SimTools v3 Public Beta
  1. deeph46
    deeph46 Member
    641Coins
    2DOF, 3DOF
    Hi, I tried to install ATS plugin, but when I clicked OK. It gives me notification that can't patching (wrong directory). Have tried manually copy the plugin but the plugin not showed up in Home.
    The other way ETS2 can be patched.
    152,971Coins
    +11,115 / 56 / -2
    What patch path are you using?
    Can you please post a picture of the message.
  3. deeph46
    deeph46 Member
    641Coins
    2DOF, 3DOF
    Picture attached..
  4. Mechromancer
    434Coins
    Well, I dl'ed War Thunder and set up plugin in STv3.
    I got movement in the tutorial (I've never played it). Plugin seemed to work well, but there are so many options to set up that it was quite overwhelming. I flew around for about 15 minutes and all the axi were working.
    I'll have to wait til the weekend to properly set up the myriad of options in this game.
    152,971Coins
    +11,115 / 56 / -2
    I don't have ATS but am guessing the path for patching is C:\Users\[Your User name]\Documents\American Truck Simulator\
  6. deeph46
    deeph46 Member
    641Coins
    2DOF, 3DOF
    Thanks, I don't know how or when, even don't try again few hours ago. But it suddenly ATS plugin installed..creepy
    But anyway, it is installed right now.
    BTW, is it installed where game exe is installed?
  7. yobuddy
    51,352Coins
    It's because you copied it there manually, but this will not install it correctly I'm afraid.
    I suggest you uninstall the plugin - use the little trash can.
    Then restart SimTools v3 and re-install the plugin thru SimTools v3 and you will be good to go.
    For ATS and ETS2, the patching path is the installation folder for the game.
    So when the steam version is used, look for your steam folder and then the path would be:
    "Steam\steamapps\common\GameName"
    Take care,
  8. richdelta9
    8,860Coins
    I uploaded Microsoft Flight Simulator X, Prepar3D and RaceRoom Racing Experience game plugins for V3.
    I also updated directions for some of the output values for Digital Combat Simulator.
    Let us know if you find any issues.
  9. levers
    956Coins
    Hi Yobuddy,
    I'm enjoying V3 although I'm having to rethink how I tune some of the axes. The smoothing is much better so I can reduce the applied smoothing relative to V2 making the motion more instantaneous. I thought the traction loss was missing on RF2 but capturing the values I'm now running it at +/- 0.1. I was running it at +/- 8 on V2!
    Is there a reason for this or is it just how the telemetry translates?
    Great work :thumbs
  10. deeph46
    deeph46 Member
    641Coins
    2DOF, 3DOF
    Thanks Yobuddy, I will try it again later if the installed ATS plugin not working.
    The V3 have a bug I think, Axis 1a when using Washout for Pitch the Gain will kept in value 1 if I restart the Simtools. Even I have setup for value 31. The rest are saving its values.
  11. yobuddy
    51,352Coins
    Did you click save?
    I am not seeing the problem here is all.
    Take care,
  12. yobuddy
    51,352Coins
    There was 2 traction loss outputs in the original plugin, seems we way want to switch to the other one for traction loss. Both of them seem to work, but the other one may be better.
  13. richdelta9
    8,860Coins
    I uploaded Microsoft Flight Simulator 2020 game plugin for V3.
  14. haroldjames
    Electronic Tech
    Ontario Canada
    - 398Coins
    3DOF, SCN5, SCN6
    I have a none steam version of msfs 2020 and it does not work for me. Here are the details of the error details.
    System.IO.FileNotFoundException: Could not load file or assembly 'Microsoft.FlightSimulator.SimConnect, Version=10.0.62615.0, Culture=neutral, PublicKeyToken=5f523ae7e6e1b389' or one of its dependencies. The system cannot find the file specified.
    File name: 'Microsoft.FlightSimulator.SimConnect, Version=10.0.62615.0, Culture=neutral, PublicKeyToken=5f523ae7e6e1b389'
    at MFS2020_GamePlugin.GamePlugin.GameStart()
    at MFS2020_GamePlugin.GamePlugin.Game_Start()
    at SimTools.MyGamePlugins.Cls_GamePlugins.GameStart(Int32 index)
    at SimTools.Frm_SimTools._StartEngine_Step3()
    at SimTools.Frm_SimTools.Timer_Step3Pause_Tick(Object sender, EventArgs e)
    at System.Windows.Forms.Timer.OnTick(EventArgs e)
    at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
    WRN: Assembly binding logging is turned OFF.
    To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
    Note: There is some performance penalty associated with assembly bind failure logging.
