My first 2 DOF
Discussion in 'DIY Motion Simulator Projects' started by FLORIN ROMANIA, Jan 23, 2023.
  1. noorbeast
    153,764Coins
    +11,149 / 57 / -2
    If you disconnect all other USB devices from the computer except the Arduino, does the issue persist in SimTools?
  2. FLORIN ROMANIA
    FLORIN ROMANIA Member
    România
    810Coins
    In the usb ports I only have the keyboard and mouse
  3. FLORIN ROMANIA
    România
    810Coins
    Sometimes when I pause the game from simtools, simtools crashes
    153,764Coins
    +11,149 / 57 / -2
    If all Tuning Center values are set to 50 does the shaking stop?
  5. FLORIN ROMANIA
    România
    810Coins
    I don't understand, what tuning center? Axis assignments?
    153,764Coins
    +11,149 / 57 / -2
    This is the Tuning Center, temporarily set all Max/Min vales to 50 and let us know if the shaking stops:
  7. FLORIN ROMANIA
    România
    810Coins
  8. FLORIN ROMANIA
    România
    810Coins
  9. FLORIN ROMANIA
    România
    810Coins
    No change, do the same
  10. FLORIN ROMANIA
    România
    810Coins
    When I change this value, nothing is changed IMG_20230318_142431_edit_12411065129355.jpg
  11. FLORIN ROMANIA
    România
    810Coins
    Maybe it's something wrong with my pc
  12. FLORIN ROMANIA
    România
    810Coins
    What spec's should my pc have? Maybe he's missing something
  13. noorbeast
    153,764Coins
    +11,149 / 57 / -2
    You should not mess with the Interface settings, they are fine.
    It is unlikely to be the PC, if it runs games it will easily run SimTools.
    I suspect your issue is interference, but my previous questions are intended to rule out other possibilities.
    So, if you manually set all Tuning Center values to 50 does the shaking stop?
  14. FLORIN ROMANIA
    România
    810Coins
    If you mean roll, pitch, surge sensitivity, I tried to adjust it to 50, but no change, (in the picture it is not the change) IMG_20230318_120636_edit_13947119052558.jpg
    153,764Coins
    +11,149 / 57 / -2
    In that case I suspect it is not a settings issue, but some sort of interference, though from what I have no idea.
  16. FLORIN ROMANIA
    România
    810Coins
    When I bought the PC it didn't have Windows installed, it was installed by someone later, I don't know if he did a good job. Maybe he didn't install what he needed. Could it be the cause of simtools not working?
  17. FLORIN ROMANIA
    România
    810Coins
    Hellow, I wonder if my issues could be the arduino cable usb, the USB port or could be the pot(it's attached directly by the frame)?
  18. noorbeast
    153,764Coins
    +11,149 / 57 / -2
  19. FLORIN ROMANIA
    România
    810Coins
    I had to change the PC (the one in the video was from work), the current one is from home
  20. FLORIN ROMANIA
    România
    810Coins
    If the first time I had the monitor connected via a VGA cable, now I have the TV connected via a 4m hdmi cable, could this be a problem?
