SimTools v3 Public Beta
  1. Brett
    Brett Member
    Engineer
    Carrum Downs Victoria Australia
    156Coins
    2DOF, 3DOF, JRK
    Awesome job so far. You've added so many new plugins lately. I'm just hoping that two existing v2 arcade game plugins will get added to v3 eventually; Daytona and Outrun 2006. Cheers.
  2. TomKlash
    TomKlash Member
    FRANCE
    425Coins
    2DOF, 3DOF, DC motor, SCN5, Arduino
    M motor (seat surge) L motor (upper back seat surge) and R (upper back seat sway) are independent.
    So I want to apply a pourcentage of sway (10-15%) that is apply on R motor on the L motor like a surge, to create a compression that my arms on steering wheel but I need only positive value to do this.
    If motor R move upper back seat on right side or left side I need to move upper back seat in front side in this two cases. So I need to take positive value without modification but I need to inverse negative values. It's the "absolut value".
    Otherwise if I R motor move upper back seat on right (positive) L motor move upper back seat on the front side (OK). If motor R move upper back seat on the left (negative) also L motor move upper back seat on the rear side ( NOK).
    I hope It's most clearly for you.
  3. yobuddy
    51,555Coins
    I see what you are trying to do, I will take a look tomorrow at a solution for you.
    Take care,
  4. TomKlash
    TomKlash Member
    FRANCE
    425Coins
  5. Mu-KwangKim
    South, Korea
    - 689Coins
    Of all the systems I have,
    In the Korean Windows 11 environment, automatic updates do not solve the menu selection problem.
    I Uninstall & Reinstalled SimTools, and it was resolved.
    Refer to it.
  6. bruno1210
    bruno1210 schumi06
    103Coins
    impossible d'activer sur windows 11
  7. bruno1210
    bruno1210 schumi06
    103Coins
    can't activate on windows 11
  8. bruno1210
    bruno1210 schumi06
    103Coins
  9. hannibal
    hannibal Active Member
    4,492Coins
    im upgrading my linear actuators.. going 600mm from 500.. hope to play with simtools 3 soon
  10. yobuddy
    51,555Coins
    So what happens for you, as others are activating fine on win11.
  11. bruno1210
    bruno1210 schumi06
    103Coins
    my license is active with win 10 I updated win 11 simtools v2 works but for simtools v3 it asks me for activation?
  12. yobuddy
    51,555Coins
    @bruno1210,
    You still have not told me what happens when you try to register buddy?
  13. bruno1210
    bruno1210 schumi06
    103Coins
    Hello everyone here is my activation problem .
  14. yobuddy
    51,555Coins
  15. bruno1210
    bruno1210 schumi06
    103Coins
  16. flipflop
    flipflop Member Gold Contributor
    Swansea
    382Coins
    3DOF, Arduino
    Hi, love the new simtools 3.
    I had a problem with it today.
    On loading, it offered to update, that gave a message to say it failed. Upon opening the plugin manager, it showed a download arrow on f1 22. I hit to download and the plugin disappeared. I thought, no problem, I will just download it again only to find it shaded out in the plugin manager saying it is already installed. It won't let me delete it either. The link to the zip file takes you to the link download but any ideas how to get it back?
  17. yobuddy
    51,555Coins
    I guessing you are talking about a update to simtools?
    If so, seems your antivirus stopped the update. Maybe add SimTools to the whitelist for your AV.
    To fix it thou, you can simply run the v3 installer again and install over the top of what you have now to get the update.
    Let me know how it goes.
  18. flipflop
    Swansea
    382Coins
    3DOF, Arduino
    OK will do. Thanks for getting back to me so quickly. I assumed the update was just for the f1 plugin, but that could well be the problem. Thank you for your help.
    It was strange that the plugin disappeared and yet showing in the plugin manager. And that there was no ability to use the delete symbol.
    I will let you know how I get on.
  19. Mu-KwangKim
    South, Korea
    - 689Coins
    I confirmed that the UDP signal is normal without changing the local language setting. It's so good. So~~~ Good.
  20. flipflop
    Swansea
    382Coins
    3DOF, Arduino
    Did a reinstall of simtools 3.0 over the top and it worked great. F1 2022 plugin appeared back in my list of installed plugins. Well chuffed
    Thanks for the help.
