SimTools v3 Public Beta
  1. yobuddy
    51,531Coins
    Sounds like you need to capture some good Max/Min settings for you rig.
    And I would suggest you check each DOF in axis settings one at a time. (To make sure they are working in the right direction) Sounds like you may have something backwards.
    Take care!
  2. Mu-KwangKim
    South, Korea
    - 689Coins
    video scaling is 100%
    maybe...
    You had scale issues in non-English windows in the past, right? Isn't that the problem?
    There is no adjustment in the output type. Is that also a scale issue?
  3. yobuddy
    51,531Coins
    No, I have not seen any gui differences in different locations of windows.
    The slider is just to long with the white slider dot off the screen to the right is all.
    (the reset buttons are there also, but they are under the slider that is to long)
    The only other thing I can think of if scaling is at 100, is your DPI setting?
    What is your DPI set to?
    Is this windows 10 or 11?
    I'm going to return the sliders to the way they were earlier in the week as it didn't fix your problem.
    And then look for a different solution to the problem.
    We will figure it out one way or another...
  4. Wingchop
    Wingchop New Member
    13Coins
    Hi, I downloaded SimTools v3 pro and installed the MSFS 2020 plugin.
    When I open the game from SimTools, it automatically goes to steam but my MSFS version is pc not steam, how do I get it to recognize is on my hard drive?
  5. yobuddy
    51,531Coins
    @Wingchop,
    You may find that some game plugins do not set a launch path for a given game plugin, or the path is setup for a different version of the game than what you’re running. To update a launch path for a game plugin, simply drag and drop the games exe or shortcut on the banner for the given game plugin.
    Let me know if you have problems.
    Take care,
  6. cheneau
    cheneau New Member Gold Contributor
    - 65Coins
    2DOF, 3DOF
    Hello friends I have a problem with V3 and f1 2022 in test mode it works but in simtool games do not receive the info, what is the ip address and the udp port of V3?? help me please
  7. yobuddy
    51,531Coins
    The plugin configures the output settings, you do not need to change them buddy.
    My guess is you need to configure your axis settings?
    ip:127.0.0.1 port:4123
  8. Mu-KwangKim
    South, Korea
    - 689Coins
    i used..
    korean windows 10 , dpi set 100%, 7680*2160
    korean windows 11, dpi set 100%, 1920*1080
    i'm try...
    dpi set 125% to same
    150% to same
    hum... OTL...
    I don't think need to reverse the version.
    The output type is still not working, but the filter side is now scrollable.
  9. Mu-KwangKim
    South, Korea
    - 689Coins
    I asked another korean user to check just in case.
    The icons overlap, but scrollable. (update version)
    What's the ... I'm curious!!! @_@
  10. yobuddy
    51,531Coins
    @Mu-KwangKim,
    Will you see if the same thing happens with the standard axis plugin?
  11. Mu-KwangKim
    South, Korea
    - 689Coins
    standard, basic all same.
    but
    I found a way.
    Click the load default button, the Degrees value becomes 1, and a move icon appears.
    There are still only four x icons, but I'll use them like this for now.
  12. Djalma Ribeiro
    Djalma Ribeiro Member
    Drone Pilot
    Cuiabá, Brazil
    168Coins
    Help me please. I used v3 for several days and everything was ok. Today when I went to use it I'm having problems. Assetto Corsa and AMS2 games are out of motion. I only have movement with Dirt 2. V2 is ok.
  13. yobuddy
    51,531Coins
    A lot of game plugins have been upgraded for v3.
    So which ever version you installed the plugin into last will work basically.
    So uninstall Assetto Corsa for V3, and then restart simtools and reinstall the plugin, and it work again in v3.
    But if you go and patch the game for v2, it may not work in v3 is all.
    Take care,
  14. yobuddy
    51,531Coins
    SimTools Update pushed and all Generic 2D plugins updated too.
    (they now properly close any open panels the plugins uses when loading a profile)
    @Mu-KwangKim,
    Let me know how the update goes buddy.
  15. irfan
    irfan New Member
    Türkiye
    158Coins
    I have that same problem. did you find a solution?
  16. Mu-KwangKim
    South, Korea
    - 689Coins
    Good!
    It works fine!
    930175620 New Member
    65Coins
    I use the SWEWART 6DOF platform, how should I set on Axis Assignment. I used thanos. 3.png 2.png 1.png
  18. Djalma Ribeiro
    Drone Pilot
    Cuiabá, Brazil
    168Coins
    It didn't work for me. I will uninstall everything and install again.
  19. yobuddy
    51,531Coins
    @Djalma Ribeiro,
    Are you using the Korean windows with a slider problem?
    This one was for you buddy. :thumbs
    Take care,
  20. Djalma Ribeiro
    Drone Pilot
    Cuiabá, Brazil
    168Coins
    I noticed that when reinstalling Simtools v3 the Profile Intensity has the slider in the middle but the value on the side is 0.
