3d printed Hoverboard motor wheel
Discussion in 'Direct Drive Wheels' started by Feisty, Mar 29, 2020.
  1. Keith
    Keith Active Member
    Electrician
    Canada, Saskatchewan
    148Coins
    So how is the wheel working? Are you happy with it?
  2. EER08
    EER08 New Member
    16Coins
    What kind of pulley you use here? And how you attached it at the back of the hub?
  3. Wayne Thebus
    Wayne Thebus Member
    CNC Machinist/Programmer
    Cape Town
    165Coins
  4. QuinrodD
    QuinrodD YawVR1
    self employed
    223Coins
    3DOF, Motion platform
    Looks very clean. How long does the hoverboard battery last during racing? and do you have the whole setup wireless, or is there still a USB cable to the PC? And how do you charge the battery?
  5. QuinrodD
    QuinrodD YawVR1
    self employed
    223Coins
    I am currently printing all the parts for this (almost done), what screws (type, length, diameter) do you use for the assembly? It looks like it uses no nuts, so just threading in the plastic? Does it hold up over time? Thanks, great work!
  6. QuinrodD
    QuinrodD YawVR1
    self employed
    223Coins
    tired to download the files, but it looks like an Onshape account is needed, which I don't have. Could you kindly upload some editable files? I use Fusion360 and want/need to make some modifications. Thanks :)
  7. Wayne Thebus
    Wayne Thebus Member
    Cape Town
    165Coins
    Hi QuinrodD,
    With my settings for the wheel which are rather brutal! The battery stay alive for around 3-4 hours, give or take, since I have never run it down in one sitting! By the time the battery gets drained I simply hook up the hoverboard charger to the battery to recharge it. (I cut off the chargers plug and replaced it with XT plug) I have 2 batteries, so one is always available when the other goes flat. As far as connection goes, I have a USB hub to connect the Diy pedals and Hover wheel to laptop via a single usb c cable.
    I use the Oculus quest 2 so my entire setup is portable.
    For any further information, just msg me
  8. Wayne Thebus
    Wayne Thebus Member
    Cape Town
    165Coins
    Hi I will upload soon, work getting in the way.
  9. Wayne Thebus
    Wayne Thebus Member
    Cape Town
    165Coins
    I was going to put threaded insert into the build, but the Amazon guys was taking too long. But so far the enclosure is holding up well, since it doesn't have much movement. I did add a small hinge to back to facilitate working on the internal, simply using magnet to keep it closed, easier to open and close without the need of a screwdriver
  10. QuinrodD
    QuinrodD YawVR1
    self employed
    223Coins
    That's great to hear, 3 hours would be plenty for me. It makes the whole setup easier, as I won't need a power supply. And also it will help me to make the entire setup wireless. I need to find a way to get the USB signals wirelessly to my PC. I have a Yaw VR motion simulator that can spin round and round endlessly, so a wireless setup would be ideal.
  11. QuinrodD
    QuinrodD YawVR1
    self employed
    223Coins
    that question about screws was actually for the OP and his 3D printed stand :) Looking forward to your upload of the files, so I can check it out. Thanks!
  12. Wayne Thebus
    Wayne Thebus Member
    Cape Town
    165Coins
    Hi
    I haven't had time to upload the files yet. The YAW sounds WAY cool! Roller-coaster with oculus and you could have an awesome time. Let me know if you find some information on making the whole setup wireless.
  13. QuinrodD
    QuinrodD YawVR1
    self employed
    223Coins
    Yes, its awesome Immersion. Roller coaster on the Quest actually works natively wirelessly with the YAW, but for PC racing sims I need the USB connection. There are ways to make it wireless, but it would cost around $100 altogether, so I am looking for a cheaper way. There is a USBIP software that is free, I need to look into that, but first I need to work on the wheel itself and get it finished. Right now I am using 180 degrees on the YAW Axis, which is quite good already
  14. paul2130
    paul2130 New Member
    155Coins
    Hello @Feisty .
    Do you mind sharing the part files for the model ? In my case, i will be keeping the base assembly from the hoverboard, so I need to adapt in order to fit for mounting holes :D
    Thank you.
    Kind regards,
    Paul.
  15. QuinrodD
    QuinrodD YawVR1
    self employed
    223Coins
    I believe he has a link to the files here: https://www.xsimulator.net/community/threads/3d-printed-hoverboard-motor-wheel.14454/
    But if you design something for the base assembly, please post it as I may want to keep mine as well
  16. paul2130
    paul2130 New Member
    155Coins
    I think only the STL files are available to download. STL cannot be opened in a CAD software to be able to make changes. At least that s what I thought...
    Yes, I will definitely post whatever I design.
    Thank you.
    Regards,
    Paul.
  17. QuinrodD
    QuinrodD YawVR1
    self employed
    223Coins
    Ah, yes, editing STL files is very annoying. You could transform them to be able to edit them, but its normally faster and better to just make it new versus editing.
  18. paul2130
    paul2130 New Member
    155Coins
    Yes, that is my other alternative. I will get to designing when I get home. Thanks !
  19. paul2130
    paul2130 New Member
    155Coins
    Hi all,
    I will post here a SolidWorks assembly with the encoder mount that i designed. This is tested, it works good. The cog wheels do not mesh 100%(of the surface) but i have tried to make it skip gears, and couldn't make it.
    These brackets were printed with 40% infill i think , solid enough. Encoder cog wheel was pressed on the shaft, and motor cogwheel was bolted with the 6 bolt of the hoverboard motor cover.
    Thanks, and good luck !
  20. MrDemon
    MrDemon New Member
    - 84Coins
    Hi. One part broke and the link to Google Drive no longer works. Does anyone have the 3D model files from the first post?