    To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
    mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.8.9139.0 built by: NET481REL1LAST_B
    SimTools
    Assembly Version: 3.0.0.0
    Win32 Version: 3.0.0.0
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/SimTools.exe
    WWIamlAtBxPUOrOznDeebCCJMEwU
    Assembly Version: 0.0.0.0
    Win32 Version: 4.8.9075.0 built by: NET481REL1LAST_C
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    System.Drawing
    Win32 Version: 4.8.9032.0 built by: NET481REL1
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    Game_PluginAPI_v3
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/Game_PluginAPI_v3.DLL
    Axis_PluginAPI_v3
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/Axis_PluginAPI_v3.DLL
    Interface_PluginAPI_v3
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/Interface_PluginAPI_v3.DLL
    Microsoft.VisualBasic
    Assembly Version: 10.0.0.0
    Win32 Version: 14.8.9032.0 built by: NET481REL1
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
    System.Core
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
    MyVibeButtons
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyVibeButtons.DLL
    MyTuningButtons
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyTuningButtons.DLL
    MyCrashButtons
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyCrashButtons.DLL
    System.Configuration
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Xml
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    Tool_AddonAPI_v3
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/Tool_AddonAPI_v3.DLL
    Default_AxisPlugin
    CodeBase: file:///C:/Users/Harry/AppData/Local/SimTools3/AxisPlugins/Default_AxisPlugin.dll
    Generic2DAdvanced_AxisPlugin
    CodeBase: file:///C:/Users/Harry/AppData/Local/SimTools3/AxisPlugins/junk1.remove
    MyCheckBox
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyCheckBox.DLL
    MyDropBox
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyDropBox.DLL
    MyRadioButton
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyRadioButton.DLL
    MyScrollBar
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyScrollBar.DLL
    MyButton
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyButton.DLL
    MyTextBox
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyTextBox.DLL
    MyOnOffSlider
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyOnOffSlider.DLL
    MyFilterButton
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyFilterButton.DLL
    MyNewName
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyNewName.DLL
    Default_InterfacePlugin
    CodeBase: file:///C:/Users/Harry/AppData/Local/SimTools3/InterfacePlugins/Default_InterfacePlugin.dll
    SCN_InterfacePlugin
    CodeBase: file:///C:/Users/Harry/AppData/Local/SimTools3/InterfacePlugins/junk1.remove
    VirtualOutputAPI_v3
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/VirtualOutputAPI_v3.DLL
    Default_VirtualPlugin
    CodeBase: file:///C:/Users/Harry/AppData/Local/SimTools3/VirtualPlugins/Default_VirtualPlugin.dll
    GameDash_PluginAPI_v3
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/GameDash_PluginAPI_v3.DLL
    Default_GameDashPlugin
    CodeBase: file:///C:/Users/Harry/AppData/Local/SimTools3/Dash/Plugins/Default_GameDashPlugin.dll
    Virtual_GameDashPlugin
    CodeBase: file:///C:/Users/Harry/AppData/Local/SimTools3/Dash/Plugins/Virtual_GameDashPlugin.dll
    CSCore
    Assembly Version: 1.2.1.2
    Win32 Version:
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/CSCore.DLL
    MyPicMenu
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyPicMenu.DLL
    MyTextBox_MinMax
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyTextBox_MinMax.DLL
    MyBannerStopButton
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyBannerStopButton.DLL
    MyRepoInstall
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyRepoInstall.DLL
    MyLoadButton
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyLoadButton.DLL
    MyTuningScrollBar
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyTuningScrollBar.DLL
    MyDashControl
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyDashControl.DLL
    MyOneClick
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyOneClick.DLL
    MyExport
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyExport.DLL
    MyProfileComboBox
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyProfileComboBox.DLL
    MyUpDown
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyUpDown.DLL
    MyRepoButton
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyRepoButton.DLL
    MyParkingLocation
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyParkingLocation.DLL
    MyDatePicker
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyDatePicker.DLL
    MyAxisLimiting
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyAxisLimiting.DLL
    MySaveButton
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MySaveButton.DLL
    MyMainMenu
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyMainMenu.DLL
    MyTopMenu
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyTopMenu.DLL
    MyNotifyMarker
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyNotifyMarker.DLL
    MyRegBox
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyRegBox.DLL
    MyMessageBox
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyMessageBox.DLL
    MyTextPrompt
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyTextPrompt.DLL
    MyFolderBrowser
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyFolderBrowser.DLL
    MyPatchingNotes
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyPatchingNotes.DLL
    System.Management
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll
    System.IO.Compression.FileSystem
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.IO.Compression.FileSystem/v4.0_4.0.0.0__b77a5c561934e089/System.IO.Compression.FileSystem.dll
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.IO.Compression/v4.0_4.0.0.0__b77a5c561934e089/System.IO.Compression.dll
    System.Web
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/System.Web/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.dll
    Network_GameDashPlugin
    CodeBase: file:///C:/Users/Harry/AppData/Local/SimTools3/Dash/Plugins/Network_GameDashPlugin.dll
    Serial_GameDashPlugin
    CodeBase: file:///C:/Users/Harry/AppData/Local/SimTools3/Dash/Plugins/Serial_GameDashPlugin.dll
    Sliders_VirtualPlugin
    CodeBase: file:///C:/Users/Harry/AppData/Local/SimTools3/VirtualPlugins/junk1.remove
    MyTrackBar
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools3/MyTrackBar.DLL
  15. yobuddy
    51,352Coins
    @haroldjames You will need to dragdrop the exe of the game onto the banner of the msfs2020 game.
    This way it will launch your version instead of the steam version.
    I sent you the missing file in IM.
    We just need to figure out where it goes and then I will add it tot he game plugin itself.
    Chat soon,
  16. lVlemphiz
    lVlemphiz Member Gold Contributor
    Automotive Engineer
    252Coins
    3DOF, AC motor, SCN6
    Question
    I reinstalled Simtools after doing a fresh install of windows. When I went to activate my license it says "It's already been activated" so Simtools never came out of Demo mode.
    Do we have to buy a license every install?
    BTW I have two licenses so I activated the other one; just not sure why I needed to.
  17. yobuddy
    51,352Coins
    Did you click activate or check license?
    As one will just check the status of the license and may give you the message.
    Nope
    Take care,
  18. lVlemphiz
    Automotive Engineer
    252Coins
    I tried both with my original license. It wouldn't let me pass go until I put in the other license.
  19. deeph46
    deeph46 Member
    641Coins
    2DOF, 3DOF
    Yes I did, but it keeps back to Gain 1. Ohh, and it's only on Assetto Corsa plugin.
  20. early_m
    early_m Active Member
    Chelmsford
    832Coins
    Hi Bud, I get the same error message, and I have the steam version. MSFS loads when I double click the start button, but the error pops up. If I click continue no telem data being received into ST
    • Optimistic Optimistic x 1
