Ralph's Racingsim Project
Discussion in 'DIY Motion Simulator Projects' started by ralphvdberg, Jan 26, 2010.
  1. Nima
    Nima Member Gold Contributor
    Glaser
    Bad Zwischenahn
    532Coins
    hi ralph,
    i have make many test for shakes.you can go a other way for shaker.
    with a velleman 8055 you have this i mean,than you mast have a hbridge
    and a acculator with a asymcron weight on the axis.you can test it with a windowmotor.i mean for rpm feeling is this better as with buttkicker.
  2. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,801Coins
    Hi
    Hi Ralph
    No i havent any expecience with them.
    I found them 3 weeks ago.
    Regards Ad
  3. ralphvdberg
    ralphvdberg New Member
    Racecar/Porsche mechanic
    Netherlands
    277Coins
  4. RaceRay
    Hamburg, Germany
    23,884Coins
  5. splendiddd
    splendiddd Active Member
    CCTV security
    Netherlands
    813Coins
    Hi Ralph,
    I can confirm the boards from Leo are great!
    ps: Ik woon ook in nederland
    Cheers,
    Rob
  6. CXCSimulations
    CXCSimulations Member
    - 9Coins
    Yup, Leo's boards are top-notch :)
  7. Schnullerbacke
    Schnullerbacke New Member
    Photographer / Videographer
    Germany near Munich
    370Coins
    Hi Ralph,
    I use this controller from Leo: http://www.leobodnar.com/products/BU0836X/ - so I can fast and easy connect and disconnect the two button boxes and test different configs. I'm absolutely satisfied with it !
    You asked for a Buttkicker. In the meanwhile I'm using TWO buttkickers, one on the back of the seat and the second on the bottom of the seat. I bought an amplifier with which I can separately adjust the two BK's - it's great...
  8. ralphvdberg
    Netherlands
    277Coins
    Thnx guys.. I orderd one today..
    Chris.. what kind of buttkicker do you use??
    I'am now building a new frame.. I think I will order a frex wheel and pedal set.. I drove with it.. It's realy great!!
  9. Schnullerbacke
    Germany near Munich
    370Coins
  10. splendiddd
    CCTV security
    Netherlands
    813Coins
    Total cost of what? Do you plan on ordering a Frex wheel Ralph?
  11. ralphvdberg
    Netherlands
    277Coins
    Yes Rob... that's the plan.. (I have already orderd today)
    Thanks chris..
  12. splendiddd
    CCTV security
    Netherlands
    813Coins
    :thbup:
    Cool, if you have any questions regarding the wheel, ask me. (kan ook in het nederlands ;))
    I have one for over 6 months now, its a blast.
    Greets
    Rob
  13. ralphvdberg
    Netherlands
    277Coins
    Dat is mooi Rob.. Je zal er wel veel plezier van hebbe :)
    ff een paar vraagjes..
    Hoe breedt en hoe lang is de stuur 'kolom' zonder stuur?
    Zou je een foto voor me willen maken van de onderkant?
    Ben een nieuw frame aan het bouwen van daar.. zal nog wel ff duren voor dat het in nederland is.
    I asked him some dimensions of the frex wheel.. :cheers:
  14. splendiddd
    CCTV security
    Netherlands
    813Coins
    Hey Ralph,
    Ik heb wat foto's voor je gepost om het duidelijker te maken.
    Hier volgen wat tips. Dit is puur info, en spreken misschien voor zich, en zijn niet om je af te schrikken, maar om je te waarschuwen voor een aantal zaken.
    Let er op bij het vastmaken van de unit, dat deze op een goede stevige constructie komt te staan.
    Dit ding heeft behoorlijke power ;) de hoekjes die aan het simwheel zitten kan je verstellen, en het zijn er vier. (waar een m8tje door heen kan)
    Ook raad ik je aan om de binnenkant regelmatig te 'smeren', deze machine smeer kan je ook bestellen bij Frex, maar een goede machinesmeer zal ook werken. Dit klinkt een beetje vreemd misschien omdat dit een zeer duur stuur is, maar er zijn mensen die problemen hebben gehad (ik niet) en voorkomen is beter dan genezen. Wordt ook geadviseerd door Frex. (staat op de site en in de handleiding)
    Mijn instellingen zijn in het windows/frexffb gedeelte: alles op 0% en de Force op 40% (max 50%), Let hier op als je hem voor het eerst gebruikt, anders breek je je polsen :happy:
    Misschien een persoonlijke smaak, maar ik vind dat een race stuur bijna 90graden moet staan, wel iets schuin omhoog, maar zeker niet wat de meesten hier hebben, probeer het zou ik zeggen. (In de echte klasses hebben ze het niet voor niets zo :)) EDIT: ik zie in je vids dat je dat al doet :thbup:
    Wat ook belangrijk is: hoe groot stuur je gaat gebruiken, ik gebruik een momo 290mm(f1 style) en een momo 280mm. Groter dan 290mm schijnt niet aan te raden te zijn. maar ligt er natuurlijk ook aan hoe je het stuur gebruikt. Er zijn namelijk mensen (amerikanen voornamelijk) die van die oval sims spelen en er een gigantisch stuur op schroeven en de Force flink op krikken. Dit zijn naar mijn mening ook de mensen die de problemen hebben.
    De meeste tips die ik je geef, geeft Frex ook gewoon in de handleiding, maar wou het toch even kwijt. Ik ben van mening dat dit absoluut het beste Sim stuur is die er bestaat. mag ook wel voor dat geld ;) Je voelt het rubber door je handen, en dit ding is mega snel, fluisterstil, stabiel en realistisch. Hierna voelt een G25 als een plastic speelgoed ding. je wilt niet meer terug...
    :D
    Klik op de pics voor een vergroting.
    Wheel Side:
    Sim Wheel Side:
    Back/Side:
    Wheels i use:
    Side View of wheel:
    Front Quickrelease side:
    Side 2 Side about 12 cm (with the attached mounting bits, you need those!)
    Total lenght:
    Total lenght up close, about 53cm WITH quick release, without probably 48cm:
    Bottom side (is flat):
    Back side where the motor is:
    Front:
    BTW:
    you can also see the wheel here in my (yet again posted) video:
    http://www.youtube.com/watch?v=JV7kugUWbCE
    Cheers, :skoal:
    Rob
  15. ralphvdberg
    Netherlands
    277Coins
    Thanks rob... the pics and info were realy helpful.. will make some pics next week from my new frame..
    Do you drive now on the frex setup (scn5) or like simexperinse?
  16. splendiddd
    CCTV security
    Netherlands
    813Coins
    Hi Ralph,
    Frex setup with X-sim. And adjusted the angles of the Scn5.
  17. ralphvdberg
    Netherlands
    277Coins
    Hi Guys...
    Long time ago...
    Finished my project...
    Feel free to comment!!
  18. Deleted member 4120
    Deleted member 4120
    :eek: :eek: w0ow its amazzzing!!!!!!!! very nicee :thbup:
  19. Frakk
    Frakk Active Member
    328Coins
    Quality work!
  20. Nima
    Glaser
    Bad Zwischenahn
    532Coins
    hi ralph,
    nice look good work
