SimTools v3 Public Beta
  1. horyoryo
    horyoryo New Member
    - 23Coins
    In previous versions the screen was broken.
      115 KB
      274
  2. horyoryo
    horyoryo New Member
    - 23Coins
    Motion doesn't work with shortcut keys shift + X no response
  3. horyoryo
    horyoryo New Member
    - 23Coins
    Start motion on Virtual Output.
    Then click stop or the motion will stop after the game ends.
    At the same time, it is a problem that the Virtual Output screen closes in conjunction
    After that, it's tedious to manipulate the Virtual Output every time.
    Please fix the Virtual Output screen so that it continues to display
  4. richdelta9
    8,850Coins
    We posted an update to F1 22 that should fix the Dash value outputs.
  5. richdelta9
    8,850Coins
    We uploaded an updated RBR plugin that should fix the surge, sway and heave issue. Also added rate values.
  6. richdelta9
    8,850Coins
    We posted an update to the Assetto Corsa plugin fixing a bug where SimTools would close when exiting a race! :thumbs
  7. Krzysztof Dej
    Krzysztof Dej Active Member
    Poland
    1,100Coins
    What it mean : added rate values?
  8. Keith
    Keith Active Member
    Electrician
    Canada, Saskatchewan
    154Coins
    The update for RBR fixed the surge issues but sway is still jerking around.
  9. ivan jack
    ivan jack Member
    412Coins
    Hello!
    After this update I found a little bug on parking side, I use the parking feature to put the rig down when exiting the game. Now when I enter the game the rig goes up in game position then goes down , games is loading , but the rig stays there. When I exit the game the profile remains stuck like the game is still loading and I need to force close and restart Simtools. I tried reinstalling the plugin but it didn't fix the issue.
    Cheers!
  10. richdelta9
    8,850Coins
    Extra 4 - Extra 6 are rate values (roll rate, pitch rate and yaw rate).
    I will take a look.
    Interesting we just added a process name to keep SimTools from closing out so nothing else was modified.
  11. richdelta9
    8,850Coins
    I just tested for this and sway is working for me as expected. Please modify your max/min values if you are getting a lot of movement and see if that resolves this.
  12. Moppi07
    Moppi07 New Member
    - 4Coins
    2DOF, JRK
    Can i use in v3 to pc like in v2.6 i mean 1 game pc and 1 motion pc ?
  13. yobuddy
    51,522Coins
    No, v3 is an all in one app.
    As PC's are so fast anymore, a 2 PC setup was deemed as not really needed anymore.
  14. Moppi07
    Moppi07 New Member
    - 4Coins
    2DOF, JRK
    Where can i select soundcard in Vibe? I have 3 soundcards in the old version i can select the Card with soundcard setup. I there any tutorial or hotow ? At the moment i use trial and error.
  15. yobuddy
    51,522Coins
    Please click the interface button in the main menu. (The same place you set up motion)
    Then look for the vibe button, on the lower left of the screen.
  16. Gilles SOUNIER
    Gilles SOUNIER New Member
    2Coins
    3DOF, SCN6
    Hello I'm new with motion. I just bought a prosimu T1000 3m. It's nice to find a community that help.
    I'm using simtools V2 with IRacing and it works well but I can't use V3.
    Is there a process to follow or something to do I missed ? I download the plugin and installed it. Simtools said it's good. I created a motion profile and when I start the game nothing works. it seems the game don't send data cause I can't capture min and max tuning.
    Thanks for help
  17. noddyier
    noddyier New Member Gold Contributor
    - 384Coins
    Hi , i'm just reinstall new Window 10
    and try to install Simtool (V2.6 and also V3.0)
    it stuck at Preparing Installation and show
    Status Not responding in the Task Manager
    i'm try disable all anti virus /install avast antivirus/ run as adminitration
    change region / language to US / reinstall window 10 again
    do i miss something ?
    Thank you in advance
  18. noddyier
    - 384Coins
    Update Some How i can install , no idea why
  19. yobuddy
    51,522Coins
    My guess is Window 10 needs to updated, and you may want to make sure .net is up to date also.
    Lastly, I would install AVG free and give it another shot.
    Take care,
    @noddyier
  20. yobuddy
    51,522Coins
    Do you have max/min values for the game?
