently than described?
    The Arduino code states:
    o|7 Motor 3 ENB
    o|6~ Motor 3 ENA
    o|5~ Motor 2 ENB
    o|4 Motor 2 ENA
    o|3~ Motor 1 ENB
    o|2 Motor 1 ENA
    3, 5 and 6 are PWM.
    But the connection says:
    ENA ----> IN1/RPWM
    ENB --+-> EN1/R_EN
    +-> EN2/L_EN (ie connect ENB to both R_EN and L_EN)
    PWM ----> IN2/L_PWM
    ENA should be PWM? Or not?
    153,950Coins
    +11,160 / 57 / -2
    What I meant is as seen here at 26:04 onward: https://www.xsimulator.net/community/threads/new-video-on-explaining-what-i-know-about-smc3.17092/
  6. Design89
    Design89 Member
    Netherlands
    214Coins
  7. Arta Yasa
    Arta Yasa Member
    968Coins
    Hi bro i try your code and set ssloop to 100 until 500 but first start still same very fast.
    And also when i set pwmmax exsample 150, and save the value after that i close the smc3 and open again the pwmmax become 11 sir, its bug or i wrong setup sir?
  8. motiondynamics
    motiondynamics Member Gold Contributor
    1,235Coins
    2DOF, 3DOF, DC motor, AC motor, SimAxe, Arduino, Motion platform, 6DOF
    The same thing happens to me too: I set SSloop to 1000, soft, linear movement. When I open SMC3Utils, in PWMmax the value of 150 becomes 12.
    It's a bug in the code, it would be good for the creator to fix it..
    However the PWMmax value, even if I read "12" is 150.
  9. Ronan Design
    Toronto, Canada
    1,716Coins
    Any news on the fix for the values not saved bug? Does it save values for everyone and the bug was a glitch or does it really not save anything for everyone? I'm trying to figure out which SMC3 mod I should use for my new 6DOF build, and I'd like a soft start...
  10. Gadget999
    12,162Coins
    somebody did code a soft startup code that should work
  11. Ronan Design
    Toronto, Canada
    1,716Coins
  12. michel123
    michel123 Member
    cadre sncf
    lezignan-corbieres
    180Coins
    Hello, I have not yet found a corrected version for the entries which do not register correctly in the SMC3 utility, I returned to the original SMC3...
    When I look at the code, there is not much to modify, it adds a loop which increments the pwmax data, and I think that the utility does not like that, we read and modify one of these values, it therefore gives a distorted result... well I think that's it....
    Has anyone found the solution?
  13. iLLuac4
    891Coins
    Hi. I have tried to identify the change and implent it into the 1.7a version so it should now read the values saved inside arduino from SMC utility for all three motors. Please not that I have not tested it yet, so if you are willing to give it a try.... Please report back if the fix is working otherwise I will remove it.
  14. iLLuac4
    891Coins
    Any feedback from those who download it? Does it work now with PWMmax?
  15. michel123
    michel123 Member
    cadre sncf
    lezignan-corbieres
    180Coins
    Yes it's perfect ! thank's !!!
  16. iLLuac4
    891Coins
    Tnx for feedback.
