SimTools v3 Public Beta
  1. yobuddy
    51,659Coins
    There is an update to f1 2023 to fix this games error, people without the update will see a little white arrow on the games banner. know that you can click the little white arrow to update the game plugin.
    Axis limiting is static and used for all games, so simply set values and they will be used for all game plugins.
    Hope that helps.
    My guess is you do not have them assigned in your axis profile?
    (seems to be working here is all)
    Chat soon all,
  2. deeph46
    deeph46 Member
    641Coins
    2DOF, 3DOF
    I see, have just an idea, how if Axis Limiting, Parking Location, Crash Detection put in Home (in game banners).
  3. deeph46
    deeph46 Member
    641Coins
    2DOF, 3DOF
    BTW, the Output Interface command is [A<Axis1a>]. What is the A capital refer to?
  4. yobuddy
    51,659Coins
    All the motion related stuff is in the motion section.
    I'm guessing your referring to the SMC3 sketch for the Arduino? [A<Axis1a>][B<Axis2a>][C<Axis3a>]
    If so, its how the sketch inputs data is all, with the 'A' referring to motor one, B is motor two and C is motor three.
  5. Pastrana
    Pastrana Member
    Argentina
    165Coins
    I add: I just finished installing and testing il2 with plugins 2.0.5 and everything seems to work correctly. I don't know why the il2 also doesn't directly move the engines in the game, if it does in test input.
  6. yobuddy
    51,659Coins
    What does your axis assignments and max/min settings for dcs look like in v3 buddy?
  7. deeph46
    deeph46 Member
    641Coins
    2DOF, 3DOF
    Yes, I'm referring to that command. Thanks for the info, it's clear now.
  8. Jeroen Vrancken
    Jeroen Vrancken ProSIMU T3000 Gold Contributor
    CPA
    Netherlands
    - 65Coins
    3DOF, SCN6
    What setting do you have to use in the telemetry screen in f12023?
  9. laurent lafont
    laurent lafont New Member
    43Coins
    Hi everyone,
    Yesterday i installed Simtool V3 for Njmotion campact-R and was really easy to septup simtool ! the Compact R was working well, this morning also ! But this afternoon when we tried to play again, nothing !!? i didn't modified anything but now i have an error ! When i click on "Test setting" the error appear and the testing doesn't work. Same when i lunch a game... Can you help me ?
    Sorry for my english, i'm french ;)
  10. yobuddy
    51,659Coins
    Please check that the cable between your PC and the simulator is well connected.
    Then I would reboot and give it another go.
    (Antivirus is the only other thing I can think of, what are you using buddy?)
    Please let me know how it goes.
    Take care,
  11. richdelta9
    8,850Coins
    We just posted an update to Automobilista 2. You can now use Project CARS 2 in the system settings.
    • Like Like x 5
  12. laurent lafont
    43Coins
    Hi
    thanks for your answer. Infortunatly yseterday i tried to check again and nothing... the red light from the switch on/off stay desperatly off... I checked the fuses, other electrical cable, outlet.... But nothing... So i send back to Njmotion... I'm very disapointed, because i bought a used one. Next time i spend more monney but i buy new... :/
  13. yobuddy
    51,659Coins
    New Trackmania v3 game plugins now available! :thumbs
  14. MR Fast
    MR Fast New Member
    32Coins
    3DOF, Arduino
    I will start with, I know I missed something, but I cannot figure out what. I built my rig and it is driven with an arduino. I have seen similar problems to mine in the forum, but none of the answers seem to fix my issue. I downloaded LVS to help diagnose any issues (ultimately GT7 via playstation is my goal) with either game, I can see the telemetry move in Simtools, but no motion output to my rig, not even in testing. (works fine in SMC utility) Game seems to grab the com port for the arduino, but provides no information to drive it. I have downloaded and configured serial interface and axis assignments. What am I missing????
  15. yobuddy
    51,659Coins
    @MR Fast,
    Please make sure the SMC utility is not running, then goto your interface settings for motion and click "Test Settings". Does it work?
    If not, can I get a screenshot of your interface settings.
    Chat soon,
  16. MR Fast
    MR Fast New Member
    32Coins
    3DOF, Arduino
    SMC is off, rebooted to make sure...test settings does not work, here are my settings.
  17. yobuddy
    51,659Coins
    Please set the BitsPerSec to 500000 and it should work.
  18. MR Fast
    MR Fast New Member
    32Coins
    3DOF, Arduino
    now I get an error message, "Unable to start interface" I did have that at times prior to the change we just made. Shut it all down and started back up and it worked with the interface test settings..... went to LFS and it is working in the game too...... now to work on my axis settings....... Thanks a ton!!!!
  19. lVlemphiz
    lVlemphiz Member Gold Contributor
    Automotive Engineer
    252Coins
    3DOF, AC motor, SCN6
    any chance grid autosport (2019) can be added back to the supported games?
  20. MR Fast
    MR Fast New Member
    32Coins
    3DOF, Arduino
    I stumbled upon a modified SMC sketch with soft start by BlazinH ....sounds great but looks like the thread died in 2019......anyone using this and how does it work??? Can I just compile it over the original, or do I need to save my settings in SMC utility first?
