SimTools v3 Public Beta
  1. toyvonen
    toyvonen New Member
    - 115Coins
    3DOF, SCN5, SCN6
    Hi
    First of All Thanks for keeping providing the best motion/haptic software for só long!
    I think V3 is really a big improvement in all areas.
    Im having a general fantastic experience
  2. toyvonen
    toyvonen New Member
    - 115Coins
    3DOF, SCN5, SCN6
    Hi
    Im having a general fantastic experience in all but one title... RBR!
    I don't know if it's just a problem of the RBR RSF plugin, or general...i have seen reported here some issues, tried to follow them... UDP activated and not, diferent port UDP numbers...but i still keep getting strange motion...kind of muffed, slow, not clear fast and crisp as in every other games, and like i had before.
    Can you help me, do you think is only related to certain non original RBR versions, or maybe NGP physics related...do you intend to support plugins like RSF, wich is now the more used by RBR comunity?!
    As anyone have profiles that work OK and that can Share?!
    Another less important thing...is it possible to adjust Parking, but that the new position is mantained during playing, and not just when off?!
    Thank you very much for All your work and support!
  3. vr_engineer
    vr_engineer New Member
    24Coins
    2DOF, 3DOF
    hello. the application stopped running games in virtual reality. If you run it from steam everything is fine.
  4. Krzysztof Dej
    Krzysztof Dej Active Member
    Poland
    1,110Coins
    For me with v3 after update is like smoth filter 20. But not tested much i play v2. Try to disable udp in launcher and try to patch game every time u play. I have good movement. Spend lots of time to fight with rbr. I think rsf update also have something at this point
  5. yobuddy
    51,002Coins
    Adjust the max/min values for the game
    It's already been confirmed working buddy.
    I don't understand as your not parked when your playing a game.
  6. Nix Park
    Nix Park New Member
    SW Engineer
    Republic of Korea
    - 53Coins
    3DOF, Motion platform
    First of all, thank you for the V3 update.
    I used to use Thanos-AMC (AASD15A) well using 'Simtools 2.5.1'.
    However, it worked normally only when the language & region setting was set to English (USA).
    I installed 'Simtools 3beta' this time, but it seems that data is not being sent and received from Thanos Board.
    You can connect to the 'AMC-AASD15A Config Tool (Addons)', but it does not work.
    Is there anything I'm missing?
  7. yobuddy
    51,002Coins
    My guess is your Thanos Boards needs a firmware update?
  8. itsumairu
    itsumairu Active Member
    Psychologist
    Indonesia
    440Coins
    hello.. after I finish my traction loss project I give a try on V3, and before its works fine, but now I cant get it right.
    in V3 my traction loss always move to the right side and stuck there, no motion whatsoever.
    here my settings
    I try to capture but the value keep changing to 90 for roll and pitch, and for TL its random number.
  9. yobuddy
    51,002Coins
    This plugin is being worked on right now.
    Please give us a bit to get it strait.
  10. Michail
    Michail Member Gold Contributor
    717Coins
    MyGames\F1 22 Folder ist empty, only a folder "hardwaresettings" is there.
    Maybe the race "very short" is not enough???
    When I try to patch, get error not valid folder or location
  11. Tiago Dias
    Tiago Dias New Member
    89Coins
    Hey guys, I'm new to this and I just bought a njmotion compact-r as I'm not getting it to work with the new simtools program, any njmotion owners who got it?
  12. lVlemphiz
    lVlemphiz Member Gold Contributor
    Automotive Engineer
    252Coins
    3DOF, AC motor, SCN6
    Hello
    I'm trying to setup a 4 actuator SFX 150 system with the THanos controller.
    I can register the motors and move the rig but when setting up the motion profile I can't seem to get my heave motion to go up and down in one series. For example; as I move the slider all the way to one side the rig will go up and down 2x before it reaches the end of the slider. Any suggestions for how to fix this?
  13. Avee
    Avee Virtual Pilot
    1,167Coins
    Hey, it seems the plugin push only yielded one flight sim plugin.
    Would it be possible to prioritize FS2020 (market leader) and XP12 (very motion platform friendly), so that flight simmers can join in?
  14. j0k3r
    j0k3r Member
    307Coins
    2DOF, Motion platform
    got a compactR too since xMas ;) what probs do you have…? Do you own a somTools license? and check that video, that helped me alot to understand the whole parameters :)
  15. yobuddy
    51,002Coins
    May I see your axis assignments, maybe I will see something that can help.
  16. yobuddy
    51,002Coins
    Where are you trying to path the game buddy?
  17. yobuddy
    51,002Coins
    @itsumairu,
    Please let Dirt Rally 2.0 update and give it another shot buddy.
    Take care,
  18. yobuddy
    51,002Coins
    To be fair, the game has 5 stand alone games in the series, so we thought it was going to be 5 plugins. :D
  19. itsumairu
    Psychologist
    Indonesia
    440Coins
    wow thats fast.
    okay, I'll test it when I home.
    thx man..
  20. yobuddy
    51,002Coins
    Be aware that you may need to remove the old and and restart simtools v3.
    Then install it again from the repo.
    Take care!
