Traction Loss setting
Discussion in 'SimTools Plugins' started by Gelatin, Sep 6, 2018.
  1. noorbeast
    153,950Coins
    +11,159 / 57 / -2
    It is an inverted adjustable tilt mechanism, which is off the original DX chair I tore apart for my rig: https://www.xsimulator.net/community/threads/dx-compact-simulator.5866/page-12#post-81158
    There are similar replacement options online.
    It does travel through a small arc, so there is a slight surge axis as it does so, that actually works to advantage in breaking and acceleration, particularly when a race harness is used.
    The main benefit is that it is adjustable, if lots of different people use the rig, and as it was designed with a human in mind the calibration scope is right, which is sometimes hard to do with other assisted solutions.
