SimTools v3 Alpha (Questions, Answers, Fixes, Show & Tell)
Discussion in 'Tutorials and Tips by the Developer' started by yobuddy, Mar 17, 2022.
Thread Status:
Not open for further replies.
  1. yobuddy
    51,227Coins
    A lot of the v2 manual applies to v3 still, but no specific manual for v3 yet...
    You can get the manual here if needed: https://simtools.us/downloads-links/
    Or you can PM me questions also, I'm always around.
    Take care,
  2. Navegation2
    Navegation2 New Member Gold Contributor
    - 9Coins
    Hi everyone,
    Forgive me if the question I am about to ask is not in the right place.
    I happen to be using several DOF (for now there are 7) and I want to use for example with different axis the same movements such as the surge, Is it possible to have several surges but that they can be configured independently?
    I hope I have explained myself correctly.
    By the way, congratulations to both the forum and the creators of Simtools, it is without a doubt a great piece of software/community forum.
    Thank you very much.
    152,627Coins
    +11,087 / 56 / -2
    I am not sure of your physical setup or hardware but if there are separate hardware controllers then they can be setup to independently run an axis, such as surge.
  4. Navegation2
    - 9Coins
    Thank you very much for your answer, I didn't explain myself very well, sorry.
    For example, if I want to have different Max/Min surges, how can I do it? In principle, in the list there is only one surge, so the Max/Min that you put there, will be affected equally in all the surges that you have selected in the hardware without being able to modify them independently.
  5. yobuddy
    51,227Coins
    You have 3 sets of max/min values, see here.
    And then in the axis assignments, you can tie to any one you want, see here.
    Hope that helps,
  6. Navegation2
    - 9Coins
    Wow !!! on the one hand, thank you very much, I knew that I was the one who failed here, how stupid I am, I'm sorry.
    On the other hand, to reaffirm myself, incredible forum and incredible software.
    My most sincere congratulations to all of you, thanks again for your help.
  7. Felix_31
    Felix_31 New Member
    88Coins
    Hello everyone,
    I have a few questions, I'm new to the whole topic and now use Simtools V3 with my 2 DOF motion rig. My problem, especially in ACC, is that when I go up a small incline, the seat always tilts forward a lot and when I only shift in 1st gear, it only goes backwards a little when I accelerate in the other gears I notice a jerk when shifting. I would be happy to attach a picture of my Axen configurations to you.
    Maybe someone can help me to solve this problems.
  8. Blame73
    Blame73 Well-Known Member
    8,305Coins
    Hey,
    first of all your axis total is 270, that's very high. Being per percentage of all the forces it should be 100 (but you can go a bit higher considering not all forces are at their maximum at the same time), let's say you can go up to 120 (but I keep it at 100)
    what you're referring to (the change of gear) is normally tied to the Surge force, we normally have asymmetrical positive and negative values for Surge. You can set them under Min-Max Tuning.
    These are my values for Surge in ACC:
    EDIT: but I would first of all adjust the axis forces to go around 100 (try not to have too much pitch if you don't want to feel too much ups and downs)
  9. Pyro
    Pyro New Member
    28Coins
    All right,
    yeah im New and testing how everything works. I will try it and than answer you.
  10. Pyro
    Pyro New Member
    28Coins
    How can i Chance the Surge number? If i click in this field, nothing happens.
  11. Pyro
    Pyro New Member
    28Coins
    My problems are that when I press the accelerator, the seat doesn't move backwards every time I switch gears. You're supposed to be pushed into the seat like in a real car, and when I drive uphill the seat always moves forward a little. although he should actually go to the back. I now have Axis total = 100
    152,627Coins
    +11,087 / 56 / -2
    It sound like your Dir checkbox settings in Axis Assignments are not configured correctly, as they determine which way each axis move.
  13. Blame73
    8,305Coins
    To manual change values press Capture, edit the values, Save, then Stop
    But, as noorbeast said, you probably have to check the direction of each axis in Axis Assignments, that's the basic for having everything working correctly
  14. VFX Pro
    VFX Pro Member
    Los Angeles
    425Coins
    Motion platform, 6DOF
    Hello all,
    Is there any estimated time frame where v3 will come out of beta? I am asking since I can't use v3 since ProSimu won't support it until it's out of beta. I'm hoping v3 will provide a way to reduce the strong shifting jerk motion in AMS2. I tried Washout to 50, and Surge -50 in the profile editor, sadly no luck. Hoping V3 has the same shift/surge softening control as SRS software does...
    152,627Coins
    +11,087 / 56 / -2
    It is always a case of it will be done when it is ready, and there are a lot of variables in that, but Beta testing has added a lot of refinement and helped squash many bugs.
    Commercial providers can and are already taking advantage of the new v3 plugin repository system, where they can craft their own repository and have plugins specifically tuned for their particular rigs.
  16. zhai1987
    zhai1987 Member
    320Coins
    2DOF, 3DOF, AC motor
    Brother, I open SIMHUB, SIMTOOLS can not link to my controller, please do you show up?
  17. zhai1987
    zhai1987 Member
    320Coins
    Turn off SIMHUB, everything's fine. What should I do
  18. noorbeast
    152,627Coins
    +11,087 / 56 / -2
  19. Felix_31
    Felix_31 New Member
    88Coins
    Hello everybody,
    I asked something a few months ago, but I haven't had much time in the last few months and now I want to get back to work on my 2dof.
    In the last few days I've been trying around, but unfortunately I just can't get the Motion to work properly.
    I configured the axes and also tried out the min/max values.
    My problem is the following:
    - Sometimes the simulator tilts to the left or right even though you are driving on a straight route
    - Sometimes it starts to lean (roll) much too early before a curve.
    - Sometimes it takes a long time until it returns to the 0 position (park position) after a curve.
    - The simulator reacts very jerkily despite 20% per Ax and 50% sensitivity.
    These are my fundamental problems. I hope someone can help me with this.
    L.G
  20. early_m
    early_m Active Member
    Chelmsford
    820Coins
    Please post screen shots of your SMC3 and simtools axis and interface settings
Thread Status:
