vthinsel
Gran Turismo 7 - PS4/5 2022-12-03
Finally motion for GranTurismo on PlayStation !
  1. levers
    965Coins
    Hi @vthinsel,
    I've attached the 2 files generated but I've had to add the .txt suffix as they wouldn't upload otherwise. The car was the Renault Clio RS at Brands Hatch GP circuit.
    I hope it helps you resolve the issue. If you need any more info please let me know.
  2. vthinsel
    vthinsel Well-Known Member
    FRANCE
    6,030Coins
    Arduino, 4DOF
    Wow ! You upgraded the engine ? Getting more than 10G with a Clio RS :)
    Indeed the result is weird. With constant speed increase, we should get a stable forward force. I'll check more in details when I'm back home if I have the same behavior and debug the issue in more details.
    You said you tried with earlier versions of the proxy, and you had the same issue, right ?
    Version upto 1.2 uses regular math operations, without numpy/pandas. It is here: https://github.com/vthinsel/GT7Proxy/releases/download/v1.2/GT7Proxy.exe
  3. levers
    965Coins
    Hi I've literally changed nothing. I've gone through the initial driving lessons just to be able to pick a car and circuit. I started with your initial release of the proxy and the surge worked well but as you can see it's now erratic. It was only when I looked again at the plugin I saw an update but that didn't change anything and then when you mentioned further update I downloaded that. So I would suggest the sway issue was there from the start and the surge happened with one of the game updates.
    Thanks for taking the time to look at this!
  4. vthinsel
    FRANCE
    6,030Coins
    Arduino, 4DOF
    Well, I have done a comparison between version 1.2 and 1.5 (1.5 uses numpy/pandas) and the result is interesting. I used my record/playback tool to have the same basis:
    version 1.5 on the left and 1.2 on the right.
    Local velocity looks the same, but we can clearly see that the surge force is different. This is strange as well because surge is just a delta of two consequent local velocity values divided by the time. I need to dig this further, but unfortunately, I'm off tonight for 3 weeks.
    For now, I suggest you go back to version 1.2. I'll also pl$ull-out version 1.5 from github.
    Thanks for pointing this issue. Feel free to open a bug as well on github.
  5. vthinsel
    FRANCE
    6,030Coins
    Arduino, 4DOF
    roll/pitch/yaw and local velocities are fine in both versions. I really need to find a better way to compute the forces :
  6. levers
    965Coins
    Thanks for all your efforts! I'll have a play with the earlier versions of the proxy while you are away. Hopefully at some point you can find a solution. I'm grateful for what you have achieved!
  7. vthinsel
    FRANCE
    6,030Coins
    Arduino, 4DOF
  8. vthinsel
    FRANCE
    6,030Coins
    Arduino, 4DOF
  9. levers
    965Coins
  10. levers
    965Coins
    Hi @vthinsel,
    I've tested it and surge is much better. Did you make the same changes to sway as that seems a little better but still has the random direction changes.
    Thanks for your efforts!
  11. vthinsel
    FRANCE
    6,030Coins
    Arduino, 4DOF
    Good News then. Yes, all forces use the same calculation. Will check if this can be improved when I get back in a couple of weeks
  12. tazerface
    tazerface Member
    Cologne, Germany
    173Coins
    Hello mates,
    I am a newbie and just set up my first 2DOF rig which I started to build for GT7 as soon as I found your awesome plugin - many many many thanks for this!!
    I started playing around with the sensitivity in order to get some first movements from the game into the rig.
    It is already really nice, but what I found so far is, that pitch only reacts to the road incline/decline, but (almost) not to acceleration/braking, which I was hoping for the most.
    Also gear shifting is not giving me any pitch movements, so far.
    What is really too extreme imo is touching kirbs and walls, shakes my rig a lot.
    I know these questions may refer more to simhub and smc3 settings itself, but could you please give me a hint how to intensify acceleration and deceleration forces, maybe show me how you set up your sensitivity settings?
    I am using GT7proxy 1.7 for now.
    Many thanks guys! :)
  13. levers
    965Coins
    The output telemetry replicates actual forces so if a car has softer suspension then it will pitch when you accelerate. If you want to exaggerate it artificially then in SIMTOOLS you need to mix some surge into pitch and to reduce the roll on kurbs then increase the values in Min/Max tuning.
  14. vthinsel
    FRANCE
    6,030Coins
    Arduino, 4DOF
    Hello
    It is up to you to configure your axis based on position/forces. Surge is the force you should use to feel accélération upon gear change for example
  15. tazerface
    tazerface Member
    Cologne, Germany
    173Coins
    thanks for your replies! I am playing around with surge and it works, quite jerky but this will be my setup, i guess. can feel the acceleration already :)
    Next step is currently my buttshakers - as I am quite happy with what simhub does for me, and I am aware of the UDP port issue - might there be an option to add a flag by starting the GT7proxy to define a different port, so I can forward the telemetry from simhub to the GT7proxy.exe?
    I know one guy here changed that in source code, but I am not confident enough to compile my own .exe.
    Might an optional flag like --port be an option for a future release?
  16. vthinsel
    FRANCE
    6,030Coins
    Arduino, 4DOF
    yes, i’ll include ports as arguments. This will make it more flexible. And maybe compatible with the udp proxy/ replicator I made here https://github.com/vthinsel/Python_UDP_Receiver
  17. tazerface
    tazerface Member
    Cologne, Germany
    173Coins
    Hello Kim,
    could you please explain how you did this?
    I also managed to compile a new proxy.exe from source where I changed the ReceivePort from 33740 to 33750.
    Simultaneously I forwarded the telemetry from simhub to this port, but when I start the proxy it gets a WinError 10054 (remotehost closed connection)
    Where to forward simhub data to (which IP) and then what ps_ip to open? I tried with both the ps IP and 127.0.0.1 as both softwares run on the same computer, but no success
  18. vthinsel
    FRANCE
    6,030Coins
    Arduino, 4DOF
    If you can wait a couple of weeks i’ll make a new release where all ports will be configurable. Or you can contribute and submit a pull request
  19. tazerface
    tazerface Member
    Cologne, Germany
    173Coins
    i will wait for it of course - just trying to make a quick solution as I am always trying around a bit and it feels like there is not much left to get it running with the current source code - sorry if i am annoying someone, just trying my luck
  20. tazerface
    tazerface Member
    Cologne, Germany
    173Coins
    all right, I got it running.
    I changed the port in the GT7proxy.py and forwarded the UDP data in simhub to this port under the game settings of GT7 (not the relay UPD plugin!).
    Then I can open the modified GT7proxy.exe and open the 127.0.0.1 as ps_ip and both simhub and simtools work simultaneously - yeehaw!!
    I am still getting the error WinError 10054 in the console, but it works anyway.
    Looking very forward to the next release, but I am already happy by now :)
