SimTools v3 Public Beta
  1. Watchumacallit
    Watchumacallit BMET- Lead
    Biomedical Engineer
    Las Vegas, NV
    66Coins
    2DOF, JRK
    It was originally built for Simhub. Simhub sees it as a aurdrino for the led lights but not sure about the nextion screen. I know it uses 2 separate com ports. I guess I’ll just have to experiment. It’s worth upgrading my diy to the pro any way as you guys do a great job.
    Thank you for the updates and work you put in this. I prefer simtools over Simhub as I notice lag/ latency with Simhub in games like AMS2.
  2. Nicki9knuckles
    Nicki9knuckles Active Member
    Web Developer
    740Coins
    3DOF, DC motor, Motion platform
    @Mechromancer you rock!! I have motion now!
    So, when I tried using the "Legacy" option instead of the Elite Dangerous: Horizons option, I started seeing values in my min and max panel. No motion at this point, but after I uninstalled the plugin, restarted SimTools, and Steam and tried again, I was able to capture new values and save them. And after that I am getting motion!
    Thanks so much for your help @Mechromancer
    One other question for you, does the Yaw axis work for you? I see values in the min and max for it, but it doesn't seem to move my motor no matter what value I put in for it.
    ANyways, regardless I am a happy man, even if I only get 2 DOF with it, that still is great.
  3. Mechromancer
    434Coins
    WOOT! WOOT! Glad to hear.
    As for YAW, I don't use it. I only use PITCH, ROLL, SURGE and SWAY.
    I'm not sure, but YAW may only work if you have an H3 with the traction loss motor. Just guessing though.
  4. mrjadez
    mrjadez New Member
    perth
    155Coins
    Hello, I am trying to install the ETS2 plugin, for patching I give it D:\steam\steamapps\common\euro truck 2 folder and it keeps giving me path is not valid. Does anyone know why this is? also running Simtools3 as admin just to see if that was the issue.
    If I try to manually install by downloading the plugin and then moving it to the main window, it doesn't let me drop, the UI gives a cross icon on the mouse cursor.
  5. yobuddy
    51,189Coins
    The plugin is looking for... PathSelected\bin\win_x86\eurotrucks2.exe
    Probably because your running the app as admin.
  6. mrjadez
    mrjadez New Member
    perth
    155Coins
    Thanks. But I only have win_x64 directory in Euro Trucks. Does it only work for 32bit Euro Truck? I can check if Steam lets me download some branch that has that directory.
    Re the Admin thing, sure I can disable that. But the fact that I can't patch the game is whats been keeping me up lol
  7. yobuddy
    51,189Coins
    It works with both 64 and 32 bit, has a dll for both.
    We just bought it from steam and installed it and this is the directory it setup.
    (it's also how the v2 plugin worked, so seemed to make sense is all.)
    I thought it was worth mentioning so others know running as admin will cause drag-drop problems.
    (you can not drag-drop items as admin in .net is all)
    So, do you have this path then?
    "PathSelected\bin\win_x64\eurotrucks2.exe"
    (As I can verify the needed location with it also.)
  8. mrjadez
    mrjadez New Member
    perth
    155Coins
    Thank you. Yes. The new distribution that I installed fresh today, only comes with win_x64 directory and the path above. If I change that to win_x86 temporary, the plugin installs and puts the telemetry DLLS to both the X64 and X86 branches.
    I think it will really help newcomers to check for that path as well, yes.
  9. yobuddy
    51,189Coins
    Cool, we will update the plugin!
    Take care!
  10. moaale
    moaale IAN MRTIN
    NN
    ARGENTINA
    96Coins
    2DOF, DC motor, SimforceGT
    Can you guide me how to connect the foorza horizon 5 with the telemetry to the simtools software.
    I already enabled the telemetry data in the game I put the ip 127.0.0.1 the port 4123.
    In UDP relay settings I also put 127.0.0.1 and port 4123 and when I press play in the forza plugins it does not activate it and I have no data BECAUSE _¡??????
  11. yobuddy
    51,189Coins
    You do not want to udp relay the packet data back to itself.
    Please remove the UDP relay and give it another go.
    (Be sure to double click play)
  12. moaale
    moaale IAN MRTIN
    NN
    ARGENTINA
    96Coins
  13. yobuddy
    51,189Coins
    Press the play button 2x...
  14. moaale
    moaale IAN MRTIN
    NN
    ARGENTINA
    96Coins
    I don't know what 2x button you mean...
    I remember that when I installed the plugins it asked me for the game directory to activate the game when I double-clicked on play now when I install the plugins it doesn't ask me for the directory.
  15. yobuddy
    51,189Coins
    Not all game plugins will ask for a directory, it's usually only when the plugin requires file patching of some kind.
    The play button is there to launch the game.
    Double click play to launch the game.
  16. moaale
    moaale IAN MRTIN
    NN
    ARGENTINA
    96Coins
    If you know that the games are started but none of the three are connected to the telemetry data, that is, the play icon, what voice do you tell me, starts the game but does not give telemetry data?
  17. eduardo.magnetto
    eduardo.magnetto New Member
    Buenos Aires
    83Coins
    Hi! Is it possible to write our own game plugins, like on V2?
    Is there any sample code available?
    Thanks!
  18. yobuddy
    51,189Coins
  19. moaale
    moaale IAN MRTIN
    NN
    ARGENTINA
    96Coins
    Simtools v3... opens game on double click but doesn't connect telemetry between game and program
  20. eduardo.magnetto
    Buenos Aires
    83Coins
